Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 12-11-2007, 22:55   #421 (permalink)
Member: 433671
Originally Posted by elroy_b View Post
well the story continues...
i tryed serval maps and the free map
... so thinq i'm using wrong cards from mapsourche metroguide 7
Free maps may not follow Garmin convention of naming, and hence, the Map ID is not the easiest to find.
Mapsource Metroguide v7 for which region? If Europe, you will encounter problems
Does anyone have BENELUX maps?
That is part of Europe v9 NT.
Old 12-12-2007, 10:21   #422 (permalink)
Member: 647849
ozling thanks for your help, but i am still getting that stupd unlock code message. might just have to go to a shop and buy a bloody garmin!
Old 12-12-2007, 11:20   #423 (permalink)
Member: 433671
Just check all the .img files in your garmin folder. Ensure that every .img file, with the exception of gmapbmap.img, has a corresponding .unl file with it.
The updates can also install extra maps, eg in the case of 4.10.60 of file size 74Mb, the Taiwan v8 map is added silently with the name gmapprom.img. Unless there's corresponding correct gmapprom.unl file, you will always get the unlock code messagage. The other maps will still works fine. If you do not need the Taiwan map, just delete this gmapprom.img file.
Old 12-12-2007, 13:22   #424 (permalink)
Member: 603499
Dear Ozling
I have been trying to set up garmin on N95 followed all instruuctions as u suggested but it is not recognising the internal GPS.
In GPS information it says Connection allowed to Garmin GPS device only. will not pair with BT 77 either. please heeeeeeeeeeeeelllllllppp
many thanks
Old 12-12-2007, 16:24   #425 (permalink)
Member: 260791
Wink
Originally Posted by flyingdoctors View Post
Dear Ozling
many thanks
1. go to file manger on phone and delite the .txt bit of both of the files you created so it will say sw.unl not sw.unl.txt and the other file you made.
2.restart Program should now recognize your built-in GPS (if not use GpsGate set to generic NMEA GPS receiver) and you should be
able to use detailed maps.
in gps .it my ask you to choose.if so..no2..but follow 1 till you understand it..
Old 12-12-2007, 17:00   #426 (permalink)
Member: 603499
Thanks for the reply I did exactly what u said in 1 but still did not pick up the internal GPS keeps saying GPS is off
so trying number 2 now where exactly is GpsGate that can be set to generic
Thanks once again for the help to an technologically challenged person
Old 12-12-2007, 17:35   #427 (permalink)
titan05's Avatar
Member: 613875
If you have made the SW.UNL and GMAPSUPP.UNL correctly it should not get that message. Launch Garmin XT, go into settings and enable internal GPS.
Old 12-12-2007, 18:31   #428 (permalink)
Member: 584168
Good evening
I can not have a warning for its radar while everything is in the directory poi alert mp3 image bmp and csv loaded with poi loader file is gpi the program well configure alerts for I see the picture but I have no sound except the original one for a garmin leger.ding.
j am sorry for the French translation miller.t
Old 12-12-2007, 18:41   #429 (permalink)
titan05's Avatar
Member: 613875
Originally Posted by miller.t View Post
Good evening
I don't believed the Garmin XT suport mp3 alert.
Old 12-12-2007, 20:01   #430 (permalink)
Member: 569891
generete unluck kode/paste choos save as SW.UNL choose all files choose ANSI and klick Save do the same with GMAPSUPP.UNL and that`s it
Old 12-12-2007, 23:35   #431 (permalink)
Member: 433671
If you cannot pair with BT or internal GPS, then it can only mean the sw.unl code in wrong or absent. You just need to get the imei or card id again from settings>about and reenter the details in the keygen to create the sw.unl file.
Old 12-12-2007, 23:36   #432 (permalink)
Member: 433671
Ahem. Er. GPSGate is a WM program, and will not run on Symbian!
Old 12-12-2007, 23:38   #433 (permalink)
Member: 433671
Before starting Garmin, why not start Nokia Navigator and ensure that the internal GPSr is up and active. Exit Navigator, then start Garmin.
Old 12-13-2007, 02:52   #434 (permalink)
Member: 651513
Anyone have the MapID for City Navigator North America 2008 or City Navigator North America NT 2008.
Old 12-13-2007, 03:54   #435 (permalink)
Member: 433671
Have a look above
http:///vbb/showpo...&postcount=135
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
help with Garmin XT 4.10.60 S60 please?? se1boy GPS devices , Navigators & Maps 22 06-23-2008 05:48
Garmin XT 4.10.80 (taiwan) titan05 Nokia Multimedia 5 03-23-2008 04:27
Garmin XT 4.10.60 S60 deankanonik GPS devices , Navigators & Maps 9 01-09-2008 21:01
Garmin XT 4.10.20 PROBLEM slososk GPS devices , Navigators & Maps 14 12-27-2007 23:41
Page generated in 0.41826 seconds with 12 queries
