Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #16 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Feb 2009
Member: 964688 Status: Offline Thanks: 161
| DSA, Quick questions: 1. I have the 8.370 NC on my GO920, patched by your tools. Now I want to try new NC 9, again, using your tools. Would you recommnend deleting any files from the TT device prior to another patching, or leave all as is and DSA tool will just replace the old files with the new?? 2. Can I still use your tool to patch TT home (how?)? Thanks a lot. |
| | #17 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 973199 Status: Offline Thanks: 204
| Quote:
2) YES. But first wait until TTHome downloads the new software for "Operate my GO". It is triggered at first click on the menu item. BUT, this software is not yet available - as you'd be notified by TTHome itself. Word of warning: it appears that external SD cards of 8GB capacity are NOT supported by the bootloader that comes along with NC v9.000.1637. So, BEFORE disconnecting device from PC, erase or rename the file named "system" from your 8GB storage, if that's the case. However, it is possible to return to the previous bootloader with dsa.exe, in case the bootloader has been already upgraded (to version 5.5256). The recipe is in my post #10. Bottom line, it is safe to upgrade to v9.000, I like it more than the v8 versions. | |
| The Following 2 Users Say Thank You to dsa8310 For This Useful Post: |
| | #18 (permalink) | |
| Crazy Poster ![]() ![]() ![]() Join Date: Mar 2009
Member: 995815 Status: Offline Thanks: 60
| Quote:
Will let you know what I find. Mathias, | |
| | #19 (permalink) | |
| Quote:
Mathias, | |
| | #20 (permalink) | |
| Quote:
I can get that indeed, your internal card (2GB, that is no greater than 4GB) supports the new NC v9.000. As I guessed, the problem stands with the external 8GB card that is NOT supported by the new bootloader ver. 5.5256 which landed on your device when first attempting the NC v9.000 installation. When it comes to installing the new NC on your (internal or external) device, the dsa.exe procedure is straightforward: 1) connect TT to PC; unmount (aka remove safely in Windows terms) the other storage you do not want to install to, if device is with both internal and external storage present. 2) select the source TT CAB with the leftmost open button of dsa.exe (e.g. NC9.000.1637.cab) 3) select either the x40 or L37 (the new lite mode that came with v9) radio button; recommended would be x40, but L37 is fine too. 4) check off the install box next to the big patch button; the target drive will be displayed below. The selection can be overriden by hand when wrong or absent. 5) click the big patch button and later on answer yes to install to TT. 6) disconnect/unmount/remove safely/ and let device start-up; that would be all. However, BEFORE letting the TT start-up, you may want to delete/rename the file "system" which contains usually a new bootloader if in doubt of its adequacy. In your case, to reenable a bootloader which supports external cards greater than 4GB in size, you should do what I have described in post #10. Install on the internal storage, of course, since the external 8GB one won't work until you patch back the last known to work bootloader, of version 5.5229, taken from the NC v8.560 cabinet - the file "system". Note also that dsa.exe (and dsa.zip) is the only tool able to downgrade a bootloader (provided that it is of version 5.xxxx), so you are quite lucky, after all | |
| | #21 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Feb 2008
Member: 715678 Status: Offline Thanks: 19
| I have installed the new navcore on my TT One but is it not working properly, it installs properly but when I turn on the devise it will stay on waiting to get a GPS signal and then shut off after about 30 seconds. |
| | #22 (permalink) | |
| Quote:
We could keep track of devices with issues by posting the first two chars of the device serial number. Just the first two chars only. For example, my device serial number starts with "V7" and is a GO 910 as one can see here: http://www.tomtom.com/products/maps/select.php in the "Which TomTom Device do I have?" area. So, what are the first two chars of your device serial? | |
| | #23 (permalink) | |
| Quote:
Device id is Z1 I reloaded the V9 navecore and now my device will just freeze and reboot. | |
| | #24 (permalink) | |
| Quote:
(reinstall with dsa.exe a v8 cabinet, or restore your backup as a last resort; by the way, the only thing a backup can NOT restore is the bootloader flashed on device - but, if necessary, that can also be done with dsa.exe, as described in my post #10) | |
| | #25 (permalink) | |
| Quote:
| | #26 (permalink) | |
| Quote:
(if you have used the latest dsa.exe, then it would be good to erase all four digit folders on device - like 8560, 8370, 8417, even the new 9000 - to save space and let the new memory savings algorithm kick in;; remove also the older dsa_navcore.xxx.zip packages too, they are next to the source cabinet files, and then rerun the dsa.exe installation, so that it effectively re-patches the v8 cab) Last edited by dsa8310; 10-14-2009 at 21:11. | |
| | #27 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Location: BiH Age: 46
Member: 37090 Status: Offline Thanks: 45
| Quote:
Is this tested enough? - playing with BL is not that funny game at all. | |
| | #28 (permalink) | |
| Quote:
![]() I have tested it on my own device, thoroughly. I jumped from 5.5229 to 5.5128, then 5.5120 and then back to 5.5229. I never post untested stuff. The easiest way to check out my patched "system" file, without involving the device itself, is to compare it to the back-up copy, named "system.orig" when patching with the same version number as in the original. They will be identical, and this proves that I know how to change the version number of a 5.xxxx BL file - and this is not a mere cut&paste game, as a naive user might think ![]() It seems (pending confirmation) that the new BL 5.5256 that came with NC v9000.1637 does NOT support SD cards bigger than 4GB in size, so for those who have already upgraded the NC together with the BL, my BL switcher looks like the only way to restore larger SD card support to their devices. Last edited by dsa8310; 10-14-2009 at 23:33. | |
| | #29 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008
Member: 818203 Status: Offline Thanks: 193
| Navcore 9.000.1637 Cab Here is the REAL Navcore 9.000.1637 CAB. http://download.tomtom.com/sweet/nav...navcore-GO.cab |
| | #30 (permalink) | |
| Quote:
(or vice-versa, if the human voice was enabled, select instead a computer voice, switch off and on and then retry the v9 installation). Who knows... | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TomTom v8 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 5948 | 03-31-2013 10:47 |
| TomTom v7 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 3479 | 03-05-2013 21:55 |
| how to install tomtom V6 software and maps on NAVMAN F20 | sniper007 | GPS devices , Navigators & Maps | 4 | 11-06-2012 17:58 |
| TomTom v6-7 and Route 66 v6 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4687 | 05-25-2012 15:52 |
