Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-06-2013, 11:17   #4336 (permalink)
Member: 1709150
Is there a version of this 9700 truck navcore for 32mb TomTom ONE that allows the use of computer voices? I have the 32mb version running with 11mb free memory, but when choosing a computer voice the unit remains silent. Any suggestions gratefully appreciated.
Old 01-06-2013, 12:40   #4337 (permalink)
dsa8310's Avatar
Member: 973199
Try using HS and K50 combined with this LoquendoTTS.zip unzipped to your storage.
Seek further advice from ONE owners.
Old 01-06-2013, 14:15   #4338 (permalink)
Member: 1431553
Originally Posted by omolino View Post
DSA: Something strange when you test the original CAP, then then the navcore shows 2 panels status bar at the old way but if you do a DSA nav then it have 3 like the news 9 i think this is because you use the kernel 9 and works but the real 9700 nav have only 2
I've tried patching DSA NC 9700, with and without K50 is always in two panels.
All through 9700 .Cab made ​​by dsa8310
How do 3 panels?.
Thank you and greetings.
Old 01-06-2013, 15:38   #4339 (permalink)
Member: 1709150
@dsa8310
Thanks for the reply, I have now tried that option but without any success. I guess I will have to stick with the recorded voices. The navcore does run smoothly on the TomTom ONE though with free memory varying between 7mb and 11.9.mb as far as I can tell
Old 01-07-2013, 01:45   #4340 (permalink)
Member: 1431396
Good news. With x50 skin it is possible to change to vehicle in the preferences. So I leave my x40 device in x50 emu.
Verstuurd van mijn GT-I9100G met Tapatalk
Old 01-07-2013, 09:28   #4341 (permalink)
Member: 1864490
Originally Posted by dodahday View Post
@dsa8310
The One with 32MB ram is not made for use with computer voices.
But you can alway,s can give it a try. It runs acceptable on my one.
*One TTS*
Old 01-07-2013, 12:09   #4342 (permalink)
Member: 1150704
TomTom GO 700!
Hi!
I've downloaded the latest dsa tools package to update my friend's Tom Tom Go 700, and I'd like to get it working with the dsa tool as my head's been going round and round for hours in a frustrating series of reboot loops, white and black screens of death, gibberish tiddly white writing and even a big white cross on a black background!!!
1) Can 9.465 Navcore be used in the GO 700? - if so can someone post a link to the recommended one please?
2) What emulation is recommended for the 700 series that will give the best speed/features?
3) I've got the BBC Radio 2 voices and copied them to the voices folder on the TT but it refuses to recognise them - both the GPS Underground Forum and the Charity CD I bought state they don't need activating - what might be wrong?
Many thanks,
Chris Williams
Old 01-07-2013, 13:01   #4343 (permalink)
Member: 1150704
DSA Tools repeatedly fails!!!
Hi
I've just tried running the latest dsatools package and the installation/patching routine is a complete failure with error messages such as
"fatal error - couldnt open cabextract - failed to open signal pipe for forked process - Windows error 461 - hangup 3598 etc., and I get a long series of almost identically-worded messages related to similar other files
before it finally bogs out with "Failed" on the interface screen!
All these files are present in the dsa program files folder, so why is the dsa tool failing to execute?
I've used the latesr available Java Runtime from the dsa's instructions page, and followed the instructions to the letter - its almost two years since I used dsa tools, but I don't remember having this problem before - the patch button both installed and patched the navcore correctly!
Can Member dsa8310 shed any light on this please?
Chris Williams
Old 01-07-2013, 17:43   #4344 (permalink)
dsa8310's Avatar
Member: 973199
You must first follow the dsa installation procedure to your PC, as described in the ReadMeFirst.html file.
Start by unzipping dsa-2December2012.zip to the Desktop. Then enter folder Desktop\dsa.app and start (double click) the dsa.msi installer within, etc.
Go 700 should work well, even with CF and MB enabled, with the latest NCs, v9.485 or even v9.700 from post #4297; select the usual GO modes, Self included. You probably won't need HS, and K50 is enabled by the CF&MB combination on a v9 NC.
If however things still aren't OK with the dsa installation, switch to a different Windows/PC, use a Mac or a Linux machine...
The Following User Says Thank You to dsa8310 For This Useful Post:
Old 01-07-2013, 23:51   #4345 (permalink)
Member: 979804
trying to install 9.700 as follows:
specified FQFN with/without '.cab' extension, but, get this:
C:\Documents and Settings\voyteke\Local Settings\Temp\9.700
C:\Documents and Settings\voyteke\Local Settings\Temp\9.700.cab
Directory of C:\Documents and Settings\voyteke\Local Settings\Temp
08/01/2013 10:35 AM 60,002,201 9.700.cab
1 File(s) 60,002,201 bytes
Windows
Fetching , please wait.
No file available. Aborting.
is my dsa version too old ?, have dsa-18November2012
Old 01-08-2013, 00:43   #4346 (permalink)
Member: 1528218
Do you have the Cab file stored under the same name you used for adding to the cabs.txt for DSA??
The Following 2 Users Say Thank You to Downunder35m For This Useful Post:
Old 01-08-2013, 03:54   #4347 (permalink)
Member: 979804
I do. (now...) and, it's working, thanks !
patched, thanks
butis this a problem?
No 9-700-1133776-1.win.2.2.xpi file available.
Old 01-08-2013, 06:45   #4348 (permalink)
Member: 1528218
There was never a Home DLL available for the Truck NC, so you won't get it for the new NC either
Old 01-08-2013, 07:17   #4349 (permalink)
dsa8310's Avatar
Member: 973199
The 9.700.cab file should be opened with CAB/Open/Return regardless of its location.
But, if you place it in the same folder where the other cabinets are downloaded (folder that holds file cabs.txt after dsa installation to PC), then you may add it as an entry to the list of cabinets too (either by editing file cabs,txt offline or by editing any cabinet list entry while running dsa - to the short name 9.700.cab).
Old 01-08-2013, 19:04   #4350 (permalink)
Member: 1709150
@holyheadx
Thanks for that file, it works a treat.
Unfortunately this navcore and v901 map still wants to send an 11' wide truck down an 8' wide lane. Pointless sending the info to TomTom though as they never take any notice of the corrections that I have sent in.
TomTom v8 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 5948 03-31-2013 10:47
TomTom v7 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 3479 03-05-2013 21:55
how to install tomtom V6 software and maps on NAVMAN F20 sniper007 GPS devices , Navigators & Maps 4 11-06-2012 17:58
TomTom v6-7 and Route 66 v6 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4687 05-25-2012 15:52
Page generated in 0.41897 seconds with 12 queries
