GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
The Following 3 Users Say Thank You to jmermel For This Useful Post: |
12-29-2012, 21:11 | #7 (permalink) |
Moderator Join Date: May 2009 Location: United States
Member: 1032904 Status: Offline Thanks Meter: 1,270 | Download Instructions:Download files into file folder. Click “V” by file. Do not choose “All Parts” Unpack install .apk and copy to Folder structure: sdcard/tomtom/com.tomtom.country/ |
The Following User Says Thank You to jmermel For This Useful Post: |
01-07-2013, 09:19 | #8 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1864460 Status: Offline Thanks Meter: 0 | Thank you so much for the app. I am a total android noob just started yesterday so would really appreciate some help. I have downloaded both parts of the southeasia apk separately and then I was able to install the apk but every time I load the app it says no maps installed I have moved the other files all over the place but to no avail. Sorry but could you please tell me what to do? Thanks a lot |
01-07-2013, 09:27 | #9 (permalink) | |
Member: 1032904 Status: Offline Thanks Meter: 1,270 | Quote:
2) Install the app from the apk. 3) Run the app. This will create a folder on the root of your SD card called com.tomtom.ukireland 4) Open this folder and delete the entire contents. 5) Copy the 'metadata.xml' file and the 'files' folder from your download and place in com.tomtom.ukireland 6) Run the app again. | |
01-08-2013, 03:37 | #10 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 979804 Status: Offline Thanks Meter: 10 | Quote:
thanks. I'm having similar issues, app starts, but, can't find maps downloaded the 2 parts, unarchived/merges to same folder, copied to device, run the australia patched apk it made dir on external SD card, the path in xml specifies /mnt/sdcard/tomtom/com.tomtom.australia so I copied dir from externals to internal, but, after app starts, it keeps saying ;map not found, and, can not quit it without killing the process, menu or back won't do anything this in on A 4.2.1 EOS Xoom, is it the change in path... with 4.2? like, in the file manager is like /storage/emulated/0 ? I tried editing xml with that, so far, no luck | |
01-08-2013, 04:31 | #11 (permalink) |
Member: 979804 Status: Offline Thanks Meter: 10 | tried on phone, A 4.1.2, again, installer extracted to ext sd media, not, internal, BUT after copying unarchived 'files' folder to /sdcard/tomtom/.... I'm working !!!! thanks! I'll try fiddling with the Xoom later this evening, and, see if I can repeat my success, thanks so, to the op, what I done: install, then copy 'files' folder from download below/sdcard/tomtom/com.tomtom.yourcountry including xml file hth |
01-08-2013, 11:28 | #12 (permalink) | |
re-did Xoom, works right off, as per instructions: install, delete newly created country folder 'files', copy 'files' from archive, works don't know what was I smoking before, sorry, all's well | |
