Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #3511 (permalink) | |
| Junior Member Join Date: Apr 2009
Member: 1009024 Status: Offline Thanks: 0
| Quote:
So I tried to upgrade with 8.398 and everything works now. So weird... So it's good ![]() Thank you. Just for my knowledge, what are the contents of /mnt/flash partitions ? Is the ttsystem copied on it or always used from HDD ? | |
| | #3512 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 973199 Status: Offline Thanks: 204
| Quote:
Code: ~ # /mnt/sdcard/extras/TTquickgpsfix/TTquickgpsfix-wrapper + [ -f /var/run/quick.dsa ] + touch /var/run/quick.dsa + cd /mnt/sdcard + ps + grep pppd + grep -v grep + [ -z ] + ln -sf /mnt/sdcard/extras/TTbtconsole/libbluetooth.so.2.11.2 /lib/libbluetooth.so.2 + true + strings /mnt/flash/settings.dat + sed -n s/.*\(..:..:..:..:..:..\).*/\1/p + sed -n s/aa:bb:cc:dd:ee:ff \(.*\)/\1/p extras/TTquickgpsfix/dun + channel=1 + [ -z 1 ] + extras/TTbtconsole/rfcomm bind rfcomm0 aa:bb:cc:dd:ee:ff 1 + pppd call ttgobuddy rfcomm0 460800 linkname dsa updetach ATZ OK at+cgdcont=1,"IP","APN" OK ATD*99# CONNECT Serial connection established. Using interface ppp0 Connect: ppp0 <--> /dev/rfcomm0 PAP authentication succeeded local IP address aaa.bbb.ccc.ddd remote IP address eee.fff.ggg.hhh primary DNS address iii.jjj.kkk.lll secondary DNS address iii.jjj.kkk.mmm + break 2 + wget http://home.tomtom.com/download/Ephemeris.cab?type=ephemeris&eeProvider=SIRFStarIII&devicecode=1 -O extras/TTquickgpsfix/Ephemeris.cab Connecting to home.tomtom.com[85.90.89.11]:80 Ephemeris.cab 100% |*****************************| 60414 --:-- ETA + mkdir -p ephem + extras/TTquickgpsfix/cabextract -d ephem extras/TTquickgpsfix/Ephemeris.cab Extracting cabinet: extras/TTquickgpsfix/Ephemeris.cab extracting ephem/packedephemeris.ee extracting ephem/ee_meta.txt All done, no errors. + /etc/rc.restartgps * Restarting GPS * Restarting GPS done + [ -s /var/run/ppp-dsa.pid ] + head -1 /var/run/ppp-dsa.pid + kill 833 + extras/TTbtconsole/rfcomm release rfcomm0 + die + rm /var/run/quick.dsa + exit ~ # The + prefixed lines are the executed instructions, followed by their respective output (not prefixed). | |
| | #3514 (permalink) | |
| Quote:
dsa-23May2012.zip (while I cannot delete it, it is automatically deleted after 30 days of inactivity) | |
| The Following User Says Thank You to dsa8310 For This Useful Post: |
| | #3515 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 979804 Status: Offline Thanks: 87
| ot: battery replacement tt720 it seems my battery 'had it', after o/night charge from main charger it only lasts literally minutes, any tips, do or don't for battery replacement? I see them listed on **** around $15/20, if anyone has any advice/suggestion please let me know if I don't replace battery, just relay on external power, are there any downsides ? thanks |
| | #3517 (permalink) | |
| Quote:
| | #3520 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 283999 Status: Offline Thanks: 163
| TT don't list every 'phone that is made. That doesn't mean that their data is unreliable only that they haven't tested it yet. If your 'phone isn't listed then it isn't in their data base to be unreliable. If it is in their list of tested 'phones and they said a feature would/wouldn't work and you found that it didn't/did, then you could say their data was unreliable. Obvious really. |
| | #3521 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2009
Member: 1177877 Status: Offline Thanks: 59
| I'm looking for some sounds of nav 9430 called warn1, warn2... warn7 they exist when you change the sonund of radar but it doesn't exist in the folder sound where i have to look for this files ? thanks !!! |
| | #3524 (permalink) |
| Anyone could check things out, using the BT Console with a v9.430 kernel. Execute: # ln -sf /bin/busybox /sbin/mkswap # ln -sf /bin/busybox /sbin/swapon # ln -sf /bin/busybox /sbin/swapoff # dd if=/dev/zero of=/mnt/sdcard/swap bs=1024k count=16 # mkswap -c -v1 /mnt/sdcard/swap # swapon /mnt/sdcard/swap If no error after the last command, then swapping is enabled in the v9.430 kernel. Let me know if that's the case, though I doubt it... |
| | #3525 (permalink) | |
| Major Poster ![]() ![]() Join Date: Jun 2011
Member: 1594667 Status: Offline Thanks: 20
| Quote:
Could someone else with access to the console try those commands on a recently published v9 Navcore? Regards and thanks, ahkp3 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TomTom v8 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 5948 | 03-31-2013 10:47 |
| TomTom v7 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 3479 | 03-05-2013 21:55 |
| how to install tomtom V6 software and maps on NAVMAN F20 | sniper007 | GPS devices , Navigators & Maps | 4 | 11-06-2012 17:58 |
| TomTom v6-7 and Route 66 v6 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4687 | 05-25-2012 15:52 |
