Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 02-23-2016, 03:57   #1 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
Talking xbox one when turning on for a brief second, then shutting off
I have a Xbox one that when I try to turn it on,it does for some seconds then shuts down.I think that it's a hardware issue..Anybody has a solution or bright idea? Thank you !
Old 02-23-2016, 21:29   #2 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,444
Hi....ive got this info from xbox for you...
Troubleshoot Xbox One unexpectedly turning off
Your Xbox One console may unexpectedly turn off under the following circumstances:
The console is too hot.There's a problem with the power supply.The*Turn off after*setting is enabled, and the console has been inactive for the allotted time.
On this page
Topics
Your console shuts down unexpectedly
Solution 1: If the console is too hot
If you received a message stating that your Xbox One console is getting improper ventilation, or it's hot to the touch, follow these steps:
Turn off the console.Wait at least one hour.Move the console to a well-ventilated spot.Turn on the console.
Important*Make sure that your console is in a cool, well-ventilated place. Remove any objects on, under or right next to the console.
For tips on positioning your Xbox One console, see*Xbox One console ventilation*and*Getting started with Xbox One.
Solution 2: Troubleshoot your power supply
If your console continues to shut down unexpectedly, the problem might be the power supply. For information about how to troubleshoot power supply issues, visit*Xbox One console won’t power on.
Solution 3: Change the console settings so it doesn’t turn off automatically
Turn on the console.Scroll left from*Home*to open the guide.Select*Settings.Select*All Settings.Select*Power.Select*Turn off or restart.
If you follow these steps but the console continues to get hot and shut down,*request a repair.
Your console shuts down unexpectedly while streaming content
Solution 1: Clear persistent storage
To troubleshoot this issue, clear persistent storage. Here's how:
Note*Persistent storage is Blu-ray data that's been cached on the console.
Scroll left from*Home*to open the guide.Select*Settings.Select*All Settings.Select*Disc & Blu-ray.Select*Blu-ray.Select*Persistent storage.Select*Clear persistent storage.Turn off and unplug your console, and then wait 5 minutes.Plug in and turn on your console, and try streaming the content again.
Solution 2: Try a wired connection
Some wireless routers have settings that may cause your Xbox One console to shut down unexpectedly. For example, a power-saving setting or network setting may cause your console to shut down.
If you use a wireless connection to connect to Xbox Live, try a wired connection. For information about how to set up a wired connection, see the*Xbox One First-Time Connection Solution.
If you can’t stream content when you use a wireless connection, see the*Networking Hardware Information section of the Xbox Forums, or contact the router manufacturer for information about how to configure the wireless settings on the router.
__________________
Wbr
THE CLASH
Page generated in 0.19612 seconds with 7 queries
