Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011
Member: 1528218 Status: Offline Thanks: 36
| IGO Primo 9.2.0.192885 Fullbackup I uploaded my fullbackup of the new Primo version. Only resolutions supported in the data.zip : 480x272 and 800x480 Please read all before you proceed! Inculded things All I had in my Primo collection, that is: Full support for all voice types. Normal, TTS and TTS pro (Nuance) voices - you cann add or delete what you prefer. Some skins and the full utility folder for the map changer. All files I had for voice recognition, the mic symbol shows up but I can not further test as my device has no microphone ![]() Additional notes I included my sys.txt, which should be adjusted to your needs for the first start. Several parameters that might be of interest are already present but might be commented out - so check it first! If you need a different screen resolution you can adjust the sys.txt in the [rawdisplay] section : screen_x=800 screen_y=480 class="landscape" Change to your screen resolution and also change the settings for the [interface] section for the 480x272 resolution. If your resolution is below that you might get a non matching display on the screen, so test at own risk if your resolution is not supported. The skins are included but not active yet, you have to do this yourself. TMC might not work as I noticed with other releases that it is device specific. Password for all: downunder Installation Unpack the archive to the root of your SD, the folder "primo" will be generated. Add the contents of your choice. Set up your device/unlock/menu for the path and filename of the MobileNavigator.exe in the primo folder. I removed the settings in the save folder so you should be asked to do the normal configuration at first start. Please make sure you checked the settings for your GPS port in the sys.txt! I had the problem that primo crashed when I selected a different voice. The voice could be selected and tested, but when clicked on "back" primo crashed. I solved this by deleting the vioce related entries inside the system.ini located in the folder primo/save. After that all was back to normal. Since I don't know what caused it I thought it might be good to add this note. Download :Klick here: And don't ask for a password or how to download the file. If you need, help is available at the download site. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
