Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #16 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: KwaZulu-Natal, South Africa Age: 43
Member: 757575 Status: Offline Thanks: 6
| Quote:
As mike2111 pointed out, the benefit of the mapsource mapsets is that they are routable and can be installed on multiple devices. The trick behind getting them to work is to install the mapsets for use with mapsource and unlock them (using Jetmouse's keygen). How about a howto? mike2111, How about I compile a howto for newbies? Can you give feedback? fugglefeet | |
| | #17 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Denmark Age: 46
Member: 385577 Status: Offline Thanks: 22
| Quote:
I am almost sure you can find one somewhere here in the forum. If you can find one or prepare one, that is absolutely fine with me .... ![]() Regards Mike | |
| | #18 (permalink) |
| Junior Member Join Date: Nov 2008
Member: 908415 Status: Offline Thanks: 1
| Sigh.... I'm not usually this thick, but I just can't see what I'm doing wrong. I Downloaded a torrent copy of Metroguide Canada: http://www.torrentreactor.net/torren...-unlock-needed unzipped it. The unzipped files are not a disk image - just the files and folders. Placed the files in a separate directory, and ran the setup program. It gets part way through the install, and it asks me for "Disk 1". Of course, since the files are on my hard drive, there is no disk 1. So, I burn a CD, and entitle it "Disk 1". I try running the setup program again. Still, it asks for Disk 1. (It doesn't recognize the disk I have in there as disk 1.) I can't seem to get past this. Worse part is - I had Mapsource installed and running, but the aborted install of Metroguide has incapacitated Mapsource, and so now, I have nothing. I'm sure it's dead simple... but I can't see it. Help...? |
| The Following User Says Thank You to bikeNguy For This Useful Post: |
| | #19 (permalink) | |
| Quote:
You can use the link for Garmin City Navigator North America NT 2009 on page 1. I know it will work for sure. Regards Mike | |
| The Following User Says Thank You to mike2111 For This Useful Post: |
| | #20 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: here and there Age: 29
Member: 381895 Status: Offline Thanks: 5
| I'm having problems trying to unlock the map so I can edit it... Downloaded: Garmin City Navigator Europe NT 2009 - Mapid: 378 Download (Torrent) The instructions are not good. English: Do not use the setup from the windows folder!. Install from the folder IMG your desired language version, eg: CNEUNT2009Update_NLD To unlock, you get an unsolicited Mapsource update for you choose, Unlock the Wizard, you just start itself. This stands in your Garmin folder (Start -> All Programs -> Software -> Unlock Wizard. Use the keygen to unlock with MapID: 378 Search ID of your GPS: Through MapSource -> Tools -> Apparaat_ID fetch. Now the cards are UNLOCKED in Mapsource you can easily transfer them to your GPS How do I unlock the map? |
| The Following User Says Thank You to bornagaibiker For This Useful Post: |
| | #21 (permalink) | |
| Quote:
Enter your GPS's ID number and mapid in the key generator, and you have the unlock-code. Then enter the code in Mapsource, and you can transfer the map, or parts of the map to your GPS. Regards | |
| | #22 (permalink) | |
| Quote:
1) In Mapsource, click Utillities > Manage Map Products 2) Select the Unlock Regions tab, and click Add 3) Enter your 25-character unlock code and then a comment, if desired. Click OK For more info look in the userguide for Mapsource. Regards Mike | |
| The Following 2 Users Say Thank You to mike2111 For This Useful Post: |
| | #23 (permalink) |
| Thank You, I was about to bang my head against the wall, I was getting so stressed with it. I had done everything right I just didn't know how to get the key into the program lol |
| | #24 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Nov 2008
Member: 903304 Status: Offline Thanks: 12
| Just a question? If I unlock the maps and use in mapsourse with my device id then that map is only for my device and not for, say my other halfs device? When the map is transferred to my device does it create the .img file? Then if I want to use that .img file on another device I just copy it off the original device and use the new card id to put on another device? Could try this myself however have a good running PDA and Nokia and do not want to experiment as I might stuff up my installations. If the above is ok then I will have a go for fun. Ta Ernie |
| The Following User Says Thank You to tamate For This Useful Post: |
| | #25 (permalink) | |
| Quote:
Regards | |
| | #26 (permalink) |
| I have two .img files, one Australia maps and the second NZ maps, when I put on a device you do not need a .ul file and they work great. The uk map I have does need a .ul file. Is this because the img file for Aus and NZ was created with mapsource? Cheers Ernie |
| | #27 (permalink) | |
| Quote:
Mapsource just allows you to view the mapsets. The UK mapset is locked and can be unlocked using Garmin Unlocker, so that you don't have to unlock it every time you install it on a device. | |
| The Following User Says Thank You to fugglefeet For This Useful Post: |
| | #28 (permalink) |
| How can I put this so I do not sound to dumb and other forum members do not cut their wrists. Ok I have unlocked the uk maps on my devices by using the keygen and making a .ul file and all is sweet, if I put the uk maps on another device I generate a new code using that device card id and making new .ul file. So if I use another progy called Garmin unlocker the uk map will not need individual .ul files like the Aus/NZ maps I have? Is this correct? I am trying to understand a little bit more, my devices are working great due to this forum however I am just trying to get my head around the finer points. Cheers Ernie |
| | #29 (permalink) | |
| Quote:
That is true. Run Garmin Unlocker on your PC and it will search for all forms of Garmin *.img files and permanently unlock them for you to use on any device. fugglefeet | |
| | #30 (permalink) |
| Let us all share our maps Requirements for maps to be included in the list: 1) All maps must be MAPSOURCE versions - not gmapsupp.img. 2) The map must be routable, and may not be prepared from a gmapsupp.img map. 3) New / Other maps to be included in the list must be in a better resolution than the existing maps. If you have a map, or have knowledge of a map that meets these requirements, please post the link here..... What is the advantage of using Mapsource? In this way you can combine several different maps, and transfer them to your GPS as a single map. Fell free to download the maps you need..... If you find this post useful, please say thanks you..... ![]() AdriaROUTE 2.10 - Mapid: 708 Download Mirror SCG Route 1.80 - Mapid: 929 Download Update Slovakia Roads v6 - Mapid: 1315 Download R.O.AD.2006 (Roads of Romania) - Mapid: 931 Download (New link) Update Garmin Navcity Turkey 2008.07 - Mapid: 848 Download, part 1 (Password: tom1807) Download, part 2 (Password: tom1807) Mirror, part 1 Mirror, part 2 Garmin Mapsource World Map 4.06 Download OFRM Bulgaria v4.60 - Mapid: 5028 Download Mirror NaviGuide Hungary 5.0 NT - Mapid: 709 Download CarteBlanche Ukraine 3.40 - Mapid: 575 Download Venezuela - Free map Download Mapear V7.00-Mapas Electronicos Argentinos - Mapid: 900 Download Mirror Philippine Islands - Free map Download Laos/Vietnam - Free map Download Samoa - Free map Download Indonesia - Free map Download Greece - Free map Download Cyprus - Free map Download Garmin City Navigator Europe NT 2009 - Mapid: 378 Download (Torrent) Garmin City Navigator North America NT 2009 - Mapid: 325 Download (Torrent) Garmin Chile Streets 2007 - Mapid: 724 Download (Torrent) Garmin City Navigator Australia NT 2009 - Mapid: 358 Download (Torrent) Garmin City Navigator Middle East NT 2008 - Mapid: 329 Download Mirror Garmin City Navigator Mexico NT 2008 - Mapid: 278 Download, part 1 Download, part 2 Download, part 3 Garmin City Navigator NT New Zealand 2009 - Mapid: 499 Download GARMAP Southern Africa Streetmaps, Topo & Rec, March 2008 Mirror (Torrent) GARMAP Indian Ocean Islands Streetmaps Version 1 Mauritius - Mapid: 1148 Download Mirror (Torrent) GARMAP East Africa Street Maps Version 1 - Mapid: 1095 Download Mirror (Torrent) GARMAP Nigeria Streetmaps, Topo & Rec Version 2 - Mapid: 807 Download Mirror (Torrent) GARMAP Southern Africa Streetmaps, March 2008 - Mapid: 1214 Download Mirror (Torrent) Roads of Russia with Routing 4.03 - Mapid: 1120 Download (Torrent) Mirror, part 1 Mirror, part 2 Mirror, part 3 Mirror, part 4 Mirror, part 5 Mirror, part 6 Moldova 2008 - Free map Download Garmin Polska GPMapa 2008.2 - Mapid: 1325 Download (Torrent) Garmin EU SpeedCams 2008 update 09 Download (Torrent) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| malaysia map for garmin xt | carrotboy88 | GPS devices , Navigators & Maps | 1 | 01-19-2012 07:18 |
| Garmin XT Canada Map | jati_grewal | GPS devices , Navigators & Maps | 2 | 07-18-2009 13:10 |
| maps for garmin xt | billyprepo | GPS devices , Navigators & Maps | 1 | 03-11-2009 10:33 |
| Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
| Garmin XT Canada Maps 2009 | s3lekta | Nokia Multimedia | 0 | 09-21-2008 19:45 |
