Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-14-2008, 16:33   #781 (permalink)
BuMobiles's Avatar
Member: 503346
Originally Posted by xabia View Post
big brobs with n95 internal 8gb
when install garmin xt 4.10.20 its seems ok but evertime i try to run it bins me off back to aplication screen
sometimes i get the garmin splash screen but bins me off im trying to get my id card in the settings about
bit but i carnt get to because it dont boot
IMEI_to_ID_and_kgen ---- done my imei unl file
GarminMobileXTSupportFiles_4***x
Garmin_XT_Europe_v9__UK__Maps.rar.part1 and 2
when extract them i get 2 files gmapsupp.unl file and gmapsupp img file
please help been at this for 2 days now
1, install garmin xt 4.10.20
2, load the program up and then close it down
3, install garmin xt 4.10.60
4, load the 4.10.60 software and then get unit id
5, make your sw.unl
6, copy maps into the garmin folder of the memory card / device memory
7, unlock the maps via the .unl file
Old 01-14-2008, 20:06   #782 (permalink)
Member: 675107
ok maybe i'm just doing something wrong or i'm getting bad maps...i have garmin 4.10.60 and have the gps unlocked, and i have the world basemap. I guess my problem is with City navigator North america nt 2008. I d/l the 1.12gb file off iso and xfr'd it onto the garmin folder on my memory card. I open up garmin and it only shows the basemap. I try to search for an address and it tell me i need detailed maps for that...
Also with the mapsource and Mapinstall programs that were posted earlier, how do those work? it never lets me select(highlight) a country or location. all i can do is select new waypoints..
Old 01-14-2008, 20:19   #783 (permalink)
Member: 678134
5, make your sw.unl
i think my prob is im not installing it properly wish i had gone for the 8gb card phone now
if i start data transfer and open folder 4.10.20 hit setup it finds the phone drive j which is the right one when i click install in a nanno second it says installed when i check on phone in apps its not even there
so the only way i can install is copy folder 4.10.20 start data transfer open drive j paste it in then go into file manager run setup from there it all installs ok but when i start garmin xt in apps it does not boot
if anyone has installed on n95 internal 8gb please let me know how you installed it
Old 01-14-2008, 21:15   #784 (permalink)
titan05's Avatar
Member: 613875
Garmin Fodor's Travel Guide North America
http://rapidshare.com/files/83817603...odors.rar.html
Old 01-14-2008, 22:36   #785 (permalink)
BuMobiles's Avatar
Member: 503346
this is what i'm saying.
i have installed it on a nokia n95 8gb, have you tried factory resetting the phone memory 1st
Old 01-14-2008, 23:33   #786 (permalink)
Member: 674060
links for garmin
Hi BuMobiles, sorry to be a pain but do you have any links for garmin xt v4.10.20 as the links i can find on the forums are not working for me? i have manage to get v4.10.60 and tried to install that but presume i need the older version 1st then upgrade to this later version.
I would be grateful if you have any other links to other items i may need to get this running on my n95.
Thanks in advance
smarty1972
Old 01-14-2008, 23:36   #787 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks in advance
smarty1972
sure i have my own links
and here you go
Garmin Mobile XT (Symbian S60 v4.10.20)
These Setup Files are for the Symbian S60 Based Device's
http://rapidshare.com/files/75128101..._v4.10.20_.rar
Garmin Mobile XT Support Files v4.x
This pack contains all the Voice files for the Garmin XT
http://rapidshare.com/files/75126810...es_v4.***x.rar
http://rapidshare.com/files/83242741...es_v4.***x.rar
p.s change *** to 3 x's (can't have them displayed due to looks like something dirty)
Garmin XT Speed Camera's POI
This is the latest Speed Camera's for the Garmin XT
Updated 1st December 2007
Just Extract and Copy the POI.GPI to the \Garmin\POI folder on the memory card after installing Garmin XT
http://rapidshare.com/files/75126824...mera_s_POI.rar
Garmin XT Europe v9 (UK) Maps
Europe Maps for Garmin XT
Part1: http://rapidshare.com/files/75147181....rar.part1.rar
Part2: http://rapidshare.com/files/75131893....rar.part2.rar
The Following User Says Thank You to BuMobiles For This Useful Post:
Old 01-14-2008, 23:38   #788 (permalink)
Member: 674060
**Thanks you are a star**
Old 01-15-2008, 05:01   #789 (permalink)
Member: 433671
Originally Posted by cc909 View Post
BU, see I got confused from this post, I thought that the settings>about screen was going to show my IMEI number in 8gb N95 since it does not have a card, and the IMEI can not be fed directly into the Keygen. It has to be converted into the device ID first by the unfound calculator.
Ooops. Should have made it clear. Yes, you use IMEI convertor to generate a Device ID from your IMEI. From there, you plug that number into the Jetmouse Keygen (version 1.3 at present) to get the unlock code.
Old 01-15-2008, 05:07   #790 (permalink)
Member: 433671
The iso needs to be either mounted or burnt to a DVD.
All these maps needs mapsource to install to your phone.
Some people rip the img off the phone and post it. If it is in gmapsupp.imp or gmaprom.img format, then it can be copied straight to the phone.
Otherwise, you need to install mapsource, and then open the map on your PC and select the tiles or parts of map you want compiled and sent to your phone as a gmapsupp.img file.
Old 01-15-2008, 20:19   #791 (permalink)
Member: 676599
could somone please confirm that they have the postcode search facility, have tried re-installing everything and still not got it
thanks
Old 01-15-2008, 20:59   #792 (permalink)
BuMobiles's Avatar
Member: 503346
thanks
garmin xt doesn't support postcode search
Old 01-15-2008, 21:06   #793 (permalink)
Member: 650415
garmin does support postcode search .60
Old 01-15-2008, 21:16   #794 (permalink)
BuMobiles's Avatar
Member: 503346
i'm using v4.10.60 and i can't find it
Old 01-15-2008, 21:21   #795 (permalink)
Member: 676599
me neither,
have read many people saying it does though, but mine hasn`t
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
help with Garmin XT 4.10.60 S60 please?? se1boy GPS devices , Navigators & Maps 22 06-23-2008 05:48
Garmin XT 4.10.80 (taiwan) titan05 Nokia Multimedia 5 03-23-2008 04:27
Garmin XT 4.10.60 S60 deankanonik GPS devices , Navigators & Maps 9 01-09-2008 21:01
Garmin XT 4.10.20 PROBLEM slososk GPS devices , Navigators & Maps 14 12-27-2007 23:41
Page generated in 0.49628 seconds with 12 queries
