GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
09-01-2009, 08:20 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1109388 Status: Offline Thanks Meter: 0 | GPS Timekeeping While most clocks are synchronized to Coordinated Universal Time (UTC), the atomic clocks on the satellites are set to GPS time. The difference is that GPS time is not corrected to match the rotation of the Earth, so it does not contain leap seconds or other corrections which are periodically added to UTC. GPS time was set to match Coordinated Universal Time (UTC) in 1980, but has since diverged. The lack of corrections means that GPS time remains at a constant offset with International Atomic Time (TAI)(TAI - GPS = 19 seconds). Periodic corrections are performed on the on-board clocks to correct relativistic effects and keep them synchronized with ground clocks. The GPS navigation message includes the difference between GPS time and UTC, which as of 2009 is 15 seconds due to the leap second added to UTC December 31 2008. Receivers subtract this offset from GPS time to calculate UTC and specific timezone values. New GPS units may not show the correct UTC time until after receiving the UTC offset message. The GPS-UTC offset field can accommodate 255 leap seconds (eight bits) which, given the current rate of change of the Earth's rotation (with one leap second introduced approximately every 18 months), should be sufficient to last until approximately year 2300. As opposed to the year, month, and day format of the Gregorian calendar, the GPS date is expressed as a week number and a seconds-into-week number. The week number is transmitted as a ten-bit field in the C/A and P(Y) navigation messages, and so it becomes zero again every 1,024 weeks (19.6 years). GPS week zero started at 00:00:00 UTC (00:00:19 TAI) on January 6 1980, and the week number became zero again for the first time at 23:59:47 UTC on August 21 1999 (00:00:19 TAI on August 22 1999). To determine the current Gregorian date, a GPS receiver must be provided with the approximate date (to within 3,584 days) to correctly translate the GPS date signal. To address this concern the modernized GPS navigation message uses a 13-bit field, which only repeats every 8,192 weeks (157 years), thus lasting until year 2137 (157 years after GPS week zero). Laser removal Nature's sunshine diabetes |
Oceanus Men's Atomic Timekeeping Watch #OCWM700TDA-1A | IPMART | ipmart WebShop | 0 | 02-10-2010 15:40 |
Could a GPS Phone be used as GPS receiver? | navid | GPS devices , Navigators & Maps | 10 | 09-01-2009 22:45 |
Stopwatch and Multi-Media Timekeeper Time Producer from Seiko | IPMART | ipmart WebShop | 0 | 10-27-2008 07:40 |
100-Lap Memory Large-digit Stopwatch, Metal Large-Digital Stopwatch, Metal Timekeeper | IPMART | ipmart WebShop | 0 | 10-27-2008 03:40 |
Sport Stopwatch, Cum Split, Clock, Timer, Stopwatches, Timekeeper, Chronograph, Chron | IPMART | ipmart WebShop | 0 | 10-24-2008 08:00 |
