Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 01-28-2015, 21:06   #16 (permalink)
Member: 1996160
Thanks Meter: 195
The features are map and navcore specific so, for example, you can have a map with cspeech/ASR/IQroutes etc but it will only run properly on a compatible navcore/application. Similarly you could have fully functioning/loaded/later navcore but that won't make a basic map any better.
As said many times before: generally speaking, you can only use a map if there's a meta available & you're running a compatible navcore. Of course there are exceptions which are detailed on the other forum but just get up & running first then you can start experimenting/learning the tricks later.
Old 01-29-2015, 11:49   #17 (permalink)
Member: 2260504
Hi i try 2 methods and both fail because no space in disk. First i try to copy the folder iberia to gps and delete the older one but it says the disk if full and i need extra 65mb. Then i try the automatic installer and patcher and also say error because no space in disk... Any ideia? Thanks
Old 01-29-2015, 12:05   #18 (permalink)
Member: 2260504
Old iberia folder has 179MB and the new one 5993 has 259MB. With older iberia folder gps disk only have 22MB free. Thanks
Old 01-29-2015, 12:45   #19 (permalink)
Member: 2260504
Sorry for ignorance, i just see that i have a 256MB sd card, i put a 8GB sd card now to test...
Old 01-29-2015, 13:09   #20 (permalink)
Member: 2260504
I format 8GB Card in fat32 and copy the content of older card to new card and insert on GPS but now i cant access card it says
F:its not accessible
Error E/S of device
Its possible that gps dont support 8GB card (Too big for gps)? Thanks
Old 01-29-2015, 13:18   #21 (permalink)
Member: 1996160
Thanks Meter: 195
Error E/S of device
To save me repeating things, see here Using an SDHC card in older devices
Old 01-29-2015, 13:31   #22 (permalink)
Member: 2260504
Hi just upload an image here
[HOW TO] Using an SDHC card in older devices
Old 01-29-2015, 13:55   #23 (permalink)
Member: 2260504
Thanks for the help justmebrowsing
Old 01-29-2015, 14:56   #24 (permalink)
Member: 1996160
Thanks Meter: 195
no worries; aka biggerdave
Page generated in 0.19170 seconds with 8 queries
