Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-15-2009, 06:54   #286 (permalink)
Member: 922633
Its working!
I have downloaded from there and I have installed it in my 276C
Old 01-15-2009, 08:38   #287 (permalink)
Member: 385577
Thanks Meter: 656
Originally Posted by superphonedeals View Post
can any one give me the link to download Garmin City Navigator Europe NT 2009 - Mapid: 378 the one currently on there is not working.
does anyone know another link.
thanks in advance
The link is working, but it is for torrent.....
If you want rapidshare try to check here: http://xwarezzz.com/utilities/1873/g...ial-patch.html
or here: http://www.passiondownload.com/forum..._full_dvd.html
or here: http://www.freshwap.net/forums/appli...-2009-dvd.html
Regards
Mike
Old 01-15-2009, 15:43   #288 (permalink)
Member: 944132
Thanks Meter: 45
Garmin Japan RoadNavi 25000 v2
Map ID: 5041
http://rapidshare.com/files/183304871/Jenas_Japan25K.part1.rar
http://rapidshare.com/files/183329996/Jenas_Japan25K.part2.rar
http://rapidshare.com/files/183420326/Jenas_Japan25K.part3.rar
http://rapidshare.com/files/183438966/Jenas_Japan25K.part4.rar
http://rapidshare.com/files/183279000/Jenas_Japan25K.part5.rar
The Following User Says Thank You to jenas For This Useful Post:
Old 01-16-2009, 22:09   #289 (permalink)
Member: 948566
some 1 help how to unlock ms map wat is the 8digit unlock code
Old 01-17-2009, 00:55   #290 (permalink)
Member: 366776
Thanks Meter: 2
leave ur msn messenger id then i will tell u how to unlock the map
Old 01-17-2009, 00:57   #291 (permalink)
Member: 366776
Thanks Meter: 2
mr.mike2111 do u know that Garmin can use in car with built-in GPS car player?
Old 01-17-2009, 07:36   #292 (permalink)
Member: 385577
Thanks Meter: 656
No.... I do not know.....
Regards
Mike
Old 01-17-2009, 16:48   #293 (permalink)
Member: 922453
Hi there,
Venezuela Venrut 4.1 link is off.
Thanks a lot for sharing!
Old 01-17-2009, 17:26   #294 (permalink)
Member: 385577
Thanks Meter: 656
Let us all share our maps
Requirements for maps to be included in the list:
1) All maps must be MAPSOURCE versions - not gmapsupp.img.
2) The map must be routable, and may not be prepared from a gmapsupp.img map.
3) New / Other maps to be included in the list must be in a better resolution than the existing maps.
If you have a map, or have knowledge of a map that meets these requirements, please post the link here.....
What is the advantage of using Mapsource?
I think the MapSource program is pretty much a "must have". In addition to the ability to load maps, the MapSource software has a lot of other capabilities, for example:
- Maybe you are lucky. Maybe you can have up till 6 maps on your phone at the same time eg. gmapbmap.img (Basemap), gmapprom.img (internal map, used when you have US or EU maps), gmapprom1.img (internal map, used when you have both US and EU maps), gmapsupp.img (Supplemental maps, will be overwritten when you add new maps), gmapsup2.img and gmapoem.img (For OEM Company). But with MapSource you can have as many as you want!!!!! You just merge more maps together so they will appear as one file (gmapsupp.img) on your device
- See all the Cities, selected map details and POI's on your computer
- Set up routes and find out distances. Helps you get an overall picture
- Create and transfer waypoints to your device
- Backup your waypoints from your device to a database (*.gdb) file on your computer.
- Find the lat/long positions of waypoints.
- Add description comments to your favorites/waypoints, like addresses and phone numbers.
Feel free to download the maps you need.....
If you find this post useful, please say thanks you.....
How to:
Installation of software on a phone (Symbian S60 3rd Edition):
Install Garmin Mobile XT Free Basemap: http://www8.garmin.com/software/Garm...emap_4xxxx.exe
Install Garmin Mobile XT Support Files: http://www8.garmin.com/software/Garm...iles_4xxxx.exe
Install Garmin Mobile XT for Symbian S60 3rd Edition: http://www8.garmin.com/software/Garm...tion_50020.exe
Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card.
Start the application.
Select settings for text language, voice, unit and for Garmin Online.
Exit the application.
Open the file called GarminDevice.xml. It is located in the Garmin folder.
Look for <Id>XXXXXXXXXX</Id>
Use the keygenerator (Howto to install locked Garmin Maps) to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL.txt) using Notepad. The file should be saved in the Garmin folder.
More info here: http://www.megaupload.com/?d=UF9MMFF3 (Thank you Fugglefeet)
Installation of maps:
Download version 6.13.7 of MapSource: http://www8.garmin.com/software/MapSource_6137.exe (Don't use the latest version - it is not compatible with all the maps).
Follow the following trick to hack the setup file so that it can be used to install MapSource clean and fresh without any prior installation of MapSource.
Unpack or extract the content of MapSource_6137.exe downloaded using WinRAR.
From the extracted files, run MAIN.msi.
Then, run Setup.exe.
Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
Garmin MapSource now installed.
Download the map you want from here.
Install the map using the file called something with XXXXXX_ENU.msi - Not the Setup.exe - This will install the map only.
Launch MapSource and unlock the map, use a key generator which you can find here: Howto to install locked Garmin Maps
Enter your GPS's ID number and mapid in the key generator, and you have the unlock-code.
In Mapsource, click Utilities > Manage Map Products.
Select the Unlock Regions tab, and click Add.
Enter your 25-character unlock code and then a comment, if desired. Click OK.
For more info look in the user guide for Mapsource: http://www8.garmin.com/manuals/MapSo...UsersGuide.pdf
Then you transfer the part of the map (e.g. Spain) you would like to your GPS.
If you would like to have more maps, e.g. Garmin City Navigator Europe NT 2009 and Garmin City Navigator North America NT 2009 you can combine the maps and transfer them to you GPS.
Try it.....
Map list:
AdriaROUTE 2.20 - Mapid: 708
Download
SCG Route 1.90 - Mapid: 929
Download
Mirror, torrent
Slovakia Roads v6 - Mapid: 1315
Download
R.O.AD.2008 v3.01 (Roads of Romania) - Mapid: 1189
Download, part 1
Download, part 2
Download, part 3
Download, part 4
Download, part 5
Mirror, torrent
Garmin Navcity Turkey 2008.07 - Mapid: 848
Download
Mirror, part 1 (Password: tom1807)
Mirror, part 2 (Password: tom1807)
Garmin Mapsource World Map 4.06
Download
OFRM Bulgaria v4.70 - Mapid: 5028
Download
NaviGuide Hungary 5.1 NT - Mapid: 709
Download
CarteBlanche Ukraine 3.50 - Mapid: 575
Download
Venezuela Venrut 4.1 - Free map
Download
Mirror
Mapear V7.50-Mapas Electronicos Argentinos - Mapid: 900
Download
Philippine Islands - Free map
Download
Laos/Vietnam - Free map
Download
Samoa - Free map
Download
Indonesia 0.66 - Free map
Download
Greece 8.11 - Free map
Download
Cyprus - Free map
Download
Peru 0.49 (20/12/08) - Free map
Download
Download (Torrent)
Garmin City Navigator North America NT 2009 - Mapid: 325
Download (Torrent)
Garmin Chile Streets 2007 - Mapid: 724
Download (Torrent)
Garmin City Navigator Australia NT 2009 - Mapid: 358
Download (Torrent)
Garmin City Navigator Middle East NT 2008 - Mapid: 329
Download
Mirror
Garmin City Navigator Mexico NT 2008 - Mapid: 278
Download, part 1
Download, part 2
Download, part 3
Garmin Mexico GPS Atlas v3.1 - Mapid: 5080
Download, part 1
Download, part 2
Garmin Mexico GPS Atlas v4.2 - Mapid: 12080 (How do you unlock that?)
Download
Garmin City Navigator NT New Zealand 2009 - Mapid: 499
Download
GARMAP Southern Africa Streetmaps, Topo & Rec, March 2008
Mirror (Torrent)
GARMAP Indian Ocean Islands Streetmaps Version 1 Mauritius - Mapid: 1148
Download
Mirror (Torrent)
GARMAP East Africa Street Maps Version 1 - Mapid: 1095
Download
Mirror (Torrent)
GARMAP Nigeria Streetmaps, Topo & Rec Version 2 - Mapid: 807
Download
Mirror (Torrent)
GARMAP Southern Africa Streetmaps, March 2008 - Mapid: 1214
Download
Mirror (Torrent)
Roads of Russia with Routing 4.03 - Mapid: 1120
Download (Torrent)
Mirror, part 1
Mirror, part 2
Mirror, part 3
Mirror, part 4
Mirror, part 5
Mirror, part 6
Moldova 20.12.2008 - Free map
Download
Garmin Polska GPMapa 2008.3 - Mapid: 1326
Download
Garmin EU SpeedCams 2008 update 11
Download
MapSource Taiwan City Navigator ver 8.51 English - Mapid: 287
Download
Garmin Iceland GPS Kort v3.5 - Mapid: 830
Download (Torrent)
Czech Republic (ATLAS TJEKKISKE v7 NT) - Mapid: 579
Download (Torrent)
Map of Sri Lanka (Sri Lanka Route) - Free map
Download (Torrent)
Garmin Mapsource City Navigator Brazil NT v4 - Mapid: 334
Download, part 1
Download, part 2
Download, part 3
Download, part 4
TrackSource Brasil 5.12 - Free map
Download
Lithuania Topo 1.06 - Mapid: 857
Download (Torrent)
GM-MySin Installer v2.30 (Malaysia and Singapore) - Mapid: 5088
Download
GM-Borneo Installer v2.30 - Mapid: 5099
Download
The Following 4 Users Say Thank You to mike2111 For This Useful Post:
Old 01-17-2009, 17:27   #295 (permalink)
Member: 385577
Thanks Meter: 656
Originally Posted by beer2beer View Post
Hi there,
Try this one: Download
Regards
Mike
Old 01-17-2009, 18:01   #296 (permalink)
Member: 922453
Regards
Mike
It's working fine, thank you!
Old 01-17-2009, 22:44   #297 (permalink)
Member: 944132
Thanks Meter: 45
Garmin Greece Toponavigator Anavasi v3.90 routable
http://rapidshare.com/files/185134036/Jenas_Anavasi390.part1.rar
http://rapidshare.com/files/185111213/Jenas_Anavasi390.part2.rar
Old 01-18-2009, 07:28   #298 (permalink)
Member: 908415
Do you know where Garmin Topo Canada can be found, and if I can have both city navigator for NA AND topo Canada resident on a 60csx?
Old 01-18-2009, 14:15   #299 (permalink)
Member: 921590
Thanks Meter: 3
@jenas, I have downloaded Greece Anavasi v3.90 and i have tried to install it. I copied the unpacked map in the Garmin folder (mine is on E:\Garmin) and I ran the anavasi.reg and "destroied" my mapsource. I had to enter in regedit to make it work, becouse even if I reinstalled a new mapsource it didn't work. It had showed me a message like there is a problem with the "800" and to try to reinstall the mapsource. I've realised that there is a problem with the map, becouse the mapID is 800. Thanks and hope you can help me.
Dacian
Old 01-18-2009, 15:02   #300 (permalink)
Member: 11074
Thanks Meter: 10
DacianGarmin, you need edit file anavasi.reg and change drive to yours = E:
LinkBacks (?)
LinkBack to this Thread: http://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/
Posted By For Type Date
What is GARMIN XT V5 MIDDLE EAST? This thread Refback 06-29-2013 08:06
malaysia map for garmin xt carrotboy88 GPS devices , Navigators & Maps 1 01-19-2012 07:18
Garmin XT Canada Map jati_grewal GPS devices , Navigators & Maps 2 07-18-2009 13:10
maps for garmin xt billyprepo GPS devices , Navigators & Maps 1 03-11-2009 10:33
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
Garmin XT Canada Maps 2009 s3lekta Nokia Multimedia 0 09-21-2008 19:45
Page generated in 0.58521 seconds with 9 queries
