GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-28-2015, 21:06 | #16 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1996160 Status: Offline Thanks Meter: 195 | As said many times before: generally speaking, you can only use a map if there's a meta available & you're running a compatible navcore. Of course there are exceptions which are detailed on the other forum but just get up & running first then you can start experimenting/learning the tricks later. |
01-29-2015, 11:49 | #17 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2260504 Status: Offline Thanks Meter: 0 | Hi i try 2 methods and both fail because no space in disk. First i try to copy the folder iberia to gps and delete the older one but it says the disk if full and i need extra 65mb. Then i try the automatic installer and patcher and also say error because no space in disk... Any ideia? Thanks |
01-29-2015, 13:09 | #20 (permalink) |
Member: 2260504 Status: Offline Thanks Meter: 0 | I format 8GB Card in fat32 and copy the content of older card to new card and insert on GPS but now i cant access card it says F:its not accessible Error E/S of device Its possible that gps dont support 8GB card (Too big for gps)? Thanks |
01-29-2015, 13:18 | #21 (permalink) | |
Member: 1996160 Status: Offline Thanks Meter: 195 | Quote:
