Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #1231 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks: 174
| Quote:
| | #1232 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 733457 Status: Offline Thanks: 3
| I gave up on my N95 8GB Hi m8s.. am new to this GPS thingy.I went all over this thread ..so far Garmin cannot locate my built in GPS on my Nok N95 ...i have V40.10.20 installed and the basemap and the support file.and i uploaded the GMAPSUPP.UNL and SW.UNL to Garmin Dir and removed the txt from within the phone...did i miss any thing .....plz advicethanx a million in advance cheeers p.s from where i can get map of middle east v4 Last edited by inaccache; 03-25-2008 at 11:56. |
| | #1233 (permalink) | |
| Quote:
2, Calc ID code and type them into the un.swl 3, Copy maps into the Garmin Folder 4, Reset the phone 5, Load garmin xt 6, Select GPS Device's, click Attached GPS 7, All Done...! | |
| | #1234 (permalink) |
| Junior Member Join Date: Mar 2008
Member: 733979 Status: Offline Thanks: 0
| BU Sorry to be a pain, but you know on the 1st page it says instructions in the file, well ive downloaded the files and used winrar to open them but cant see any instructions, trying to get it on an n95 but struggling! cheers rich |
| | #1235 (permalink) | |
| Quote:
-------------- Let's start from scratch. 1) Install the program - can copy it to the SD card directly into a folder named Garmin. 2) Download and run the support files for voice etc. 3) Start the program. 4) Cancel out of the GPS search. It will not see the BT or internal GPS at this stage. 5) Get you Unit ID (IMEI and calculate) and also your Card ID from Settings>About 6) Calculate the key and create your sw.unl file 7) Copy that to the garmin folder. 8) Check that your GPS receiver is working - with BT, ensure that you can get your location with navigator etc. Similarly, internal GPS. 9) Start your program. The GPS options will be available for non Garmin receivers. 10) Install your basemap and area map. 11) Calculate your map unlock with KeyGen. Use the Map Id if need to. 12) Create your GMAPSUPP.UNL and copy it to the garmin folder on your SD card. 13) If you get to the no maps found, then either the map is faulty, or the the entered is incorrect. Try an unlocked map (delete the GMapsupp.unl file). Route 66 V8 Help ----------------- http://rapidshare.com/files/92380481...stallation.rar Route 66 Installation Guide --------------------------- 1, copy all the files and folders from the extract rar file 2, install the 'Route 66 Mobile 8.0.11540.sis' from the route 66 v8 folder 3, goto your memory card and select the folder called \system\apps\route 66_v8\data folder 4, open both imei.dat and phone.dat using notepad and edit the first lines of both files 5, input a 0 then your imei no and save both files 6, Copy your map files to the folder called \system\apps\route66_v8\data\maps 7, run your route 66 v8 from your phone Route 66 V8 ----------- to make this route 66_v8 program to work you have do this things : 1, download the program http://rapidshare.com/files/89255007/route66_3d.rar extract the file and after exracting open the map and copy the file to the first map route66_V8. 2, open the map route66_v8 and then open the data map. 3, go to the imei.dat file and open it with the notepad program 4, change the imei nummber to your phone imei (dont delete the zero) after doing that close and save the changes 2 the file. 5, open the phone.dat file also with notepad and put your phone imei after that close and safe the changes 2the file. 6:download this file: http://rapidshare.com/files/91068751...11540.rar.html after downloading finesh extract the rar file and recall the map to : route66_V8 7, copy the map to your phone memory card (system\Apps) after that run the Mobile8.0.11540.sis file from your phone to install after you finsh from instaling the program go and run it and you see that its working. | |
| The Following User Says Thank You to BuMobiles For This Useful Post: |
| | #1236 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2007
Member: 663114 Status: Offline Thanks: 0
| Great last post on installing, quick question although I think difficult to answer, but here goes ! Garmin XT in subscription status I have safety camera trial, traffic US Traffic Europe, Fuel US and Hotels There is at the bottom activation information. Free subscription to add remove services ? at the bottom there is the activate button. Is there a keygen for this ?? to add extras. I have nothing for the UK ? traffic won't update, speed camera the same ?? Any way of getting some of these services updated ? The version i have is 4.10.40s60.9.tw Thanks |
| | #1237 (permalink) | |
| Quote:
| | #1239 (permalink) | |
| Major Poster ![]() ![]() Join Date: Sep 2005 Age: 53
Member: 179296 Status: Offline Thanks: 6
| Quote:
http://rapidshare.com/files/89255007...66_3d.rar.html http://rapidshare.com/files/91068751...11540.rar.html | |
| | #1240 (permalink) | |
| Quote:
now am realy lost... i did as you said but without copieng tha map as i did not know where to get the map of middle east..tell me is the ID code is the card ID in the about under settings..i even got IMEI and IMSI so which one is it....plus where can i get the above said map.....do i need to install the basemap and the support files ??? tanx a million m8 | |
| | #1242 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Apr 2002
Member: 11074 Status: Offline Thanks: 10
| Quote:
8. map put in to the folder Garmin 9. you need support files, as there are voices and so on... 10. no need for basemap... In About you see UnitID, isn't it? When you unlok map to UnitID, you can change card for bigger one and use same map with same unlock code. When you unlock map to CardID, after change map you need to generate new unlock code. | |
| | #1243 (permalink) | |
| Quote:
please check your pm inbox thanx | |
| | #1245 (permalink) |
| For those m8s using Vista ops you will face a problem in creating the sw.unl file as it took us hours me and my new buddy on this forum ( ataralgin ) for which I thank him for his time and effort in resolving the problem..the thing is when you creat the sw.unl file, Garmin XT will never locate your built in GPS for the Nokia N95 8GB, as the created file is 51 bytes and it should be 25 bytes ..so the best thing is to creat the file using Win XP as Vista note pad differes ...dont know why ![]() So if you face such prob...XP is the solution for the sw.unl file ..and make sure to remove the TXT extension from within the phone using file manager. Hope this info would help Vista users and will not suffer as I did |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
| help with Garmin XT 4.10.60 S60 please?? | se1boy | GPS devices , Navigators & Maps | 22 | 06-23-2008 05:48 |
| Garmin XT 4.10.80 (taiwan) | titan05 | Nokia Multimedia | 5 | 03-23-2008 04:27 |
| Garmin XT 4.10.60 S60 | deankanonik | GPS devices , Navigators & Maps | 9 | 01-09-2008 21:01 |
| Garmin XT 4.10.20 PROBLEM | slososk | GPS devices , Navigators & Maps | 14 | 12-27-2007 23:41 |
