GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
09-20-2006, 00:23 | #34 (permalink) |
Freak Poster Join Date: Jul 2003 Location: UK
Member: 35476 Status: Offline Thanks Meter: 0 | use this instructions: thanxx to my friend... 1)make a folder in C:\ to make it easier, call it keygen. 2)Put your .mid file in there and TT6_kg_4_C4Pda.exe in there. 3)Now open command prompt "Start-Programs-Accessories-command prompt 4)Then type as follows cd C:\ [Press Enter] 5)now you wiill have C:\> in command prompt. 6)Then type: cd keygen : You will then see c:\keygen> 7) Then type : TT6_kg_4_C4Pda.exe North_america.mid : Don't forget the space between .exe and North. 8)then put in your code ID and then enter. OR DOWNLOAD THIS BAT FILE AND COPY YOUR DEVICE ID FROM WHEN IT ASKS YOU TO REGISTER YOUR PRODUCT AND IT WILL GIVE YOU YOUR CODE |
09-20-2006, 00:48 | #37 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Scotland
Member: 18535 Status: Offline Thanks Meter: 11 | Everything was fine until activation code... Can someone help.... My Activation code ANFA8 CJRGS Code generated which does not work is HMZPR DJJN5 VSGU2 This is on Great_Britain.mid maxmix |
09-20-2006, 01:55 | #39 (permalink) |
Member: 18535 Status: Offline Thanks Meter: 11 | 100% on my Nokia 5500 Sport.... Used this map here and Keygen got me up and running.... GB_plus_major_roads_of_WE Just got this all running inc the POI's with the Europe map.... Argyll, Scotland to Barcelona Fookin amazing ! maxmix |
09-20-2006, 06:11 | #41 (permalink) |
Junior Member Join Date: Jul 2006
Member: 320886 Status: Offline Thanks Meter: 0 | @ Husvik Had same problems, then I got the Guam Map very small map, uploaded that to my mobile to.. And used the mid file from Guam, got the activation key with the keygen.. activated the Guam map... And tomtom works.. In tomtom setup, change over to the map you wanted, no need to activate the map |
09-20-2006, 08:44 | #44 (permalink) |
Crazy Poster Join Date: Aug 2006
Member: 338706 Status: Offline Thanks Meter: 1 | I made it! I activated it using Guam map and now I have both Guam map (which was used for activation) and Italia map on the same mini SD and they both work, you just have to swap them; by the way, the Guam map is so small that it can always remain in the mini SD together with all the other maps |
TomTom Navigator 6 Palm fix :) | the_jaguar | GPS devices , Navigators & Maps | 163 | 04-04-2010 03:55 |
TomTom Navigator 6 + Australia map v6.50 | bmohsen | GPS devices , Navigators & Maps | 11 | 06-21-2007 04:01 |
TomTom Navigator 6 on windows "smartphone" ? | ipguy | GPS devices , Navigators & Maps | 4 | 11-07-2006 14:08 |
TomTom Navigator 6 for symbian 9.1 | blaze3g | Nokia Base Band 5 ( BB-5 ) | 2 | 09-21-2006 11:34 |
