GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-15-2009, 20:57 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 948179 Status: Offline Thanks Meter: 0 | HTC Touch HD satnav HELP!!! ASAP I know there are different threads and posts for this but after anhour of searching and finding dead links i have decided to give up. If anyone could give me these links and a quick how to guide that would be mega appreciated and will forward links to this thread to all the HTC touch HD forums Im a member of. Many thanks in advance! |
01-17-2009, 21:48 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Denmark Age: 57
Member: 385577 Status: Offline Thanks Meter: 656 | Quote:
Here you find software and maps for Garmin..... Do not use the software for Garmin Mobile XT for Symbian S60 3rd Edition, but get the software for windows mobile here: http://www8.garmin.com/software/Garm...ile_50020w.exe Read the "how to" for information regarding installation.... Regards Mike | |
The Following User Says Thank You to mike2111 For This Useful Post: |
02-05-2009, 23:17 | #6 (permalink) | |
Regards Mike | |
02-06-2009, 15:04 | #7 (permalink) |
Member: 960491 Status: Offline Thanks Meter: 0 | hi there Yes i renamed or called the file name SW.UNL , but to be sure do you actually type in unl or do u kust type in SW and save as unicode or something? I saved it in notepad as decribed. and yes i saved it in the garmin folder in the storage card storage card/garmin/ To be sure which of the two keygens do you use Part 1 or Part 2 ? That bit is not very clear. |
02-06-2009, 15:19 | #8 (permalink) | |
1) Enter your units id here 2) Select software product 3) Select map product When you want to unlock the software, you type your units id into the first section, and press "gererate" in section 2 (Select software product). The key you generate here is the one you put into sw.unl. When you want to unlock maps, you type your units id into the first section, and press "gererate" in section 3 (Select map product). Regards Mike | |
02-06-2009, 15:58 | #9 (permalink) |
Member: 960491 Status: Offline Thanks Meter: 0 | hi mike Do i have to install the maps and the map unlock key before i will get rid of that Free trial, Purchase and Go, screen at the start? Also if you copy and past the unlock key to notepad is that ok or do you have to manually type it? Also when iam saving in note pad do i just type in the save as box= sw.unl and leave the other 2 boxes for Save as type and encoding alon? |
02-06-2009, 16:00 | #10 (permalink) |
Member: 960491 Status: Offline Thanks Meter: 0 | hi mike Do i have to install the maps and the map unlock key before i will get rid of that Free trial, Purchase and Go, screen at the start? Also if you copy and past the unlock key to notepad is that ok or do you have to manually type it? Also when iam saving in note pad do i just type in the save as box= sw.unl and leave the other 2 boxes for Save as type and encoding alone? And last question. the unit ID....is that Card Id or device Id or one of the other 2 id numbers. cheers for the help |
02-06-2009, 16:37 | #11 (permalink) | |
You can just copy the key into notepad ... When you save, you must write "sw.unl" and select Save as .... Then select unicode. You can open your file manager on your phone and check if the file has the right name .... It depends on whether you save the map on an SD card or phone memory. Now I do not know your phone, so you must try on you on ... On my phone (Nokia N73 running version 5.00.20) there is only one number.... Regards Mike | |
02-06-2009, 16:51 | #13 (permalink) | |
Read the "How to" to install software and maps.... There is NO map of India for Mapsource, but you can find a free map of India here: http://mapcenter2.cgpsmapper.com/get...inst&prev=6326 I don't know how the resolution is..... Regards Mike | |
HTC Touch HD2 satnav HELP!!! | arekbedwort | GPS devices , Navigators & Maps | 0 | 10-09-2009 00:32 |
HTC TOUCH HD ..plz help | saghi | HTC & PDA WM( With Touchscreen) | 2 | 07-19-2009 10:57 |
htc touch hd i need help please!!!! | danwood84 | HTC & Smartphones ( WM Without Touch) | 0 | 03-17-2009 16:27 |
Help - Coreplayer on HTC Touch HD (BLACKSTONE)? | Metalboz | HTC & Smartphones ( WM Without Touch) | 0 | 11-27-2008 23:17 |
