Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 05-29-2008, 03:05   #1501 (permalink)
Member: 321113
Well jst to thanks the guys who helped out in teaching how to install and find maps. I was in brunei, we kinda got lost and without the maps on the Nokia e90 I think we would have been seriously lost, apparently we were heading towards the opposite direction for 20 mins! cos the GPS could not get a fix.
Anyways while I have the borneo map, I'm now looking for one with Sabah, the map I have only got Sarawak & bRunei. I'm going to Sabah in about 3 weeks time and as far as I can tell no roads there ! *gasps* helps! been searching malsingmaps forum but I cant make head or tail of it. they seem to speak in a language i cant understand.
Old 05-29-2008, 09:26   #1502 (permalink)
BuMobiles's Avatar
Member: 503346
Originally Posted by zeely9599 View Post
Hi
It would be much appreciated if i can get Garmin speed camera database for the UK? and how to use the POI loader to install it?
thanx a million in advance
they are out there just need to search for them
The Following User Says Thank You to BuMobiles For This Useful Post:
Old 05-29-2008, 13:02   #1503 (permalink)
Member: 433671
Just go to malsing maps, download section, and download their 2.15 version of map (Jan 2008) for borneo. It is not locked, and just need to be installed to be used.
Old 05-29-2008, 22:23   #1504 (permalink)
Member: 782725
Hi, I am from Uruguay, and I have nokia E65, just bought Nokia BT receiver, and I need the Garmin Mobile XT cracked to connect with my nokia BT receiver. I can not find the links on this post, would you help me please?
thx
G
Old 05-30-2008, 05:47   #1505 (permalink)
Member: 433671
From Garmin direct:
http://www8.garmin.com/support/colle...t=010-11034-00
Keygen etc can be found above...
Old 06-01-2008, 03:05   #1506 (permalink)
Member: 271255
OK, I have spent nearly eight hours today trying to get this to work. First I tried the 60 FW thru Torrent and it took most of yesterday to download. I found out I didnt need the Euro stuff ( i live in Colorado). The Sys file seems to want to open in my Windows Media player, at least thats the Icon that is attached to it. I have tried others to open it, but they wont; so I know thats a problem there: perhaps I am lacking the app to open this app; I dont know. Why it automatyically attached itself to wmp I dont know, but I suck at software.
Then I tried to move it thru my Nokia PC Suite and the Install Application section, but it would not move the folders.
Then I tried the guys links from page 99 or 100, the one written in blue on blue. Now on those I tried to put them thru my card reader and it wouldnt let me. Then I tried to put my n95-3 on usb rather that pc suite and went in the order he suggested.
1st the Support file download
2nd the Basemap Download
These bot showed a Garmin screen and asked me to choose where it was going and it only showed "h" which I assumed was my usb into the N95. Both of those downloads seem to load fine.
However the 3rd download (Symbian Updates and Downloads) did not show me the same screen the first two did. It didnt ask where i wanted to download, it just started downloading it, but noting appeared in the folder, on the phone, or anywhere else that i can find on my pc or phone! Then I thought it may be that "Hidden file" problem, I went back and made sure that was unchecked and the other uncheck hidden file item above it ( I didnt mention I have windows 2000 Professional). But that didnt work either.
Then I tried to Download it into my pc using the "Extract Here" option when I right clicked the zip file. Finally a few folders appeared including a "Setup" file with what i hope is the Garmin logo. But when I clicked on that, I see the hour glass for 1/2 second and it goes away and nothing hapens!
I'm ready to throw this computer out the window! I am an "OLd School" Cellular guy in the Biz 15 years but this Software SH** drives me nuts! I can disassemble any phone, I've brought back and saved phones that were dropped out of cars on highways and run over and in Jacuzi's for two hours, but I am having the hardest time with all this software, but I know I need to understand it to stay in my profession. So Someone please give me a link to software downloads I can use. I believe the ones the above guy gave were for if you wanted to do an upgrade, not to install on a virgin N95-3 with no Garmin at all. I dont know if its important or not, but I did do the new FW update thru NSU and it went fine. Someone PLEASE help; I can offer almost any kind of hardware help you may need in exchange for step by step directions as if you were explaining it to a mentally challenged Monkey; if it is successful, I can help you out in many ways...Thanx in advance!!!!!!!
Old 06-01-2008, 05:11   #1507 (permalink)
Member: 433671
Back to simplified installation:
Navigate here:
Download:
1) Garmin Mobile XT for Symbian (th program)
2) Garmin Support Files (Voice etc)
3) Garmin Basemap (Map)
Connect phone to PC
Run the first program on PC. After the first, you will get a prompt on phone to permit installation of Garmin. Accept it, and when it finishes, run the next two on PC.
At the end of this, the program will be installed on phone.
Start Garmin on phone. Ignore trhe unable to find GPS receiver. Go to Settings>About, and copy down the Card ID.
This Card ID is also your Device ID, and is used by the keygen to unlock the program and also maps.
Get jetmouse's keygen (and if needed the IMEI converter)
Generate your unlock key. Save it in a file named sw.unl. Send this file to your phone in the Garmin folder.
Program will now be unlocked. It'll allow you to select the internal or bluetooth GPS receivers.
Once this is done, then work on the map(s).
Old 06-01-2008, 05:51   #1508 (permalink)
Member: 271255
[quote=Ozling;3362146]Back to simplified installation:
Navigate here:
Download:
quote]
Ok are you talking about this one:
Garmin Mobile XT for Symbian S60
Because I dont see one with "th program"
On a seperate note I finally got one to download, but it wasnt off this page. For what ever reason, it didnt work. But now the Code generators code doesnt work to unlock the maps, maybe I need to do the first unlock? I'll try that now, If it doesnt work, I'll erase everything. reset the phone (*#7370#) and thry that file again. I must have 5 or 6 of these Garmin files on my PC now..I'm thinking I may need to delete all those to. I'm staying here(My Store) until I do it. Thanx.
Old 06-01-2008, 05:55   #1509 (permalink)
Member: 271255
This is another problem; Where exactly is this File? Am I looking in the garmin foldes on my sd card? On my PC in one of the files I downloaded?
Old 06-01-2008, 06:11   #1510 (permalink)
Member: 271255
Ok, I just deleted everything and I'm starting over> I went to the link above and downloaded the one I highlighted right above this post. But even the Garmin messages on that Download say it is only an update and not the real program as someone else on here pointed out...It seems to me it need s to be attached to a full program..but I'm gonna follow what you say verbatum.
Old 06-01-2008, 06:38   #1511 (permalink)
Member: 271255
Ok, when I click on the Zip file it asks me if I want to set up and I say yes..or what ever the command is. It goes thru a series of bars as if its downloading some place, but nothing is promted on my phone, nothing shows in that file on my PC, nor the file above it. It disappears. Somewjere theres about ten of this just sitting there, but where, I havent a clue.
Anyway, I then Decided to open it up using WINRAR a file thingy I got a while ago. at least with that it opens up in front of me in a separate window. I went down to the EXE apressed it, but it downloaded to that black hole i guess.
The I decided to use the EXTRACT button up top. It gave me a choice of where I wanted to extract it to, And I chose my "H" file, which is my USB to my phone in this computer. That took much longer to do, and It did doit. Whether or not I can open it is another issue. Now I'll try the next step.
BTW, I never did get a prompt on my phone either, but the file is there. I think because in this USB mode on the Nokia, It doesnt recognize anything going on with the SD card until the usb is unplugged..I'm not sure about this, just a theory as to why it didnt offer a prompt.
Old 06-01-2008, 07:05   #1512 (permalink)
Member: 271255
Ok on the second file it did the little setup thing first and then opened up the Garmen XT Mobile set up as it did the last time. I also just found where those missing files are going. They are put in a separate folder on the main drive folder(in this case its my E Drive) in a folder marked "For Symbian" ; but I'll leave them be for now. Just as a reminder, I am using Windows 2000 Pro. If that matters.
Ok the third file went as easy as the second one. I forgot to mention, you do have to highlight the acceptable drive the Garmin setup finds or it wont Illuminate the Install button. Very basic, but It stumped me for about 5 minutes.
Ok, so everything is on my Micro sd card now. When I pulled the USB nothing happened like before when it was half installed. I then went int othe folder thru the phone and it wouldnt open the program, mainly because it still wasnt set up. So I tried to push the setup.exe and it said it didnt recognize the program. Then I rehooked it back up through my pc and went thru my PC into the H drive wher the USB is hooked up, and once again it wont open it. Th e60 fw link givin back around page 85 or so did download the program into my phone, but I thought this would be more complete, but I'm fairly convinced, this program is just what it says, and upgrade to an existing program and cant be used as the original. It just took me three hours to confirm that. Hopefully I can bring back the old one from my recycle bin and work from it. It also may have something to do with my W2K OS. but thanx anyway.
Old 06-01-2008, 07:23   #1513 (permalink)
Member: 45985
Do as Ozling told u and you´re done!
Download:
http://www8.garmin.com/software/Garm...nS60_41080.exe
http://www8.garmin.com/software/Garm...emap_4***x.exe
http://www8.garmin.com/software/Garm...iles_4***x.exe
Note:replace the stars in links with tripple x,this forum is censoring it!
Format your phone´s card.
Conect your phone and choose "Data transfer" mode (select it when your phone asks you).
Run 1st exe file on your PC,don`t extract it!
Choose your "Removable Drive" as install destination.
Wait till it´s finished.
Do the same with another 2 exe files you have downloaded.
Send me your IMEI in pm and i´ll post you your sw.unl file.
br
The Following User Says Thank You to gjurobrod For This Useful Post:
Old 06-01-2008, 08:20   #1514 (permalink)
Member: 271255
OK, ask the risk of sounding really bad, specify "Run" and what exactly I'm supposed to do.
I erased the old prog5ram again and am Downloading your links...the page 85 link was downloading...but I'll go thru this one more time..thanx.
Old 06-01-2008, 08:28   #1515 (permalink)
Member: 45985
Double click on it using mouse
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
help with Garmin XT 4.10.60 S60 please?? se1boy GPS devices , Navigators & Maps 22 06-23-2008 05:48
Garmin XT 4.10.80 (taiwan) titan05 Nokia Multimedia 5 03-23-2008 04:27
Garmin XT 4.10.60 S60 deankanonik GPS devices , Navigators & Maps 9 01-09-2008 21:01
Garmin XT 4.10.20 PROBLEM slososk GPS devices , Navigators & Maps 14 12-27-2007 23:41
Page generated in 0.47715 seconds with 12 queries
