Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
| | #3316 (permalink) | |
| Junior Member ![]() ![]() Join Date: Jan 2008
Member: 671793 Status: Offline Thanks: 13
| Quote:
I ended up removing all my favourites (including Home) and re-adding them, I also cleared out the recent destinations as these couldn't be used either. Since then however it has worked OK. Andy | |
| | #3317 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Feb 2009
Member: 964688 Status: Offline Thanks: 161
| Quote:
If not, the other tool I gave you the link works very well as well. Last edited by sophie999; 05-27-2009 at 14:52. | |
| The Following User Says Thank You to sophie999 For This Useful Post: |
| | #3319 (permalink) | |
| Junior Member ![]() ![]() Join Date: Sep 2008
Member: 851511 Status: Offline Sonork: DE7 6PE Thanks: 23
| Quote:
Have tried Easyusetools tonight. It seems to successfully patch my map _ i have attached screenshots of this - and I have installed the 7.915 navcore on the device. However when I try option 2, and enter, to patch the system files, I get (repeatedly) "File missing". Aaaaaaarghhh! What am I doing wrong????? WHAT file is missing? | |
| | #3320 (permalink) | |
| Quote:
tt8_keygen <map-folder-name> <device ID> Assuming the Meta.txt is in the same folder as the tt8_keygen.exe and has the correct entries for your map and any TomTom speed cameras you should get something like this: Code: C:\tomtom>tt8_keygen.exe United_Kingdom_and_Republic_of_Ireland_830_2306 AB2ZXXXX 'United_Kingdom_and_Republic_of_Ireland-33.meta' - OK 'FuelStationsEU.ov2' - OK 'Safety_Cam_UK_Premium.ov2' - OK 'Safety_Cam_UK_TomTom.ov2' - OK C:\tomtom\ HTH Andy | |
| | #3321 (permalink) |
| Junior Member ![]() Join Date: Jun 2008
Member: 785089 Status: Offline Thanks: 0
| can someone help here please i have been trying to get tomtom on my htc touch all day and am struggling. i have a text file that consist of ; United_Kingdom_and_Republic_of_Ireland_725.1871 3E BF B6 52 66 53 EC E2 F2 25 BB A7 B1 26 7B 15 United_Kingdom_and_Republic_of_Ireland-17.meta and in same folder is United_Kingdom_and_Republic_of_Ireland-17 meta file when i run the keygen it says there is no so map in the keyfile meta.txt what am i doing wrong thanks |
| | #3322 (permalink) | |
| Quote:
After digging around today it seems in the UK we can't get USA maps - certainly can't even buy one on the Tom Tom site although I read that the map for Go works with a PDA and you can get that. | |
| | #3323 (permalink) | |
| Quote:
Where are the map and tools stored on your C:\ drive? To change directories you use the command 'CD' with options. If you want to go back to the root then use 'cd\' , if you want to move back one level use 'cd..'. On my PC I have a folder called 'c:\tomtom'. In this folder I have the 'tt8_keygen.exe' and 'meta.txt' as well as sub-folders with maps (United_Kingdom_and_Republic_of_Ireland_830_2306 etc). In the map folder there are various files - cline.dat, cname.dat, cnode.dat, faces.dat, mapinfo.dat, poi.dat, tables.dat, tmccodes.dat and traffic.dat. There are also two files with the start of the filename as the map name 'United_Kingdom_and_Republic_of_Ireland' - United_Kingdom_and_Republic_of_Ireland.pna & United_Kingdom_and_Republic_of_Ireland-27.meta. When I run the tt8_keygen with the correct parameters I then get another file called 'United_Kingdom_and_Republic_of_Ireland-27.meta.dct' which is then unique to my device. Lets assume you have the same folder structure as me - 'c:\tomtom' with the two files 'tt8_keygen.exe' and the 'meta.txt' in it. Inside this folder in another folder with your map '\North_America', inside this folder are two files 'North_America-35.meta' and the 'North_America.pna' (assuming that is the map you are trying to use?). You would need to open a command prompt - Start, Run, cmd Change directory to the c:\tomtom folder - cd\tomtom Type the command to generate the .dct file - tt8_keygen North_America XXXXXXXX - where XXXXXXXX is your unique device ID. This should generate the file 'North_America-35.meta.dct' file. Copy the files to the map folder on your storage card. That's it..... | |
| The Following User Says Thank You to ADB100 For This Useful Post: |
| | #3324 (permalink) | |
| Quote:
There is no problem with generating the .dct file for the map -that's there. The problem is with patching the system file - I get this 'file missing' message when I try the tt system patcher thru easyusetools. Any way I think I'm wasting my time. Had this message from Tom Tom support today: Thank you for contacting TomTom Customer Care The reference number for your query is 090529-002561. There are currently no maps available for the USA for use with Nav 7. Apologies for the inconvenience. With Kind Regards The TomTom Customer Care Team UNLESS ANYONE OUT THERE KNOWS DIFFERENT???! | |
| | #3325 (permalink) | |
| Quote:
| | #3326 (permalink) |
| Sorry sophie999 but the tools you sent the links for ARE the tools I've been using (as well as anything else anyone has kindly suggested). The .dct file is there in the map folder. When I go on to patch the navcore the tt system patcher says it can't find the file; see post #3319 . So I'm stumped. I don't know if this is something to do with the TD's "My Device" and "Internal Storage" System. There seems to be an original installation on MY device and a later one on Internal Storage. I uninstalled the earlier one on My Device thinking the tt system patcher was going for that. Now TomTom says No Maps Found while the device is plugged into the pc, but when it is unplugged I can use TomTom and it is with the 7.915 navcore and I can use my installed UK map. I don't suppose anyone can make any sense of this ..... just letting out my frustrations really!!! |
| | #3327 (permalink) |
| OK. Now I am confused. The best thing I guess is to uninstall everything and start from the scratch. 1. Unpack TTN7 from the link. It will either be a CAB file or a combo of 2 files: TT7 .exe and .data. If it is cab file, just install it. If it is a combo of 2 files, copy them on your device. In either case, they DO NOT need any patching (unlike navcore 8 used for PNA TT devices, which do need separate patching). For TT7, only maps need to be patched. You can later up/downgrade your TT7 version simply by repalcing existing .exe and .data files by new ones without any more patching it is that simple). 2. Generate .dct file. Place .dct file in the folder with the US map. Copy maps to your device. 3. Run the TT. If cab was installed, find TT among your programs. If you got 2 separate files, just run the TT .exe file from wherever you put it. You can then copy the shortcut of .exe file to the windows/start menu/programs directory so that it will appear on your program list. 4. Enjoy. Your native UK map should work with any TT7 versions. It will not need any patching. Device should be able to recognize it. So, install US maps and TT navigator first. Make sure it works. Then simply add UK maps. Hope this helps. Let me know how it goes. Last edited by sophie999; 05-30-2009 at 14:30. |
| | #3328 (permalink) | |
| Quote:
![]() I tried deleting the free city map but again it will not let me go any further unless I download/install it. ( Without it -No maps found! NEXT.Welcome! You can download a free map...NEXT leads to download or CANCEL leads back to No maps found!) TT does not see the N America map. My only thought is that this map - North_America V830.2284 - is not compatible with the TD and I will try USAandCanadav815.2022 which I am currently downloading. Will post back. | |
| | #3330 (permalink) | |
| Quote:
Sorry, I gave you the wrong link. 830.2284 IS FOR PNA ONLY!!!!. IT DOES NOT WORK FOR PDA. I have both devices and must have spaced out. You need 830.2323 map. Get it here (thanks tendriver). Totally my fault. Sorry about that. TomTom v8 Firmware and Maps post 4391 This should finally work!!! Last edited by sophie999; 06-01-2009 at 05:10. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| [Archive] TomTom v9 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4520 | 06-15-2013 19:46 |
| TomTom v8 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 5949 | 06-12-2013 03:17 |
| how to install tomtom V6 software and maps on NAVMAN F20 | sniper007 | GPS devices , Navigators & Maps | 4 | 11-06-2012 17:58 |
| TomTom v6-7 and Route 66 v6 Firmware and Maps | BuMobiles | GPS devices , Navigators & Maps | 4687 | 05-25-2012 15:52 |
