GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-01-2007, 12:21 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 268715 Status: Offline Thanks Meter: 0 | Route 66 Mobile 7 WMS 7.0.2992 For Windows Mobile Smartphone Software: http://rapidshare.com/files/9992725/...-2006.zip.html Maps: http://rapidshare.com/users/KOH87I Installation: 1. Copy all files onto SD card. 2. Insert SD card into phone and the installation process should start automatically. If not, navigation to \Storage Card\2577\ and install either the signed or unsigned "ROUTE 66 N7.CAB" file. 2. When installation is completed, exit Route 66 if it starts automatically. 3. Copy either either unsigned or signed ROUTE66N7.exe into "\Storage Card\Program Files\Route 66\" or "\Program Files\Route 66\" depending on where you installed it. 4. Start Route 66 and when asked to activate, select Internet. 5. Enter 16 "a" as the activation key ("aaaaaaaaaaaaaaa"). NOTE: You must download a map and place it into "\Storage Card\maps\" or else you will a "one or more files are missing" error. I am looking for USA maps, particularly Southern California. Does it anyone have it? Last edited by ladude626; 01-03-2007 at 12:14. |
01-07-2007, 10:26 | #2 (permalink) |
Junior Member Join Date: Aug 2006 Location: Neverland Age: 46
Member: 332615 Status: Offline Thanks Meter: 0 | i have try it on my Qtek 8310 it installs perfectly (i copy the cr@cked exe after) but when i start it it doesent ask me to enter an activation code, and when i try to load a map after few seconds it exits the application! any help; |
01-08-2007, 00:39 | #4 (permalink) |
Member: 263696 Status: Offline Thanks Meter: 0 | Works fine in my c500 and mobile 2003se, with Iberia map. I install the software as described by poster and after this reboot the smartphone, after reboot, start application and the registration appear, only after registration i can see the map. Right now all works fine. |
01-08-2007, 08:33 | #5 (permalink) | |
Junior Member Join Date: Nov 2006 Location: Czech / Teplice Age: 65
Member: 386949 Status: Offline Thanks Meter: 0 | NEED CZECH MAPS if somebody have it?? Quote:
NEED CZECH if somebody have it?? no problem with registration, see map / (All install on memory card). Thanks to ladude626 for share | |
01-08-2007, 11:00 | #7 (permalink) | |
Member: 386949 Status: Offline Thanks Meter: 0 | 1 post, 2nd link you have US PAC-NW and USA EAST!!!! Quote:
01-08-2007, 14:08 | #8 (permalink) |
Member: 324134 Status: Offline Thanks Meter: 0 | Problems to load map Hello, With the installation everything is fine, but when route 66 ask for a map and I choose one nothing happend. And the application hangs up. I had the Macau and Germany map. Does somebody has a tip for me? greets, NoFear |
01-09-2007, 02:12 | #10 (permalink) |
Junior Member Join Date: Jan 2007
Member: 426391 Status: Offline Thanks Meter: 0 | Thanks for the software...everything installed fine on my cingular 3125 (qtek 8500, HTC Star trek) including the activation key, only problem is that when I open the East map (only map installed) I get a message that says not enough memory to open map. Everything is installed on a 512MB microSD card. Total file size for the complete installation was 388.4MB....what size card is everyone else using? |
01-09-2007, 03:15 | #11 (permalink) | |
Member: 268715 Status: Offline Thanks Meter: 0 | Quote:
01-09-2007, 04:06 | #12 (permalink) |
Member: 426391 Status: Offline Thanks Meter: 0 | Thanks for the reply...I soft reset the phone to insure that no apps were running and I still get the same message....I'll try to install the app in a 1GB microSD to be sure that it's not the card instead of RAM, but you are probably right. shucks.. it was looking promising. Got any leads on Mapopolis Maps for Windows smartphone?? |
01-10-2007, 01:09 | #15 (permalink) | |
Junior Member Join Date: Jan 2006
Member: 222554 Status: Offline Thanks Meter: 0 | Quote:
I tried different things: - Copy all folders to root of storagecard. (tried also with empty one) - Install CAB-file, cause autorun don't seem to work. - Installed on card (on phonememory neither works) - After installation rogram startup automatic. - Stop program with taskmanager, cause there aint no option in R66 to close the app. - Overwrite R66...exe - Reboot phone - Start R66 - I need to choose language, it says welcome to R66, choose map, it hangs. 1 time I got further than this, by modifying "ActivationKey.dat" that is placed in memorycard-root after installation. I copied to desktop and renamed to .txt Then type 16 aaa's and save. Replace the item on MC and start R66. After choosing Map, it showed me legal notice, and then hangs. I think I'm warm, but I don't succeed to get furher. Any help is welcome!! | |
Netwasp Release FlashThemes Player for Windows Mobile SmartPhone | Netwasp | HTC & PDA WM( With Touchscreen) | 0 | 01-29-2008 22:23 |
CoPilot for Windows Mobile 5 Smartphone | ipguy | HTC & PDA WM( With Touchscreen) | 0 | 11-01-2006 07:05 |
