Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #3871 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 973199 Status: Offline Thanks: 204
| Quote:
echo echo -n "Self is " cat /proc/barcelona/modelid echo Then check file log in the root of storage. | |
| | #3872 (permalink) |
| Oh yes, sound=1 means answer with Self to the first reading of modelid (don't use it!); sound=2 means answer with Self to the second reading of modelid; and sound=3 means answer with Self to the third reading of modelid. Other values won't matter. |
| | #3875 (permalink) |
| Yes, thanks. Nonetheless you could give another try to your loquendo issue: put sound=0 to avoid any interference (or don't use the sound parameter at all, it's the same, I think). BTW, code is in file dsa.app/Contents/Resources/Java/firmvare/dsa.c - with lines commented out activated in the root dsa.ko module. |
| | #3876 (permalink) |
| Updates: dsa-23August2012.zip ttn.zip dsa-23August2012.zip is identical to dsa-22August2012.zip with the exception of file dsa.c (source). This ttn.zip has got a better coded dsa.ko, and contains its source dsa.c too. |
| | #3877 (permalink) |
| Please DISREGARD links in post #3876 above. Here are updated links: dsa-23August2012.zip ttn.zip Both have improved dsa.ko (and source). |
| The Following 6 Users Say Thank You to dsa8310 For This Useful Post: |
| | #3878 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: The Netherlands
Member: 1431396 Status: Offline Thanks: 64
| Bravo! It's a miracle!! With dsa-23August2012 you solved the LIVE-subsciption and Loquendo problem on the XL LIVE IQ Routes device!! I patched the device the same way as before with SLF and 36-XL LIVE modes using the 9.430.2-2008.le.CAB-navcore-LE cabinet. I'm just waiting on the LIVE-services password to do some advanced tests. You definitely changed something important in the patching method, but what? BTW: I didn't set any sound parameters in neither the new dsa.c and ttn. Do you want to test me with the sound parameter? Last edited by keessie74; 08-24-2012 at 11:51. |
| | #3881 (permalink) |
| I am glad it's sorted out. But there was no miracle, just a sloppy implementation of the older dsa.ko... Previously, I was creating extra entries in the proc filesystem which were duplicates of the originals, but writable, which allowed me to overwrite parameters such loquendo, modelid, etc. My duplicates were placed before the originals and so they were taking precedence over them, and all seemed OK. Unfortunately, in reality, access to proc might have been optimized, in that the search for a parameter (like loquendo) could start not from the beginning but from the last accessed position, and this could be beyond my parameters; as a result, the return could have had the original value, not patched... Now, there are no more duplicate entries, because I simply overwrite the read/write functions of the existing, unique entry of each parameter (of interest), with my own functions (actually coded as before) which make the entry writable, aka patchable. I have also taken care of the eof (end of file) status, updated correctly now (before it was ignored) which has eliminated multiple unnecessary accesses, and helped me to determine that there are only three readings of modelid, etc. Finally, the original parameter values are copied internally during module initialization, as it should have happened in the first place. I could infer that there are other devices which would benefit from this dsa update, perhaps in the very same area of the computer voices (loquendo), so dsa-23August2012.zip from post #3877 is a mandatory upgrade. --- Now, about ttn: it contains an extended dsa.ko kernel module with one parameter, named sound, which works as described in post #3872. My hope is that by answering with self to the second or third inquiry about the value of modelid, that value would be used for setting out the device sound. It might not be the case at all, but using dsa.ko for patching the sound, instead of HS, would be so nice... (first modelid reading is for skins, but it might be used for sound too, in which case HS is the only solution - many thanks again to rickgtx for its invaluable contribution!) |
| The Following User Says Thank You to dsa8310 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TomTom v8 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 5948 | 03-31-2013 10:47 |
| TomTom v7 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 3479 | 03-05-2013 21:55 |
| how to install tomtom V6 software and maps on NAVMAN F20 | sniper007 | GPS devices , Navigators & Maps | 4 | 11-06-2012 17:58 |
| TomTom v6-7 and Route 66 v6 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4687 | 05-25-2012 15:52 |
