Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-04-2013, 09:19   #4321 (permalink)
Member: 1757151
It can be a lower version: bootloader (system) 5.5022 and higher support SDHC.
Old 01-04-2013, 09:24   #4322 (permalink)
dsa8310's Avatar
Member: 973199
Originally Posted by garcad View Post
dsa8310 would be possible to create a PDA-PNA navcore senior of v.79.xxxx
greetings and happy new year
I did not understand what versions you are looking for, but a happy new year to you too.
Use dsa with the latest NC (v9.700) on any non v10/11/12 device.
Old 01-04-2013, 19:14   #4323 (permalink)
Member: 1431396
Originally Posted by omolino View Post
This will be easy (not for me)
Create and scrit that erase settings.dat, at the root and make a restart of the device.
but you lost your last configuration...
maybe is better an original settings.old (with your configuration) and copy to settings.dat at the moment of restart.
Removing settings.dat and currentmap.dat doesn't result in asking for a vehicle profile again after reboot. What Downunder35 said is true: only after reskin with Skin Chooser a new vehicle profile will be asked.
It should be nice if a copy of SkinChooser could be used as an icon in SdkRegistry wihtout really reskin it so without showing the graphical stuff (like
calibrating and skin choose but with the reboot at the end).
I tried some things like:
#!/bin/sh #
killall ttn 2>/dev/null
while [ -n "`pidof -s ttn`" ]; do true; done
echo "V" >/dev/watchdog
killall mp3d clmapp ttpnpd ttsserver launchserver 2>/dev/null
mount `mount | sed -n 's|\(.*\) on /mnt/sdcard.*(..,\(.*\))|\-o remount,rw,\2 \1 /mnt/sdcard|p`
rm -f /mnt/sdcard/settings.dat
sync
sync
/sbin/reboot
But of course this didn't work (LOL ). Just tried to using the Skinchooser code with calling 'fb', ts-calibrate' and 'skin'. I presume some crucial code in the other bits of 'fb'/'ts-calibrate'/'skin' are mandatory.
Maybe dsa8310 could push me in the right direction?
Old 01-04-2013, 19:40   #4324 (permalink)
omolino's Avatar
Member: 1177877
Keessie :
I'm very interesting in this because i have a ONE V6 and DON'T WORK in x30 skin (in this skin have a way to change the truck ) i only can start in 34 and can choose ONLY the first time but no more...
IDEAS : what about a folder named fleetecd, are there some scripts that maybe can change the truck
fleetec-ppp.sh
ttwd.sh
can be ussefull ? i
Old 01-04-2013, 19:42   #4325 (permalink)
dsa8310's Avatar
Member: 973199
Simply switching to another mode by changing file skins/reskin could be done as in the Restart menu item.
But, hey, this is why Skin Chooser was made in the first place, wasn't it?
My advice: select all skins, or go skins, or a few skins of interest at dsa run, and use Skin Chooser to flip between modes if you really want to reconfigure your truck NC. After all, the time consuming reboot phase is unavoidable.
I may add that reverting to factory default might help too, albeit some things will be lost.
Old 01-04-2013, 19:49   #4326 (permalink)
Member: 1431396
Yes, but in x40 I don't want to really switch the mode but only the side effects. So switch from x40 to x40 with reboot so at boot there will be asked for a vehicle profile. A switch from x40 to x40 will not trigger anything.
EDIT: Yes, a factory reset helps too, but a lot of work to configure anything again.
Old 01-04-2013, 20:09   #4327 (permalink)
dsa8310's Avatar
Member: 973199
Yes, go x40, x30, and back to x40....
And if there ain't other bootable modes available, try factory default, or search harder for another bootable mode with access to Skin Chooser.
Old 01-04-2013, 20:16   #4328 (permalink)
Member: 1431396
Keessie :
Really? You should be able to choose a skin which you have selected at DSA install (you know you could select multiple skins at install). As far as I concerned all skins should be available when eventually running up.
Old 01-04-2013, 20:53   #4329 (permalink)
dsa8310's Avatar
Member: 973199
As a matter of fact, there is another file settings.dat that could be edited or deleted (not on the main storage). Deleting it would probably be equivalent to factory default. Editing it would require a study of its format, hopefully not very complicated. But I don't have my device at hand. BT Console helps with the task.
Old 01-04-2013, 21:02   #4330 (permalink)
dsa8310's Avatar
Member: 973199
I have recently become aware that there is some interest in improving dsa or at least its GUI.
So feel free to go ahead and make some terrific skins for dsa (the app), and/or push it to its limits!
Old 01-05-2013, 00:36   #4331 (permalink)
Member: 1528218
For the vehicle profiles I have a few things I suggested in the past to other users first:
a) on GO models use one verion internal, one on SD - remove the SD to "switch"
b) do a full reset to get the profile selection back, but have not checked if that is still working on the new NC
As for modifications: I don't think it is not necessary to make changes to DSA just to get the profile selection working, the tool works geat as it is now.
A better way (for the Linux Freaks here) would be to compare this NC to the 9.004 as there you have the vehicle profiles permanently in the menu.
It might be a very simply thing that "turns off" the menu icon for it in the Truck NC, and it should be possible to find this bit of code in the 9.004 and apply it to the 9.7
Old 01-05-2013, 01:11   #4332 (permalink)
Member: 1431396
I doubt it because I think its hidden deep down in ttsystem and nearly impossible to disassemble that.
Verstuurd van mijn GT-I9100G met Tapatalk
Old 01-05-2013, 05:31   #4333 (permalink)
Member: 1528218
But I don't really understand the fuzz about the profiles as with the standard patched cab and the DSA version I have "Edit Vehicle profile" on page one of the preferences.....
So maybe it should in the same place if X20 or X30 emulation is used in DSA?
If not either you are doing something wrong or use the wrong EMU I would say...
Old 01-05-2013, 11:44   #4334 (permalink)
Member: 1431396
Don't understand me wrong, I appreciate your ideas. In x30 mode (on my GO 740) I have this possiblity on page 3 or 4 in the preferences which I had missed before. After all, for the one time I need to switch the profile I will going to swith to x30, change the profile and switch back to SLF (x40). For Omonilo with his One v6 I hope he finds the Change vehicle profile somewhere in one of the available skins.
Old 01-06-2013, 02:18   #4335 (permalink)
omolino's Avatar
Member: 1177877
keessie: When i did the new rute the navcore ask me about the vehicle and then i can change it !!! Good news
http://i56.tinypic.com/15eisf7.jpg
DSA: Something strange when you test the original CAP, then then the navcore shows 2 panels status bar at the old way but if you do a DSA nav then it have 3 like the news 9
i think this is because you use the kernel 9 and works but the real 9700 nav have only 2
TomTom v8 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 5948 03-31-2013 10:47
TomTom v7 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 3479 03-05-2013 21:55
how to install tomtom V6 software and maps on NAVMAN F20 sniper007 GPS devices , Navigators & Maps 4 11-06-2012 17:58
TomTom v6-7 and Route 66 v6 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4687 05-25-2012 15:52
Page generated in 0.36942 seconds with 12 queries
