GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
09-28-2008, 18:37 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 872191 Status: Offline Thanks Meter: 10 | Need help to install UK 7.25 maps to TomTom One 3rd Edition I have the Meta.txt file inside the map folder (United_Kingdom_and_Republic_of_Ireland_725.1871) I have a V7 & V8 keygen , but no matter what i cannot get the maps to work on my tomtom . Now rather then bang on about what i am doing / done can someone please simply guide me over it on msn please as my patience is wearing thin as been trying for afew hours now and fruitless results from google etc so if someone can post of talk me over it on msn for some more detailed help its much apprechiated . my msn is : Code: [email protected] Thanks Rented |
09-29-2008, 01:56 | #2 (permalink) |
No Life Poster Join Date: May 2006
Member: 283999 Status: Offline Thanks Meter: 1,203 | The keygen does not look for the Meta.txt in the map folder. It looks for it in the Progs folder. Check that it is in there and leave it there. If you are using the Official Navcore v8 as downloaded from TomTom Home, the keygen will NOT patch it. It WILL patch official Navcore v7 though. All this has been written and rewritten again and again and......................... Look at this post: http://forum.gsmhosting.com/vbb/show...postcount=2159 Apart from the extra meta txt which was included in that keygen upload ( which you are told to ignore anyway) it should be the same as the one you have. |
The Following 2 Users Say Thank You to rytenuff For This Useful Post: |
09-29-2008, 02:23 | #3 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 433671 Status: Offline Thanks Meter: 118 | Quote:
When you are creating an unlocking file for any map's .meta code, you'll need: 1) The keygen 2) meta.txt containing the codes reuqired to unlock that particular map. Both the keygen and the meta.txt file needs to be in the same folder. If you want to be lazy (like me), then do the following: 1) Create folder on called tt7 on drive c: of your PC. 2) Make sure you have the following files in the folder a) keygen b) an up to date meta.txt c) <MAP>.meta - substitute map you want unlock in <MAP> 3) Start a DOS window. 4) Type 'cd..' (repeat as many times as needed) down to root directory of your PC. You should only see c:> when you reach there 5) Type 'cd c:' 6) Type 'tt7_keygen . <DEVICEID>' 7) You should get ok. 8) Copy both the <MAP>.meta and <MAP>.meta.dct to the map folder of your phone. 9) Delete both <MAP>.meta and <MAP>.meta.dct from the tt7 folder. 10) Copy another <MAP>.meta to TT7 and repeat from 3 tt7_keygen and tt8_keygen needs the parameters <path to map> and <deviceID> after it. If you substitue a . in place of <path to map>, it looks for the first <MAP>.meta it can find in its current folder and generates an unlock code for that particular map. Hope this helps. | |
The Following 2 Users Say Thank You to Ozling For This Useful Post: |
09-29-2008, 17:55 | #4 (permalink) |
Member: 872191 Status: Offline Thanks Meter: 10 | thank you for the replies , turns out i needed to update and patch the navcore to make the maps work and to apply the payches to home so it worked correctly Thanks for the help , the instructions above where very helpful thank you |
The Following User Says Thank You to Rented For This Useful Post: |
07-13-2010, 21:24 | #5 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1342603 Status: Offline Sonork: hslaw Thanks Meter: 0 | hello all hi everyone.im very new to all this sat nav stuff.... i got a tomtom one 3rd edition 1 gb... a friend gave it to me...i wanted to remove all of his details off it.. i connected it to my computer...and formatted it..only thing is i never made a back up of it..so now i cant get my tomtom to work... can anyone please please help me.....as my girlfriend is already after biting my head off and told me that i better be able to fix it...as we have planed a trip around ireland over the summer holls.... i need to get the maps for the UK and ROI If anyone can help me with this... i would be much obliged.. many thanks |
tomtom one 3rd edit map key | tailsnz | Phone Unlocking Codes & Maps | 1 | 03-30-2010 14:40 |
TomTom One 3rd Edition | davethegooner | GPS devices , Navigators & Maps | 1 | 11-10-2009 22:35 |
TomTom One 3rd edition or Naviigator 6 (PDA) - Map of New Zealand Wanted | TheSubmariner | GPS devices , Navigators & Maps | 0 | 10-15-2009 02:51 |
How to install Navigation software & maps on TomTom XL?? | Wais777 | GPS devices , Navigators & Maps | 0 | 01-04-2009 21:53 |
HQRP Car Cigarette Lighter 12V Charger Replacement for TomTom One, 3rd Edition, One X | IPMART | ipmart WebShop | 0 | 09-16-2008 08:40 |
