GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
12-07-2014, 19:36 | #17 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2306637 Status: Offline Thanks Meter: 0 | After long long tries, I finally installed it on Samsung Galaxy Tab Pro 12.2 (KtiKat 4.4.2) on internal memory storage. - unpack the .rar file and copy tomtom folder and .apk to SD card - install the application - create the second file folder and move all the application files inside it (i.e. /data/data/comDOTtomtomDOTwhatever/files/files - also move/copy the .metadata inside files/files folder - copy comDOTtomtomDOTwhatever folder into /storage/emulated/0/Android/data/ - copy the above folder to /storage/emulated/legacy/Android/data/ (if it's not there already) - start the application if the application starts but the map is blank, probably you have a high resolution device. I use multi window and start GPS Status and TomTom app together just to decrease the window size. hope that helps. |
01-30-2015, 13:56 | #18 (permalink) |
Junior Member Join Date: Apr 2005
Member: 136288 Status: Offline Thanks Meter: 1 | On Samsung Galaxy S2 .... Tried with size set to zero in .XML file. Also with 2 files folders in directory structure. No go. still get "Unable to connect to TomTom Try again later. (WiFi is ON) Any ideas anyone? earlier TT releases all work ok. |
