GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
04-01-2009, 05:07 | #781 (permalink) |
Freak Poster Join Date: Apr 2008 Location: KwaZulu-Natal, South Africa Age: 54
Member: 757575 Status: Offline Thanks Meter: 70 | Garmap Indian Ocean Islands Streetmaps V1 (MapID:1148) Alternate download http://www.megaupload.com/?d=LPESGYBB fugglefeet |
04-01-2009, 09:39 | #782 (permalink) | |
Insane Poster Join Date: Jan 2009
Member: 958380 Status: Offline Thanks Meter: 17 | Quote:
Yes, that's completely normal. You successfully installed MapSource and now MapSource complains that it can't find any maps. Install a map and everything will be fine. Greets, Frank | |
04-01-2009, 19:38 | #783 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 944132 Status: Offline Thanks Meter: 45 | Garmin Roads of Russia with Routing (Federal regions) Navicom v5.13 Ciryllic Code: http://rapidshare.com/files/216228103/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part1.rar http://rapidshare.com/files/216232502/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part2.rar http://rapidshare.com/files/216237645/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part3.rar http://rapidshare.com/files/216242632/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part4.rar http://rapidshare.com/files/216247444/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part5.rar http://rapidshare.com/files/216224273/Jenas_Roads_of_Russia_with_Routing_Ncom_v5.13_Ciryllic.part6.rar |
04-03-2009, 00:37 | #784 (permalink) |
Crazy Poster Join Date: May 2006
Member: 285241 Status: Offline Thanks Meter: 2 | Hi, I managed to unlock a map (Garmin City Navigator Australia NT 2009) using latest mapsource version 6.15.4 without installing the earlier version 6.13.7 : 1. Extract MapSource_6154.exe using WinRAR 2. From the extracted files, run MAIN.msi. This will install mapsource 6.15.4 and you don't really need to run Setup.exe. The software is now ready for use. 3. To unlock a map: Run a separate program UnlockWizard automatically installed on your computer when you install mapsource 6.15.4. When prompt, enter 25 character unlock code you got from Keygenerator and done, your map is unlocked. |
The Following User Says Thank You to WombatAu For This Useful Post: |
04-03-2009, 06:45 | #785 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | help mapsource not found!!! How to: Installation of software on a phone (Symbian S60 3rd Edition): Install Garmin Mobile XT Free Basemap: http://www8.garmin.com/software/Garm...emap_4xxxx.exe Install Garmin Mobile XT Support Files: http://www8.garmin.com/software/Garm...iles_4xxxx.exe Install Garmin Mobile XT for Symbian S60 3rd Edition: http://www8.garmin.com/software/Garm...tion_50020.exe Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card. Start the application. Select settings for text language, voice, unit and for Garmin Online. Exit the application. Open the file called GarminDevice.xml. It is located in the Garmin folder. Look for <Id>XXXXXXXXXX</Id> Use the keygenerator (http://forum.gsmhosting.com/vbb/show...04&postcount=4) to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL.txt) using Notepad. The file should be saved in the Garmin folder. More info here: http://www.megaupload.com/?d=UF9MMFF3 (Thank you Fugglefeet) Installation of maps: Download version 6.13.7 of MapSource: http://www8.garmin.com/software/MapSource_6137.exe (Don't use the latest version - it is not compatible with all the maps). Follow the following trick to hack the setup file so that it can be used to install MapSource clean and fresh without any prior installation of MapSource. Unpack or extract the content of MapSource_6137.exe downloaded using WinRAR. i got up to here then it said mapsource not found will not extract further |
04-03-2009, 10:30 | #786 (permalink) |
Junior Member Join Date: Apr 2007
Member: 488164 Status: Offline Thanks Meter: 0 | ive downloaded the maps, ive run the "CNEUNT2009.11Update_ENU.msi" file then it tells me - error reading file from c:/documents~city navigator europe mt 2009.22.gmap/[products/00263604/i07ada38.gmp. verify that file exists anyone? |
04-03-2009, 20:28 | #787 (permalink) |
Member: 944132 Status: Offline Thanks Meter: 45 | Garmin Topo Sweiz v2 Code: http://rapidshare.com/files/217057470/Jenas_Topo_Swiss_v2.part1.rar http://rapidshare.com/files/217061720/Jenas_Topo_Swiss_v2.part2.rar http://rapidshare.com/files/217066184/Jenas_Topo_Swiss_v2.part3.rar http://rapidshare.com/files/217053855/Jenas_Topo_Swiss_v2.part4.rar |
04-04-2009, 04:50 | #788 (permalink) | |
Member: 285241 Status: Offline Thanks Meter: 2 | Quote:
Regards, | |
04-04-2009, 06:36 | #789 (permalink) |
Member: 944132 Status: Offline Thanks Meter: 45 | Garmin Australia OZtopo V2.1 Roads Code: http://rapidshare.com/files/216964596/Jenas_Australia_OZtopo_V2.1.part01.rar http://rapidshare.com/files/216971596/Jenas_Australia_OZtopo_V2.1.part02.rar http://rapidshare.com/files/216976095/Jenas_Australia_OZtopo_V2.1.part03.rar http://rapidshare.com/files/217000561/Jenas_Australia_OZtopo_V2.1.part04.rar http://rapidshare.com/files/217004927/Jenas_Australia_OZtopo_V2.1.part05.rar http://rapidshare.com/files/217009572/Jenas_Australia_OZtopo_V2.1.part06.rar http://rapidshare.com/files/217014065/Jenas_Australia_OZtopo_V2.1.part07.rar http://rapidshare.com/files/217039127/Jenas_Australia_OZtopo_V2.1.part08.rar http://rapidshare.com/files/217043626/Jenas_Australia_OZtopo_V2.1.part09.rar http://rapidshare.com/files/217049206/Jenas_Australia_OZtopo_V2.1.part10.rar http://rapidshare.com/files/217070563/Jenas_Australia_OZtopo_V2.1.part11.rar http://rapidshare.com/files/217074894/Jenas_Australia_OZtopo_V2.1.part12.rar http://rapidshare.com/files/217079087/Jenas_Australia_OZtopo_V2.1.part13.rar http://rapidshare.com/files/217083287/Jenas_Australia_OZtopo_V2.1.part14.rar http://rapidshare.com/files/217087467/Jenas_Australia_OZtopo_V2.1.part15.rar http://rapidshare.com/files/217091815/Jenas_Australia_OZtopo_V2.1.part16.rar http://rapidshare.com/files/217096120/Jenas_Australia_OZtopo_V2.1.part17.rar http://rapidshare.com/files/217100344/Jenas_Australia_OZtopo_V2.1.part18.rar http://rapidshare.com/files/217109067/Jenas_Australia_OZtopo_V2.1.part19.rar http://rapidshare.com/files/217112933/Jenas_Australia_OZtopo_V2.1.part20.rar http://rapidshare.com/files/217116784/Jenas_Australia_OZtopo_V2.1.part21.rar http://rapidshare.com/files/217120502/Jenas_Australia_OZtopo_V2.1.part22.rar http://rapidshare.com/files/217124071/Jenas_Australia_OZtopo_V2.1.part23.rar http://rapidshare.com/files/217127441/Jenas_Australia_OZtopo_V2.1.part24.rar http://rapidshare.com/files/217130674/Jenas_Australia_OZtopo_V2.1.part25.rar http://rapidshare.com/files/217133828/Jenas_Australia_OZtopo_V2.1.part26.rar http://rapidshare.com/files/217136901/Jenas_Australia_OZtopo_V2.1.part27.rar http://rapidshare.com/files/216959731/Jenas_Australia_OZtopo_V2.1.part28.rar http://rapidshare.com/files/216948522/Jenas_Australia_OZtopo_V2.1.part29.rar |
The Following User Says Thank You to jenas For This Useful Post: |
04-04-2009, 09:44 | #790 (permalink) |
Junior Member Join Date: Mar 2009
Member: 999919 Status: Offline Thanks Meter: 7 | Roads of Russia 6.0 Topo MapID: 1281 Code: http://rapidshare.com/files/189146670/rr600_25january_200.part1.rar http://rapidshare.com/files/189146981/rr600_25january_200.part2.rar http://rapidshare.com/files/189147007/rr600_25january_200.part3.rar http://rapidshare.com/files/189146988/rr600_25january_200.part4.rar http://rapidshare.com/files/189146440/rr600_25january_200.part5.rar |
04-04-2009, 10:49 | #791 (permalink) |
Junior Member Join Date: Jun 2005 Age: 46
Member: 156102 Status: Offline Thanks Meter: 0 | south korea is there anyone with the map of south korea? http://garmin.kr/index.php?pgurl=etc/maps |
04-04-2009, 12:08 | #792 (permalink) |
Junior Member Join Date: Dec 2008
Member: 922453 Status: Offline Thanks Meter: 1 | I really need this one: http://www8.garmin.com/cartography/g...sp?sku=VSA003R. Someone? |
04-05-2009, 14:31 | #795 (permalink) | |
Junior Member Join Date: Apr 2008 Location: In my life Age: 41
Member: 749130 Status: Offline Sonork: WolF Thanks Meter: 0 | Quote:
This works 100% ! Greetz to all! Detailed explanation Do not use the setup from the windows folder!. Install from the folder IMG your desired language version, eg: CNEUNT2009Update_NLD To unlock, you get an unsolicited Mapsource update for you choose, Unlock the Wizard, you just start itself. This stands in your Garmin folder (Start -> All Programs -> Software -> Unlock Wizard. Use the keygen to unlock with MapID: 378 Search ID of your GPS: Through MapSource -> Tools -> Apparaat_ID fetch. Now the cards are UNLOCKED in Mapsource you can easily transfer them to your GPS TESTED , and 100% working! | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/ | ||||
Posted By | For | Type | Date | |
What is GARMIN XT V5 MIDDLE EAST? | This thread | Refback | 06-29-2013 08:06 |
malaysia map for garmin xt | carrotboy88 | GPS devices , Navigators & Maps | 1 | 01-19-2012 08:18 |
Garmin XT Canada Map | jati_grewal | GPS devices , Navigators & Maps | 2 | 07-18-2009 13:10 |
maps for garmin xt | billyprepo | GPS devices , Navigators & Maps | 1 | 03-11-2009 10:33 |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
Garmin XT Canada Maps 2009 | s3lekta | Nokia Multimedia | 0 | 09-21-2008 19:45 |
