Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #4352 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 973199 Status: Offline Thanks: 204
| Start with post #4244, then look for v900 maps here: TomTom 900.XXXX Maps The latest v9.700 navigation cabinet is in post #4297. |
| | #4356 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Oct 2009
Member: 1145396 Status: Offline Thanks: 1
| Happy new year to all. I discovered that, when my GO 910 re-boots for any reason, there is an infinit re-boot loop.... When I connect my GO via the USB cable to my PC, and i rename the directoty containing the map, when the GO reboots, a map selection appears on the screen and if I select the WCE map, the GO starts normaly and the navigation is anable again. The DSA tool is from the 8th november 2012 with K50 and X40 and the NC is V 9.160. If i connect my GO on my PC, TThome starts and when MAPSHARE is performed, I have to rename the directory of the map before re-booting the GO!.... What can I do to fix the problem? I use NC V 9.160 to anable RDS-TMC to work on my GO 910 in X40 emulation to get the voice control. Thanks in advance for your help. |
| | #4357 (permalink) |
| Happy new year to all. I discovered that, when my GO 910 re-boots for any reason, there is an infinit re-boot loop.... When I connect my GO via the USB cable to my PC, and i rename the directoty containing the map, when the GO reboots, a map selection appears on the screen and if I select the WCE map, the GO starts normaly and the navigation is anable again. The DSA tool is from the 8th november 2012 with K50 and X40 and the NC is V 9.160 and the map is WCE 895.4438. If i connect my GO on my PC, TThome starts and when MAPSHARE is performed, I have to rename the directory of the map before re-booting the GO!.... What can I do to fix the problem? I use NC V 9.160 to anable RDS-TMC to work on my GO 910 in X40 emulation to get the voice control. Thanks in advance for your help. |
| | #4358 (permalink) |
| This is what I usually do with my own go 910: 1- first of all, get the newer dsa-2December2012.zip file from post #4244. 2- when getting a new map (BTW, v900 maps are available) I transfer the old mapsettings.cfg file to it, then I connect to TTHome/Operate my Go and I make a fake edit of any of the favorites. A go around this issue would be transferring all the favorites into a POI file - one by one - then removing all favorites. 3- since I use the CF flag, I get the currentmap.dat file deleted automatically at each cold boot, and because I always keep at least two maps, the map selection screen appears - which slows down things properly for my SSD/CF storage. A regular go 910 with HDD does not need it, but it could be enabled in file skins/ttn - see posts #4247 and #4248. Try only 1 & 2, you don't need 3. Last edited by dsa8310; 01-15-2013 at 12:29. |
| | #4359 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011
Member: 1528218 Status: Offline Thanks: 37
| Would a faster CF card help or is that a general problem of adaptor use with a CF? Only asking as I recently bought a bigger CF for my camera and noticed that multishots are not only a little bit faster but also that the cam takes now 7 pics instead of the 4 I got before. From memory I know the original HDD TT used was not really what you could call fast, compared to modern flash media. |
| | #4360 (permalink) |
| I really don't know. Could be at driver level. Every single time I put back the HDD instead of a true SSD and later a CF card with adapter, all issues disappear... And the extra SSD/CF configurations which take advantage of the faster storage (see file skins/ttn with CF enabled) don't make any difference with or without. That is why I make the trick with two maps and deletion of file currentmap.dat, and I use the special most compatible v9 kernel. But no need of anything if the HDD is in place... (except for the mapsettings.cfg transfer between maps, which should be handled as suggested above) I also believe that v8 kernels are OK (with SSD/CF), and that trouble started with the v9 and v8-v9 transitional kernels. |
| | #4361 (permalink) |
| @dsa8310, Thank you for your answer, I will use your recomandations to see, if that help me not to use my iphone to guide me when my TOMTOM GPS re-boots because it's endless, and I don't have PC in my car to rename the directory map to restart the map selection process at re-boot. I am very surprised to be alone to have this problem on earth! Thanks again. I will give you the result after applying your recomandations. |
| | #4363 (permalink) |
| Another tip: restart your go 910 while NOT put in the live cradle (fed with DC). After reboot (and eventual map selection), then connect it to the cradle. I actually wait until I get to the initial screen. Same rule when switching it on (hibernation wake-up): first switch it on, and only after a few moments put it in your car cradle. (extra precautions could be necessary because of my CF card though) Last edited by dsa8310; 01-15-2013 at 21:08. |
| | #4364 (permalink) |
| Link to the official 9.700 Truck : Click here |
| The Following 3 Users Say Thank You to Downunder35m For This Useful Post: |
| | #4365 (permalink) | |
| Quote:
9.700.go_work.CAB-navcore-GO-WORK.cab (that is odd, content identical to what had surfaced earlier...) | |
| The Following User Says Thank You to dsa8310 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TomTom v8 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 5949 | 06-12-2013 03:17 |
| TomTom v7 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 3479 | 03-05-2013 21:55 |
| how to install tomtom V6 software and maps on NAVMAN F20 | sniper007 | GPS devices , Navigators & Maps | 4 | 11-06-2012 17:58 |
| TomTom v6-7 and Route 66 v6 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4687 | 05-25-2012 15:52 |
