GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-13-2008, 22:06 | #751 (permalink) |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | ----------------- http://www8.garmin.com/software/MapSource_6136.exe Garmin XT Map Install --------------------- http://www8.garmin.com/software/MapInstall_3116.exe Garmin POI Loader ----------------- http://www8.garmin.com/software/POIL...indows_242.exe |
01-14-2008, 04:07 | #757 (permalink) |
Junior Member Join Date: Nov 2007
Member: 638352 Status: Offline Thanks Meter: 0 | it wasnt at the offical page , i got it from sum torrent pages . i didnt b elieve it at first thats v80 but its even opening screen is diffrent and looks a lil diffrent then the v60, if you guys want im gona upload it here and will tell you how i did setup |
01-14-2008, 05:35 | #758 (permalink) |
Major Poster Join Date: Dec 2007
Member: 650130 Status: Offline Thanks Meter: 0 | GXT on N95 8gb Has any body tried GXT installation on the 8GB N95 with the instructions provided in this forum. I did it on my regular N95 and it works just fine but I was wondering how the installation is going to be in the N95 8GB i.e. with out the micro SD card. As far as I know with the instructions the application is installed on the card and the Keygen is used for generating card ID codes and stuff, so if there is not a memory card in the 8GB N95, how will the installation proceed. just wondering? |
01-14-2008, 06:24 | #759 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 433671 Status: Offline Thanks Meter: 118 | The keygen will also generate an ulock file based on your IMEI, ie if you do not have an SD card, it will list your IMEI as device ID. Look early on. I posted an IMEI to Device ID calculator. Use that in your keygen. |
01-14-2008, 11:35 | #762 (permalink) | |
Member: 650130 Status: Offline Thanks Meter: 0 | Quote:
So to summarize, in 8gb N95 installation once I go to the settings>about, it will show me my phone's IMEI number under the device ID place but I cant use my IMEI number directly in the Keygen, I will have to use the IMEI to device ID calculator first and use that generated ID in the regular Keygen to get the unlock code. I am not sure if this sounded right?? | |
01-14-2008, 12:28 | #764 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | Quote:
i've put a readme file that explains all the information about activation, etc | |
01-14-2008, 12:37 | #765 (permalink) | |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
help with Garmin XT 4.10.60 S60 please?? | se1boy | GPS devices , Navigators & Maps | 22 | 06-23-2008 05:48 |
Garmin XT 4.10.80 (taiwan) | titan05 | Nokia Multimedia | 5 | 03-23-2008 04:27 |
Garmin XT 4.10.60 S60 | deankanonik | GPS devices , Navigators & Maps | 9 | 01-09-2008 22:01 |
Garmin XT 4.10.20 PROBLEM | slososk | GPS devices , Navigators & Maps | 14 | 12-28-2007 00:41 |
