Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-25-2008, 09:17   #961 (permalink)
BuMobiles's Avatar
Member: 503346
Originally Posted by cc3 View Post
Hi BuMobiles,
thanks for the help!
After the SW.UNL u gave, but still doesn't work! I just trying using Bluesky the BT and GPSr is working fine..
any Idea, what wrong?
Please kindly advise.
thank you!
cheer!
you need to generate a new device unlock code,
try formatting memory card, factory reset phone, install garmix xt, generate unlock code (this should work )
Old 01-25-2008, 15:55   #962 (permalink)
Member: 663114
Please has anyone got TMC Traffic update to work in the UK, there is an option for it, but says that detailed map does not have this option.
What map do I need??
Thanks
Old 01-25-2008, 17:32   #963 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks
doesn't work in the uk with then maps at the moment
Old 01-25-2008, 17:41   #964 (permalink)
Member: 682631
i gave it a try today
it was more than great
so much thanks for all the guys who helped me
Old 01-25-2008, 18:04   #965 (permalink)
Member: 331838
New mirror of a LOT of Garmin stuff here
http://rapidshare.com/users/3E8D87
Old 01-25-2008, 18:51   #966 (permalink)
Member: 689101
I have a Nokia n95 8GB. I can't get internal GPS to work. Maps is working fine and I have both GMAPSUPP.UNL & SW.UNL files in my Garmin folder. Both these files have the correct extension and doesn't end in .txt
Please can someone advise where I'm going wrong?
Old 01-25-2008, 21:40   #967 (permalink)
Member: 331838
If you use ver 4.10.20 sometimes the internal GPS isn't recoqnized. Update and it should work. Full installer of version 4.10.60 is available through the message right above yours.
Old 01-25-2008, 21:55   #968 (permalink)
Member: 433671
Originally Posted by SentraVIP View Post
Manage to view Malaysia's detailed map after I get the base map in. Thanks Ozling.
BTW, are you from KL?
On a whole different continent!
Old 01-25-2008, 21:58   #969 (permalink)
Member: 446456
Hi guys,
If anybody have a link of Brazil map with Code for Mapsorce and Map ID?
Old 01-26-2008, 03:01   #970 (permalink)
Member: 668701
Originally Posted by Ozling View Post
Some have reported problems with it though.
The Version .40 update for Garmin XT will speed it up significantly.
Might also use smaller maps, ie use mapsource and select the state you want only... Same keys will work
Upgraded to .40 and it says it's not compatible with my P1i? The .40 upgrade is meant for
UIQ3 users, right?
Old 01-26-2008, 04:54   #971 (permalink)
Member: 360805
Ok, so I'm hoping someone here can help me out with this, as I can't find a solution to my problem.
My device is a WM6 PDA. I installed Garmin Mobile XT (ver. 4.10.40wp) with no issues. I easily got it working with my internal GPSr. I have the basemap installed, which shows my correct position/speed/direction/etc.
I'm trying to get some detailed North American maps installed. I downloaded and installed the MapSource City Navigator North America NT 2008, with no issues. I go into MapSource, select my areas, and click on the transfer to device option. I get the 'send to device' dialog box which finds my device, but is then quickly replaced with an error message (see attachment for screen shot).
I've tried this on two seperate PC's, and I've reinstalled Garmin Mobile on my device multiple times. Same issue every time.
If anyone can help me with this, I would be very grateful. I've looked online and cannot find any solutions to this problem. Or if someone knows where I can get the IMG files for North America, or if there's another way to transfer these maps to my device.
Old 01-26-2008, 13:48   #972 (permalink)
Member: 560462
Did you copy the log and sent to Garmin support as it says? lol j/k
I've noticed a couple things when generating maps. If I have a map installed (excluding the base map) then I error out when trying to transfer a new map. I need to manually copy the map from my pda to pc then delete it on the pda. Then mapsource will transfer successfully.
2nd, maps are quite large. You sure you have enough free space on your storage card?
I haven't found a way to have mapsource install the map files on the pc allowing you to manually transfer them.
Old 01-26-2008, 14:09   #973 (permalink)
Member: 611660
Red face
How can I unlock the maps for MapSource 6.13.6? I have found few text files in the iso, but only one contains some code (Setup.dat). I tried it when I was asked by MapSource (no matter that the code should have 25 chars and the one from source.dat had around 50), and it didn't work ...
I have read (almost) all posts on this thread and I googled for an answer, but no luck.
Thanks!
Old 01-26-2008, 16:29   #974 (permalink)
Member: 11074
Thanks!
try this:
43XPW-723MK-PUVGV-9QQZZ-S3T5B
it is for Proiectul Romania Digitala RO.A.D 2006, if you have same version, it can work.
PS: I read somewhere, that when you use code DEMO, you can view map in Mapsource on PC...
Old 01-26-2008, 20:42   #975 (permalink)
Member: 683976
I have GMXT up and running on my N95, but I have found the map rendering and redraw to be very slow with a lot of lag.
Does anyone have this problem or have I done something wrong?
Cheers
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
help with Garmin XT 4.10.60 S60 please?? se1boy GPS devices , Navigators & Maps 22 06-23-2008 05:48
Garmin XT 4.10.80 (taiwan) titan05 Nokia Multimedia 5 03-23-2008 04:27
Garmin XT 4.10.60 S60 deankanonik GPS devices , Navigators & Maps 9 01-09-2008 21:01
Garmin XT 4.10.20 PROBLEM slososk GPS devices , Navigators & Maps 14 12-27-2007 23:41
Page generated in 0.50590 seconds with 12 queries
