Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #1 (permalink) |
| Junior Member Join Date: Jun 2006
Member: 287760 Status: Offline Thanks: 1
| Garmin Mobile XT for Windows Mobile v5.00.20w Updated 25th Sept 08 Garmin Mobile XT for WindowsMobile V5.00.20wp Requirements: Windows Mobile 2003/SE/WM5/WM6 PocketPs with GPS receiver Overview: Add full-featured navigation to your GPS-enabled smartphone with Garmin Mobile XT. Just plug this data card into your compatible phone¹ (see specs tab) and start navigating. With no monthly fees, preloaded maps, turn-by-turn directions, real-time services and only $99, this easy-to-use data card has everything you need to navigate to the front door. ![]() Changes made from version 5.00.10 to 5.00.20: Update the subcategories listed for City Navigator Europe 2009 maps. Correct various out of memory conditions that can occur. Correct the processing of a received Location Message to not save the point on the Recent Finds list. Correct the processing of received text messages to not close the GMXT application when a text message is received without a subject. Correct an error that occurs when a headset is plugged into some devices. Correct the use of the directional pad for movement between hyperlinks within Flight Status. Correct saving and editing waypoints with non-English characters. More Info: Code: http://www8.garmin.com/support/colle...t=010-00579-00 Download Instructions: All credits for the keygen go to JetMouse, as well as Lord Yuz and starix who helped with the creation of the keygen. Code:Installation procedure: a) Start installation of 'GarminMobileXTforWindowsMobile_42020w.exe' from PC through ActiveSync. Select your Storage Card as destination. During the installation, files will be copied to your storage card. The files should appear in '\Storage Card\Garmin\Apps\WM'. b) Install 'GarminMobileXTSupportFiles_4xxxx.exe' for voice files. c) Install 'GarminMobileXTFreeBasemap_4xxxx.exe' for Garmin's base map. d) Run GarminMobileXT and record the Unit ID and use keygen to create unlock key. e) Save as sw.nl file. f) Copy 'sw.unl' to '\Storage Card\Garmin'. Installation procedure: For previous version user just install over the previous version.... a) Start installation of 'GarminMobileXTforWindowsMobile_42020w.exe' from PC through ActiveSync. Select your Storage Card as destination. During the installation, files will be copied to your storage card. The files should appear in '\Storage Card\Garmin\Apps\WM'. b) Install 'GarminMobileXTSupportFiles_4xxxx.exe' for voice files. c) Install 'GarminMobileXTFreeBasemap_4xxxx.exe' for Garmin's base map. d) Run GarminMobileXT and record the Unit ID and use keygen to create unlock key. e) Save as sw.nl file. f) Copy 'sw.unl' to '\Storage Card\Garmin'. Garmin Mobile XT Free Basemap, Ver. 4.xx.xx Code: http://www8.garmin.com/software/Garm...emap_4xxxx.exe Garmin Mobile XT Support Files, Ver. 4.xx.xx Code: http://www8.garmin.com/software/Garm...iles_4xxxx.exe Updated Version 5.00.20w as of Sept 25, 2008 http://rapidshare.com/files/154764026/GarminXT_5.00.20w.rar.html http://www.sendspace.com/file/ig3low |
| The Following 7 Users Say Thank You to Molorola For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Garmin Mobile XT for Symbian S60 3rd Edition software version 5.00.10 | angelvasmil | Nokia Multimedia | 0 | 11-06-2008 09:50 |
| Garmin Mobile XT for Windows Mobile v5.00.10w with Keygen | Molorola | GPS devices , Navigators & Maps | 0 | 09-26-2008 03:12 |
| Garmin Mobile XT for Windows Mobile? | ewok666 | Nokia Multimedia | 1 | 04-13-2008 05:10 |
| [REQ] Route 66 Mobile 7 for Windows Mobile Smartphone | fakoly | GPS devices , Navigators & Maps | 2 | 11-02-2006 06:01 |
