GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
06-03-2007, 22:55 | #61 (permalink) |
Junior Member Join Date: Jun 2007
Member: 520615 Status: Offline Thanks Meter: 0 | Reset your phone to factory defaults (to do this turn your phone off, then press green call button, 3 and * and turn the phone on) this should set the phone to how you got it fresh out the box, then load your signed route 66 on there... If you Get "Resource Error" Its cause you haven't got any maps in the /system/apps/Route 66/maps folder Put a map in there and it will work fine if that folder isn't there just create it Hope that resolves everyone posting questions arleady answered |
06-04-2007, 16:40 | #63 (permalink) |
Insane Poster Join Date: Mar 2005
Member: 128748 Status: Offline Thanks Meter: 2 | dunno tbh mine and mesh had sim issues so we tried ething we could think of i redid mine 5xs b4 worked wheras mesh found doing it once on his thanks to mesh for his help but worked poss firmware version or conflicting soft on fone maybe? |
06-09-2007, 13:59 | #68 (permalink) |
Member: 524295 Status: Offline Thanks Meter: 0 | I went out for a drive in the car and found that it started to work. but when I select the start option to navigate to somewhere it doesnt work. I search for a location which it then finds in the list. I select it. Then when it starts to calculate the program crashes. Have even done the format and it still does the same thing. Anyone else had the problem? Its so frustrating! My girlfriend was laughing when I was playing with it cause I was getting annoyed |
06-11-2007, 13:36 | #70 (permalink) |
Member: 524295 Status: Offline Thanks Meter: 0 | yes you will loose everything. anything that is saved to the phone. so if it is saved to your memory card then it will be fine I am having the same problem as you. the program will run but as soon as it needs to recalculate directions the program crashes. |
06-11-2007, 15:57 | #71 (permalink) |
Junior Member Join Date: Sep 2006
Member: 350398 Status: Offline Thanks Meter: 0 | noooo, what a bad news! I'm not sure if I want to use route66... too much problems! I'll go with tomtom until a new better solution will arrive! thanks ps but when I reset my phone, every program in the memory will be reinstalled automatically? or I have to reinstall every application one by one? |
Route 66 on Nokia N96 | occ | GPS devices , Navigators & Maps | 2 | 03-03-2009 08:29 |
Keygen for Navigator on Nokia N95 | AirSac | Nokia Multimedia | 4 | 03-18-2008 22:20 |
Route 66 on N91 Problems | alpinanady | Nokia Multimedia | 3 | 08-30-2006 18:07 |
How to install Route 66 on N80? | br0k3n | Nokia Multimedia | 0 | 08-06-2006 10:06 |
