GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
10-21-2007, 06:45 | #152 (permalink) |
Junior Member Join Date: Oct 2007 Location: Australia
Member: 608577 Status: Offline Thanks Meter: 0 | voice directions work with route 66 select a voice and if that doesnt work just try pressing any number 9 it is the volume mute button and also make sure your phone is not on silent not sure if that affects it but anyhow try it |
10-21-2007, 14:39 | #154 (permalink) |
Member: 614289 Status: Offline Thanks Meter: 0 | so . i have this problem unsolved. i installed everything but when i click on route 66 it dissapears. i did the reset to factory settings.. but still the same problem. i even installed route 66 once again.. same problem . i have maps installed too . what can i do ? pls help ? |
10-21-2007, 18:24 | #156 (permalink) |
Member: 608347 Status: Offline Thanks Meter: 0 | I have Route66 all signed to my phone and installed but i can't get it to work because of the resource error. I understand from reading this thread that its because my maps isn't in the correct place but i can't correct a system folder on the memory card as it says its already in use even though i've search on both phone and memory card and found no such folder. Shall i just format the memory card and re do it all? How can i make a system folder if its taken supposedly. I don't have a pc card reader and am doing it by transfer it to the memory card via Nokia software and installing is that ok? Tomtom worked fine. |
10-21-2007, 23:21 | #157 (permalink) | |
Member: 613446 Status: Offline Thanks Meter: 0 | Quote:
Route 66 comes up very briefly and then goes back to applications menu. If i quickly press options i see activate by sms, internet etc but even that disappears after about 1 second. I just dont get it! Ive done several factory resets and have maps installed. Any help would be much appreciated | |
10-22-2007, 10:13 | #159 (permalink) | |
Ive got another version of it (the correct one i think) but i need to get it signed or a cert for my phone. Ive asked on a few posts here but no luck getting a cert as of yet.............help! Last edited by skribble; 10-22-2007 at 10:21. | |
10-22-2007, 14:15 | #160 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | what version are you using? I use verion 7.3.534 and I dont have voice either. The volume is at max and when I press number 9, the pix of a speaker with a cross appears and when I press it again, it disappears but there is still no voice. |
10-24-2007, 03:54 | #162 (permalink) | |
Member: 610417 Status: Offline Thanks Meter: 0 | Quote:
Did you install with the .unsign.crack version that was posted on here?? if you did, it would have installed with voice, just no maps | |
10-24-2007, 03:57 | #163 (permalink) | |
http:///vbb/showth...=337658&page=7 post #101 get it sign yourself, faster and you don't have to wait | |
10-24-2007, 11:23 | #164 (permalink) |
Member: 616328 Status: Offline Thanks Meter: 0 | Hi guys, I finally solved most problems followed above posts, and it works in my N95 very well. thanks lots. A little question is does route66 UK map support 7 digit postcode search? if yes, where I can get it? thanks |
10-24-2007, 14:24 | #165 (permalink) |
Member: 177568 Status: Offline Thanks Meter: 147 | I installed the crack version that I downloaded from this forum. It's v7.3.545.multilanguage.s60v3.x.symbiaos9.x.crack.u nsign.sis. Can you please post here the version that you installed, I might have to try a different one. |
Route 66 on Nokia N96 | occ | GPS devices , Navigators & Maps | 2 | 03-03-2009 08:29 |
Keygen for Navigator on Nokia N95 | AirSac | Nokia Multimedia | 4 | 03-18-2008 22:20 |
Route 66 on N91 Problems | alpinanady | Nokia Multimedia | 3 | 08-30-2006 18:07 |
How to install Route 66 on N80? | br0k3n | Nokia Multimedia | 0 | 08-06-2006 10:06 |
