GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
02-06-2010, 20:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | How to remove preinstalled maps on nuvi 1200? got a nuvi 1200 model.it came with pre-installed maps of EU central. Installed the complete map of EU on the memory card but it wont recognize the complete version. It will default to the internal pre-installed one. Tried to find where the pre-installed is but cannot find it. Usually it is in the Garmin folder but its practically empty. Any help appreciated thanks |
02-10-2010, 13:24 | #2 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1167958 Status: Offline Thanks Meter: 0 | Quote:
In Explorer -> Folder options -> turn "ON" show hidden and system files and you'll see it. If You plan to remove it, backup before deleting. Do not delete other files in "System" folder. If you'll put another map on device rename file as preinstalled "gmapprom.img", on SD should be named "gmapsupp.img" and in Garmin folder (no folder "System") | |
02-10-2010, 14:17 | #3 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | mate all files and folders are set to visible. yet cannot find any .img file at all. Its really weird. The problem is that it is not allowing me to use another map of EU which is a later version and of all western not just central. Its sticking to the one that is pre installed. No System folder exists (not even as a sub folder). The only folders present in the root are... Garmin GPX help keyboards reports help text jpeg vehicle voice |
02-10-2010, 18:53 | #4 (permalink) |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | Connect your nuvi to PC, open root folder on nuvi (to show visible folders like in your post above), then type in explorer's address bar: "\.system" (without quotes) Do not copy new map images to 'Garmin' folder - make new one named 'Map' (in root) and copy map(s) here. If I remember correctly, mapsets can be named anything (with IMG extension!) - this way you can add more maps. Last edited by XisiX; 02-10-2010 at 18:58. |
The Following User Says Thank You to XisiX For This Useful Post: |
02-10-2010, 19:10 | #5 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | you are great! found them!! yes they are there. problem now is that the space left is small. gonna try change extension to the one installed to see if the unit will see the one on the memory card. |
02-10-2010, 19:26 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | just placed one map in the .system folder named as gmapprom.img together with its unlock file and another map on the memory card as gmapsupp.img together with its unlock file. worked perfectly. |
Someone needed to show me how to remove glued UEM on Nokia's!! | MC Harami | Nokia Hardware & Hardware Repair | 17 | 02-08-2011 10:38 |
How to remove security code on Sony J5? | Bogi | Sony | 2 | 01-29-2002 21:21 |
How to remove security code on Maxxon Epsillon | 43e08 | Various | 2 | 11-07-2001 21:27 |
How to remove phone lock on Z18 | acyl2000 | Sony | 0 | 09-24-2001 05:53 |
how to remove SP lock on Ericsson s868 | Tim | Old Ericsson Phones & Sony Phones | 3 | 07-15-1999 22:33 |
