Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 12-17-2019, 03:27   #1 (permalink)
Member: 2938603
Sonork: 52104
Thanks Meter: 5
I have a problem The following versions cannot be activated -tomtom
tomtom
Morocco_1040_9812
Morocco_1040_9816
Morocco_1040_9854
This failed to activate a map
latest-fastactivate
Last edited by mounir7878; 12-17-2019 at 03:28. Reason: This failed to activate a map
Old 12-17-2019, 06:39   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Bad meta.txt [ missing your releases ] , bad ttgo.bif ...
The Following User Says Thank You to debeliamark For This Useful Post:
Old 12-17-2019, 12:28   #3 (permalink)
Moderator
Member: 1032904
Thanks Meter: 1,270
Also, if a meta is available , make sure that you are using latest version.
Old 12-18-2019, 02:07   #4 (permalink)
Member: 2938603
Sonork: 52104
Thanks Meter: 5
jmermel
Using the latest version did not work, you can try it yourself
Old 12-18-2019, 02:24   #5 (permalink)
Moderator
Member: 1032904
Thanks Meter: 1,270
Originally Posted by mounir7878 View Post
jmermel
The only meta available for Morocco is
F5 4E 84 CB DC F5 37 59 80 4D 4B C2 FE 24 81 A3 Morocco-102149.meta ; Morocco 1040_9807
If you are using another map. It will not activate.
Make sure that this meta is in text file
The Following User Says Thank You to jmermel For This Useful Post:
Old 12-18-2019, 21:56   #6 (permalink)
Member: 2938603
Sonork: 52104
Thanks Meter: 5
meta
Where can I find the text file?
Old 12-18-2019, 23:09   #7 (permalink)
Member: 2938603
Sonork: 52104
Thanks Meter: 5
jmermel
Activation has succeeded with this map only
Morocco_1040_9807
Old 12-18-2019, 23:11   #8 (permalink)
Moderator
Member: 1032904
Thanks Meter: 1,270
jmermel
Morocco_1040_9807
That is because that is the only meta available.
Old 12-22-2019, 02:35   #9 (permalink)
Member: 2938603
Sonork: 52104
Thanks Meter: 5
Thank you
Thank you, I hope that the rest of the versions will be activated in the future
Page generated in 0.15439 seconds with 8 queries
