GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
The Following 5 Users Say Thank You to jmermel For This Useful Post: |
05-28-2020, 04:44 | #10 (permalink) | |
Junior Member Join Date: Dec 2019 Location: Morocco
Member: 2938603 Status: Offline Sonork: 52104 Thanks Meter: 5 | Quote:
Identification code not found on map ------------------------ I have run the tool FastActivate and followed all phases as usual, and when searching for a Meta file inside the map folder I can't find it. -You can try it on your device * =========== I have never directed this problem with the rest of the previous maps | |
05-28-2020, 05:28 | #11 (permalink) | |
Member: 2938603 Status: Offline Sonork: 52104 Thanks Meter: 5 | The file we find does not include an activation code for the map of Morocco Quote:
Even if I activate the map with the tool FastActivate You will not find a Meta file and the map will not work for you, Even if you add the file manually, the map will not work for you ======================== The file being added does not include identifiers for the map of Morocco +This is the file I found is (Integrated_meta) Does not include identification codes for the map of Morocco. ---------------------------------- I tried the process with more than one device and the same problem You can try it on your device and understand what I mean | |
06-02-2020, 02:10 | #12 (permalink) |
Junior Member Join Date: Jan 2009 Location: UK
Member: 951568 Status: Offline Thanks Meter: 7 | with this version Europe_TRUCK_1050_10209 / nav 9.702 on tomtom go720 i cannot get voices to work i get the error you cannot use the selected voices with the selected language. language is set to english uk correct . the voices ive added do not show up on the screen ? map and voices patched ok with fast active . |
