Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 08-25-2010, 16:56   #1696 (permalink)
dsa8310's Avatar
Member: 973199
Originally Posted by dsa8310 View Post
Sure, anyone could check out 39, 40, 41, etc, now that there is user level access in dsa!
(I am going to check out 39 asap)
Well, on my go 910 with nc v9.205, modelid 5 seems as good as modelid 17, both being Rider modes.
39 does not work (it reboots).
40, 41 don't have menus at all.
Actually, beside Rider (and Go), there seems no much interest in other modes, except for Self, which stands in place of any particular device mode.
Old 08-26-2010, 00:24   #1697 (permalink)
dsa8310's Avatar
Member: 973199
Link to dsa-25August2010.zip
Link to dsa-25August2010.zip:
New: just a change in the way the TomTom device mounting point is recognized by the application.
Opening a CAB or BL will display the TT path automatically, if device mounted (before it was done at start-up time only).
I made this change to ensure that the application initialization happens exclusively in Java.
@njofy: this time, you will get the dsa window on screen; click the unnamed check box next to the big Patch button and read the string displayed in the pop-up text area below the main dsa window. If it does NOT read "Windows", then this was the problem. Let me know what the string is.
The Following 7 Users Say Thank You to dsa8310 For This Useful Post:
Old 08-26-2010, 10:08   #1698 (permalink)
dsa8310's Avatar
Member: 973199
As before, the TomTom button has full control over the installation path. Canceling the TomTom dialog will erase the path, if so needed (e.g. a BL patching without installation).
Old 08-27-2010, 20:10   #1699 (permalink)
Member: 219051
Red face
hi just downloaded and installed the DSA , it installed ok and the icon appearears on my desktop. but agoin when i run it . black cmd box flashes.....
Old 08-28-2010, 23:35   #1700 (permalink)
dsa8310's Avatar
Member: 973199
I am sorry to hear it.
Bad luck, wrong Java maybe.
I would have heard about 64 bit issues by now, so it's not that.
Old 08-29-2010, 05:55   #1701 (permalink)
Member: 1143028
I can confirm : no problem at all on Win7 64 Enterprise.
Only the correct Java version is needed or maybe you have to check the rights for your account.
Old 08-30-2010, 18:05   #1702 (permalink)
dsa8310's Avatar
Member: 973199
@njofy
C:\Users\UserName>java -version
java version "1.6.0_21"
Java(TM) SE Runtime Environment (build 1.6.0_21-b07)
Java HotSpot(TM) Client VM (build 17.0-b17, mixed mode, sharing)
C:\Users\UserName>dir "c:\Program Files\Java\jre6\bin\java.exe"
Volume in drive C has no label.
Volume Serial Number is 44E9-AD81
Directory of c:\Program Files\Java\jre6\bin
07/17/2010 05:00 AM 145,184 java.exe
1 File(s) 145,184 bytes
0 Dir(s) 13,879,955,456 bytes free
C:\Users\UserName>java -jar "c:\Program Files\dsa.app\Contents\Resources\Java\dsa.jar"
Issue the above command(s) in a DOS window (run cmd.exe) to figure out the error.
The Following User Says Thank You to dsa8310 For This Useful Post:
Old 08-30-2010, 21:53   #1703 (permalink)
Member: 219051
just did that got a lot of text in the dos window.
Old 08-30-2010, 22:05   #1704 (permalink)
dsa8310's Avatar
Member: 973199
Use the upper left corner button to enter the DOS window "Edit" menu in order to select all, copy and post those messages here. Or, just to me in a PrivateMessage.
Old 08-31-2010, 11:36   #1705 (permalink)
Member: 219051
all sorted now working perfectly the TT to is upgrade and working like a charm
now what tomtom version can i put on my nokia n95 is there a tutorial somewhere for it??? thanks
Old 08-31-2010, 12:45   #1706 (permalink)
dsa8310's Avatar
Member: 973199
Great!
For n95, this is the wrong place...
Old 09-03-2010, 19:56   #1707 (permalink)
dsa8310's Avatar
Member: 973199
Link to EU8552885.dlc
Link to EU8552885.dlc:
EU8552885.dlc
It's Europe v855.2885, in three parts, parallel downloading at 2shared.com, meta.txt included, to download with JDownloader.
Old 09-03-2010, 20:14   #1708 (permalink)
Member: 228221
EU8552885.dlc
Is there IQR and ALG?
Old 09-03-2010, 20:30   #1709 (permalink)
dsa8310's Avatar
Member: 973199
I don't know, it's the only Europe available so far. Check it out, downloading from 2shared.com is really fast.
Old 09-03-2010, 20:35   #1710 (permalink)
Member: 1179032
EU8552885.dlc
the link does not work
TomTom v8 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 5948 03-31-2013 10:47
TomTom v7 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 3479 03-05-2013 21:55
how to install tomtom V6 software and maps on NAVMAN F20 sniper007 GPS devices , Navigators & Maps 4 11-06-2012 17:58
TomTom v6-7 and Route 66 v6 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4687 05-25-2012 15:52
Page generated in 0.37341 seconds with 12 queries
