GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
06-03-2016, 10:24 | #1 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1996160 Status: Offline Thanks Meter: 195 | [TomTom] Latest FastActivate Instructions: Menu items: 1. Update meta.txt[/COLOR] Update latest meta.txt. (if servers are not down) You need to allow wget.exe in your firewall if asked. If you have a new meta code which is not in the integrated or updated meta.txt (See in program for date of current integrated meta.txt) then you must put all new meta codes in a file named MYMETA.TXT and copy it to the Device/SD-Card ROOT Directory or keep it in the same directory as FastActivate.exe. 2. Patch Maps, Voices, Speedcams and Fuel PricesPatch ALL these in your device. If you get a ".dct ERROR" message, it usually means the meta has not been released. 3. Patch Navcore (ttsystem or PNDNavigator) Patch Your Navcore with this which is needed to use patched maps. Wait and it will tell you when done.[/INDENT]4. Patch TomTom HOMEThis works automatically and there is no need to search for any files, just wait and it will tell you when done. If you use this you first need to use TomTom HOME "Operate my Device" option; this will download your profile files; then close HOME and patch it. 5. RunMeForCode (Create a meta/****fish code from genuine map)You can create meta code with this button...you have to be the original owner of the map. Remember... meta data does NOT contain any personal information from you or your device. It is safe to share. 6. Update QuickGPSfix (Fix your GPS position) Your TomTom device uses the signals of at least 4 satellites to find out where you are. To start navigating, it needs to know exactly where each satellite is. So start your journey faster with TomTom QuickGPSfix button 7. My Device InfoThis is just info from your device which others need if you ask for help (on most forums). 8. Android ActivationUse this button on Android device with patched .apk. 9. Update FastActivateUpdate FastActivate.exe. (if servers are not down) You need to allow wget.exe in your firewall if asked. Notes: Note 1:If you get trouble running the .exe then "right click and run as administrator" If you use Wince and mapshare p a t c h copy ttnavigator.bif to ttgo.ori Note 2:If You use special characters in windows user name program may halt. ( eg. &, <, >, |, ^ Note 3:[/COLOR][INDENT]If you are doing a fresh install on internal memory of navcore and map then you will need to restart the unit once after the installation of navcore Before you try and patch the map because your unit will then generate the needed ttgo.bif file for the keygen to read. Also if you are installing to a sd card rather than the internal memory the same applies you will need to insert the sd card into the tomtom device and reboot before you patch the map so it generates the needed ttgo.bif file. Note 4:Program works with TomTom PC emulator. Click here for the latest Fastactivate Remember to switch off your A/V, Windows Defender etc before running F/A to avoid getting False/Positive warnings AND remember to switch back on again once finished too! Special thanks to; p33dro Remember to switch off your A/V, Windows Defender etc before running F/A to avoid getting False/Positive warnings AND remember to switch back on again once finished too! Just to remind everyone that although TTActivator is a "live" tool & therefore will automatically utilise the currently latest available metas, FastActivate is not "live " & therefore you should always run "Update Meta.txt" to ensure the latest metas are included Last edited by jmermel; 12-02-2022 at 14:54. |
The Following 54 Users Say Thank You to justmebrowsing For This Useful Post: |
08-17-2020, 14:57 | #3 (permalink) | |
Junior Member Join Date: Dec 2019 Location: Morocco
Member: 2938603 Status: Offline Sonork: 52104 Thanks Meter: 5 | Quote:
The Following User Says Thank You to mounir7878 For This Useful Post: |
