Member: 385577
Thanks Meter: 656 | Let us all share our maps ! Requirements for maps to be included in the list: 1) All maps must be MapSource versions - not gmapsupp.img;
2) The map must be routable, and may not be prepared from a gmapsupp.img map;
3) New / Other maps to be included in the list must be in a better resolution than the existing maps. If you have a map, or have knowledge of a map that meets these requirements, please post the link here. Thank you! If you find this post useful, please say thank you..... What is the advantage of using MapSource?
I think the MapSource program is pretty much a 'must have'. In addition to the ability to load maps, the MapSource software has a lot of other capabilities, for example: - Maybe you are lucky. Maybe you can have up till 6 maps on your phone at the same time eg. gmapbmap.img (Basemap), gmapprom.img (internal map, used when you have US or EU maps), gmapprom1.img (internal map, used when you have both US and EU maps), gmapsupp.img (Supplemental maps, will be overwritten when you add new maps), gmapsup2.img and gmapoem.img (For OEM Company). But with MapSource you can have many more! (The maximum amount of map-tiles for your unit is the limiting factor.) You just merge more maps together so they will appear as one file (gmapsupp.img) on your device
- See all the cities, selected map details and POIs on your computer;
- Set up routes and find out distances. Helps you get an overall picture;
- Create and transfer waypoints to your device;
- View and edit .GPX (POI) files;
- Backup your waypoints from your device to a database (*.gdb) file on your computer;
- Find the lat/long positions of waypoints;
- Add description comments to your favourites/waypoints, like addresses and phone numbers;
- Interact seamlessly with Google Earth
= - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = How to ... Prepare your Garmin-device, Mobile, PDA - Nüvi, StreetPilot, etc.
Download the webupdater to update your device: http://www8.garmin.com/software/WebU...indows_242.exe - Garmin Mobile PC
Download the software here: http://www8.garmin.com/software/Garm...lePC_50060.exe - Phones, PDA, etc.
- Install Garmin Mobile XT Free Basemap: http://www8.garmin.com/software/Garm...emap_4xxxx.exe
- Install Garmin Mobile XT Support Files: http://www8.garmin.com/software/Garm...iles_4xxxx.exe
- Install the software for your phone, eg. Garmin Mobile XT for Symbian S60 3rd Edition. If your phone uses a different OS find the correct Garmin software here.
- Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card.
- Start the application.
- Select settings for text language, voice, unit and for Garmin Online.
- Exit the application.
- Open the file called GarminDevice.xml. It is located in the Garmin folder.
- Look for <Id>XXXXXXXXXX</Id>.
- Use the Keygenerator to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL.txt) using Notepad. The file should be saved in the Garmin folder. As default Notepad will save your file as a text file! You have to choose “save as” and change the file name from .txt to ALL FILES.
More info here. (Thank you Fugglefeet)
If you - after following the previous steps - start the application get a screen with 1) Purchase & Go!, 2) Begin Free Trial, 3) Enter Product Key, and 4) Connect to a Garmin GPS, then you have done something wrong! Did you save the file as "just" sw.unl? Did you save it into the garmin folder? Try to use your phones filemanager to locate the file and check it is called sw.unl only.
If your phone, after unlocking, is looking for a Bluetooth GPS and not the internal GPS go to TOOL > SETTING > SYSTEM > REMOTE GPS. Choose USE BUILT IN GPS > ENABLE it then click DONE. Install MapSource - Download MapSource version 6.13.7
It isn't compatible with the newest maps (2009 NT) from Garmin but it's the last MapSource version that provides you with the Unlock Wizard and also newer versions have compatibility issues with some free maps. - For a clean and fresh setup without any prior installation of MapSource
- Extract the content of MapSource_6137.exe (the file you downloaded in step 1) using WinRAR;
- From the extracted files, run MAIN.msi;
- Now run Setup.exe.
If you don't follow these steps exactly as listed, MapSource will abort the setup-process with an "Previous MapSource not found" error message. - Open Windows Explorer and navigate to the directory where MapSource is located. (Probably C:\Garmin)
- Rename MapSource.exe into MapSource_6-13-7.exe
If you want to have a localized version of MapSource you need to rename the corresponding .DLL too: In the same directory you'll find a lot of MapSourceXXX.dll files where XXX represents a language-code. (e.g. MapSourceRUS.dll = Russian, MapSourceDEU.dll = German, MapSourceESP.dll = Spanish, etc.). Pick the .DLL representing your language and rename it to MapSource_6-13-7XXX.dll (XXX being the language code) so you end up with e.g. MapSource_6-13-7RUS.DLL. Done. - The MapSource-installer has created shortcuts on your Desktop and in the Start-menu. You'll have to adjust them so that they
- represent the MapSource version (renaming them from MapSource > Mapsource 6.13.7) and
- point to the correct file (Properties > Link target)
It's just a piece of cake to do that... - Now download MapSource 6.15.6 from Garmin and
- install it. (Since you already have a installed version of MapSource you don't have to all the unpacking from above. Just run the .EXE)
- There is a patched version of MapSource 6.15.6, allowing you to save map-sets (.IMG) not only to SD-cards and Garmin-devices but to any of your local drives. If you want it, download it from here.
- Follow the above steps 3. - 5. accordingly to rename the file(s).
Congratulations, you have two simultaneous installations of MapSource and can now enjoy all the features. Install maps - Download the map you want;
- Install the map using the file called something with XXXXXX_ENU.msi - Not the Setup.exe - This will install the map only (this applies to "real" Garmin maps only – with other maps the file might just be called setup.exe);
- Unlock the map:
- Get a key generator which you can find here;
- Enter your GPS ID number and enter your MapID (scroll down to “custom maps”) in the key generator, and you have the unlock-code.
- Launch MapSource;
- In MapSource, click Utilities > Manage Map Products;
- Select the Unlock Regions tab, and click Add;
- Enter your 25-character unlock code and then a comment, if desired. Click OK.
For more info read the MapSource user guide
If you would like to have more maps, e.g. Garmin City Navigator Europe NT 2009 and Garmin City Navigator North America NT 2009 you can combine the maps and transfer them to your GPS.
Try it! Use Basemaps - What is a Basemap?
A Basemap is a map with limited detail and precision. - Limited? So, what it is good for?
It serves two purposes:- It gives you the possibility to navigate where none of you regular maps provides coverage.
- When you zoom out on your device it would take lots of processor power - and therefore time - to draw all the details of your regular map. Hence in such moments your device uses the Basemap.
- Isn't my device factory equipped with a Basemap?
Yes, it is. Garmin sells their equipment with one of two preinstalled Basemaps: Americas lite or Atlantic lite. - So why should I want different Basemap?
The two pre-installed Basemaps are limited to their region. They don't provide you with world-wide coverage. - But there is a WorldMap from Garmin. Why not use it instead?
It has no autorouting. - You convinced me. What shall I do?
Follow these steps: - Download the World-Wide routable Basemap v3.01 from the Garmin Website. (Here you can learn about the coverage.)
- Don't run the .EXE! Instead open it with - for example - WinRAR (Right-click).
- Navigate within the archive to the worldwide directory and extract the GMAPBMAP.IMG file to some place on your computer.
- Copy it into the garmin directory on your device.
- But this will delete my existing Basemap?! Shouldn't I save or keep it?
Yes, that would forever delete your pre-installed Basemap. If you want to save or keep it you should either- copy the original file to your computer, a CD or a DVD for possible use in the future. (Backups are always a very good idea! and you should take the chance to make a backup of your entire device) or you
- could rename the original Basemap to gmapoem.img and keep it parallel to the new basemap. Your device will handle the rest.
- The file I downloaded says iQue 3600. Can i really use it for my device?
Yes, you can. The only devices you possibly wouldn't use it for are the new Garmin units with 3D terrain. But these are factory supplied with the Worldwide Autoroute DEM Basemap. (If you accidentally deleted it, you can download a copy here.) Use POI Loader POI Loader is a free program from Garmin for your computer that lets you upload customized points of interest (POIs) to your compatible Garmin device. With the help of POI Loader, you can update your compatible Garmin GPS with the latest restaurants, safety camera locations, tourist destinations, etc. More info about poi here, and about POI Loader here
= - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = = - = Map list
Recent changes are marked in yellow. EUROPE - AdriaROUTE 2.20 - MapID: 708
Commercial streetmap of Bosnia and Herzegovina, Croatia, Macedonia, Slovenia Download
- Adria TOPO 2.10 - HR - MapID: 928
Commercial topographic map of Bosnia and Herzegovina, Croatia (original map scale 1:25.000) Download
- Adria TOPO 2.11 - SLO - MapID: 844
Commercial topographic map of Slovenia (original map scale 1:25.000) Download
- SCG Route 2.0 - MapID: 929
Commercial streetmap of Montenegro, Serbia Download
- Topo Czech 2.0 PRO - MapID: 1391
Commercial topographic map of the Czech Republic (original map scale 1:10.000; effective scale 1:25.000) The map supports automatic route calculation on road and street network and terrain shading in PC. The Topo map includes: cities, towns, road & street network, railroads, lakes, rivers, forests, elevation contour lines, trails. Download
- Eesti Teejuht 21.11
Commercial streetmap of Estonia - No installer Very detailed map with many topographic features but no contour lines. Download
- NaviGuide Hungary 5.1 NT - MapID: 709
Commercial streetmap of Hungary Lakes, rivers, cities, motorways, national and regional thoroughfares, and local roads, plus street level maps for 3051 cities. Also contains nautical chart data for Lake Balaton, with depth contours, spot soundings, navaids with view range and coverage and port plans. Download
- NaviGuide Hungary 5.2 NT BETA - MapID: 709
- GPS Kort Iceland v3.5 - MapID: 830
Commercial topographic map of Iceland (original map scale 1:50.000) It features contour lines distanced 20 meters. Download (Torrent) Download (Torrent)
- Lietuvos Topo 1.071 - MapID: 857
Commercial topographic map of Lithuania The map provides 75.000km of highways, county and residential roads with street level detailed maps of all settlements in Lithuania. Other objects includes lakes, rivers & canals (110.000km), railway lines, Kauno marios, Kuršių marios. Download
- GPMapa 2008.4 OEM - MapID: 1634
Commercial streetmap of Poland Version GPMapa 2008.4 includes over 2,2 millions of address points, 2829 detailed city and town plans, including 2602 plans provided with addresses and 277 plans bearing only names of the streets, 405 980 km of roads, including 307 044 km of asphalt roads and 98 036 km of dirt roads. 146 033 points of interests (POI), including photoradars and "Black Points". 44 cities inclusive if the building outlines (Augustów, Bartoszyce, Białystok, Brodnica, Bydgoszcz, Bytom, Chełmno, Częstochowa, Elbląg, Gdańsk, Gdynia, Giżycko, Gorzów Wielkopolski, Iława, Katowice, Kętrzyn, Kielce, Kościerzyna, Kraków, Krosno Odrzańskie, Lublin, Łódź, Mrągowo, Myślenice, Olkusz, Olsztyn, Ostróda, Poznań, Pruszcz Gdański, Radom, Reda, Rzeszów, Sopot, Starogard Gdański, Szczecin, Szczytno, Tarnów, Tczew, Warszawa, Wieliczka, Wrocław, Września, Zabrze, Zielona Góra). Download
- R.O.A.D. 2008 v3.01 - MapID: 1189
Commercial streetmap of Romania (original map scale 1:100.000). Covers all the cities, lakes and marshes of Romania, the Danube Delta and the shore of the Black Sea, all the large and middle size rivers, aprox. 75% of the small intermittent rivers and canals; european, national and state roads, highways A1 and A2; contour lines distanced 40 meters apart, railways, ******* runways, bathymetry data in a few selected areas in the Black Sea. Detailed maps reference scale 1:5000 or higher Detailed cities: Bucuresti, Suceava, Iasi, Oradea, Cluj-Napoca, Turda, Huedin, Timisoara, Arad, Targu Mures, Campulung Moldovenesc and Brasov (with street level information, city limits, industry, parks, forests, gardens, orchards and POIs) plus Danube Delta Dunarii (wetlands, canals, lakes, flats, toponames).
Download Part1 Part2 Mirror (Torrent)
- Slovakia Roads v6 - MapID: 1315
Commercial streetmap of Slovakia Download
- Navcity Turkey 2009.02 - MapID: 848
Commercial streetmap of Turkey The Basarsoft NavCITY Turkey 2009.02 contains current routing Detailcards of 81 turkish cities (Istanbul, Ankara, Izmir, Adana, Antalya, Bursa, Samsun, Konya, Kayseri, Denizli, Diyarbakir...) and all Cities of the South-Westcoast from Alanya to Ayvalik with 786.199 km of streets and 318.071 Points of Interest. Coverage map Download Mirror
- Aeroscan Ukraine 4.03 - MapID: 934
Commercial streetmap of Ukraine Detailed map of the Ukraine and metropolitan maps of Kiev and about 80 other Ukrainian cities and towns. In some cities house numbers are provided. Includes business and residential streets, rivers, lakes and shoreline details. Download (Torrent)
- CarteBlanche Ukraine 3.50 - MapID: 575
Commercial streetmap of Ukraine The map covers European, national, regional and local roads and provides detailed city maps of about 40 settlements including all regional centres as well as some other important cities. The remaining settlements are provided in the form of points and contours. It also shows railways, rivers, streams, lakes, parks, and forests. Download
- NavLux Ukraine Navigator (11.03.2009) - MapID: 1174
Source: Luxena Software Company Detailed map of the Ukraine with 250.000 km roads, 30.108 settlements and contours of buildings with address information. Download
- European POIs
- SpeedCams 16-04-2009 - Fix camera
Download Speedcam covering A, AND, B, BIH, BR, CH, CZ, D, DK, E, F, FIN, FL, GB, GR, H, I, IRL, IS, L, LT, N, NL, P, PL, RO, RUS, S, SK, SLO and UA. Furthermore Swedish Road Toll & Austria Road Toll.
This one really works (with the right speed limit), and these alerts will sound and become visible once, as you approach the POI location. If you remain under the user specified speed, you will get no more alerts. However, if you exceed that specified speed, a beep will sound every second to remind you of the alert, until either you slow down below the set speed or pass the POI. All use is at your own risk.
To install just copy the 6 files into /garmin/POI/ on your device.
Based on data from POI Plaza, Poi.cz, Poigps.com, gratispoi.dk and Speedcam****
RUSSIA - Roads of Russia v4.03 (translit.) - MapID: 1120
Commercial map of Russia The map presents entire Russia with a map scale of 1:100.000 (some regions 1:200.000). Maps of Oblast (Federal district) capitals are based on a scale of 1:10.000 with street level detail while maps of regional centres are based on a 1:25.000 scale and provide partial street level details. Other settlements are presented as points in the geographic centre of the settlement. (RU) Download (Torrent)
Mirror Part1 Part2 Part3 Part4 Part5 Part6 NORTH AMERICA - MetroGuide Canada v4
Commercial streetmap of Canada Provides detailed maps and points of interest throughout Canada using DMTI Spatial map data for all provinces in Canada, including provincial highways, controlled access highways and local roads. Coverage map Out of the box the product supports routing within MapSource but not on devices. Download (Torrent)
- MetroGold
With MetroGold you can make your GPS capable of autorouting with MetroGuide maps. MetroGold will upgrade your MetroGuide Europe or North America to have this functionality. You can upload up to 2GB of modified maps to your GPS. Download (Torrent)
- City Navigator Mexico NT 2008 - MapID: 278
Commercial streetmap of Mexico Coverage includes major metropolitan areas as well as major and intertown roads in Mexico. Coverage map
Download Part1 Part2 Part3
- Mexico GPS Atlas v4.3 - MapID: 12080
Commercial streetmap of Mexico The map covers more than 517.000km of highways, roads, streets, unpaved roads and trails all over the country. More than 280,000 towns and rural locations, providing street details with auto routing for over 2150 settlements. Address search with house number in the downtown area of Mexico City (Miguel Hidalgo, Cuajimalpa, Cuauhtemoc and Benito Juarez sectors), Naucalpan in State of Mexico, Ajijic and Chapala in Jalisco, Palenque in Chiapas, Empalme in Sonora, Valladolid in Yucatán and Ciudad Canatlan in Durango. International and state boundaries, lakes, rivers, national parks. Generally featuring 100m countour lines the Baja Peninsula shows 50 meters and selected regions of outdoor activity even 20m resulution. Download SOUTH AMERICA - City Navigator Brazil NT 2010 - MapID: 404
Commercial streetmap of Brazil Coverage includes major road coverage throughout Brazil and detailed coverage for Minas Gerais, Rio de Janeiro and Săo Paulo. Contains over 500.000 points of interest. Coverage
- TrackSource Brasil 6.02 – Free map
Free streetmap of Brasil Download MIDDLE EAST - City Navigator Middle East NT 2010 - MapID: 445
Commercial streetmap of Bahrain, Kuwait, Oman, Saudi Arabia, Qatar and United Arab Emirates. Coverage of the map depends on the region: Full coverage is provided for Bahrain, Kuwait, Oman, Qatar and United Arab Emirates while in Saudi Arabia only the major urban areas and intertown roads are covered. Download Mirror 1 Mirror 2
- Israel rute v.153 - MapID: 2009
Commercial streetmap of Israel - No installer Download AFRICA - East Africa Street Maps v1 - MapID: 1095
Commercial streetmap of Kenya, Tanzania and Uganda The map provides 92.000km of tar and gravel road network between the three countries and a comprehensive street level detail for all cities and selected towns in the East Africa region including Nairobi, Dar Es Salaam, Arusha, Moshe and Kampala. Download Mirror (Torrent)
- Southern Africa Streetmaps - MapID: 1214
Commercial streetmap of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe. Contains more than 750.000km road data across the nine countries and street level data for more than 1700 cities, towns and villages in South Africa and other major cities in the south african region. It also provides routable roads and tracks for 55 game reserves and parks in Botswana, Malawi, South Africa and Zambia. Download
- Southern Africa Streetmaps, DEM 2009 - MapID: 1218
Commercial topographic of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe. Contains more than 750.000km road data across the nine countries and street level data for more than 1700 cities, towns and villages in South Africa and other major cities in the south african region. It also provides routable roads and tracks for 55 game reserves and parks in Botswana, Malawi, South Africa and Zambia. Download (Torrent)
- Southern Africa Streetmaps (Topo & Rec), 2009 - MapID: 1215
Commercial topographic map of Botswana, Lesotho, Malawi, Mozambique, Namibia, South Africa, Swaziland, Zambia and Zimbabwe The map provides the same information as the normal Southern Africa Streetmaps plus 20m contour lines, rivers and forests for the nine southern African countries and farm boundaries and names for South Africa and Namibia. Download (Torrent)
- Garmin Tunisia v11 Topo & Road Map - MapID: 223
Free topographic map of Tunisia Download
- Nigeria Streetmaps, Topo & Rec v3 - MapID: 1418
Commercial topographic map of Nigeria The map provides contour lines of 100m and more than 135.000km of road data including street level data for Lagos and Abuja. Download (Torrent) ASIA - Laos and Vietnam (Oct. 2008)
Free streetmap of Laos and Vietnam The mapset was originally created from publically available sources and was from thereon enhanced by 1sec tracklogs.
Source: asiaGPS Download
- GM-MalSing v2.30 (Gold version, 2008-09-24) - MapID: 5062 RgnID: 1
Streetmap of Malaysia and Singapore
Source: www.malsingmaps.com/ Download
- Indonesia v0.66 (2008-12-30)
Free streetmap of Indonesia The map covers entire Indonesia, incl. Bali
Source: navigasi.net Download
- Indian Ocean Islands Streetmaps Version 1: Mauritius - MapID: 1148
Commercial streetmap of Mauritius Provides 5.700km of road and street network for Mauritius and its various resorts, cities and towns with street level detail for Port Louis and other towns. Download Mirror (Torrent)
- HongKong Routable Version 4
Commercial streetmap of HongKong This map is fully "navigation-ready". The best, most accurate english-language GPS mapset of Hong Kong available anywhere. The map is also available as a "transparent" mapset so that it can be used with maps of China from other vendors. The October 15 build allows this map to now be used with the most recent versions of MapSource. Download
- RoadGuide Philippines
Free streetmap of Philippines The map provides general coverage of Luzon, Visayas and Mindanao with street level detail for about 50 cities and towns. It is available in two versions: one for the general public and a much more detailed for contributors.
Source: RoadGuide Philippines Download
- Sri Lanka Route
Free streetmap of Sri Lanka Download
- City Navigator Taiwan v8.51 English - MapID: 287
Commercial streetmap of Taiwan Download OCEANIA - City Navigator Australia NT 2009 - MapID:358
Commercial streetmap of Australia The map provides highly detailed maps of motorways, regional arterials, local and Outback roads. Coverage Download (Torrent)
- City Navigator New Zealand NT 2009 - MapID: 499
Commercial streetmap of New Zealand Provides detailed national street network coverage, including major motorway infrastructure updates and link roads, such as Auckland Motorway Interchanges and Waikato SH1 Mercer to Longswamp, for all of New Zealand with detailed coverage for major metropolitan areas as Auckland, Wellington, Hamilton, Christchurch, Dunedin and Stewart Island. Coverage Download
- New Zealand Open GPS Maps Project
Free streetmap of New Zealand The project is based around purchased LINZ | CORAX data, and added to by the regional mappers. New or changed roads are added via extracts from LINZ and / or GPS track logs. The maps have a rich set of POI that is fed from the Zenbu project - another open source project. ESRI shape files can be extracted from the maps for use in other mapping applications. Download WORLD - WorldMap 4.06
Commercial streetmap WorldMap provides basic worldwide map detail, including areas where no other detailed maps are available. These general maps display political boundaries, coastlines, cities and towns, major interstates and highways, lakes and rivers, and urban areas and railroads. WorldMap also includes U.S. Interstate Exits information, including fuel and service stations, restaurants, hotels, campsites, hospitals and banks. [B]WorldMap is generally recommended only if no other detailed maps are available for the area of interest. Download
Thanks to meisterfrank for the new layout and all the map info..... |
