Unlock Server
Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 10-18-2008, 01:27   #121 (permalink)
tendriver's Avatar
Member: 818203
Originally Posted by bignil40 View Post
Anyone gets another mirror of this one? I couln't find any file for downloading. Also, does it work for Tomtom go 910?
Thanks!
Go back to this site. http://linksave.in/209600023548c7631c94394 You download the "DCL" file. You also have to download & install "jdownloader" http://jdownloader.org/home. Once installed use jdownloader to run the "DCL" file. Password is 4gulli.
Old 10-18-2008, 01:56   #122 (permalink)
tendriver's Avatar
Member: 818203
Originally Posted by Lyncas View Post
Could you please upload it again? Link has been deleted...
Thank you
Regards
Lyncas
Zoned
http://www.megaupload.com/?d=R8BYUT5P
Consolidated
http://www.megaupload.com/?d=A46GQTZI
Single File
http://www.megaupload.com/?d=42ANR4KC
Old 10-18-2008, 02:09   #123 (permalink)
tendriver's Avatar
Member: 818203
Thank you
Regards
Lyncas
Originally Posted by tendriver View Post
Disregard, these have already been deleted. SORRY!!!!
Old 10-18-2008, 09:51   #124 (permalink)
Member: 748557
Originally Posted by BuMobiles View Post
UK and IE v8.10.1870
http://www.2shared.com/file/4030948/...1870part1.html
http://www.2shared.com/file/4031179/...1870part2.html
Better hurry
Thanks B.u Mobiles
I've downloaded both files, but when extracting from part2, cline.dat has a CRC error, any ideas?
I've tried downloading the file again, but same problem.
TIA
The Following User Says Thank You to northender For This Useful Post:
Old 10-18-2008, 18:33   #125 (permalink)
tendriver's Avatar
Member: 818203
TIA
IF you downloaded both parts to the same location, extracting part 1 SHOULD actually extract part 1 & part 2 at the same time. There should NOT be a need to extract part 2 seperately.
The Following User Says Thank You to tendriver For This Useful Post:
Old 10-19-2008, 03:31   #126 (permalink)
Member: 792624
Ppc tt8
I know before it was said that TT8 was not available on a Windows Mobile phone.
I'm wondering if anyone knows of any updates on this, if it has been ported or released anywhere?
Old 10-20-2008, 13:58   #127 (permalink)
Member: 671793
The latest release of TT 7 for Windows Mobile is 7.451 (9033). Currently there is no version 8.x available for the Windows Mobile platform, nor have I seen any announcements or rumours. Version 7. for Windows Mobile is not commercially available and has only surfaced due to it being 'ripped' from HTC's Diamond. TomTom's website has absolutely no information regarding TT 7 for WM.
Andy
Old 10-25-2008, 21:42   #128 (permalink)
Member: 885092
Help pls(can not install map)
Hello guys.I've got a problem.Can't install map of North America on my TomTom OneXL(AK6SC AAARW).Talking about map North_America_2GB_v810.(1907.My device version is 8.010.When I try to use this map the device show me that I can't use this map.I can't handle it.Can someone explain to me step by steb what to do .Thank you very much ...
Old 10-26-2008, 19:01   #129 (permalink)
Member: 885702
Hello to all, my first post follows:
I recently purchased the TomTom Go 530T for my wife and decided to take it upon myself to install some extra maps as we were off to France. #
After some searching i managed to download the right maps from torrents, searched for using the ubiquitous pirate bay. (still seeding, ratio = 1.3)
I then did some reading and downloaded the easy use tools to create the necessary dct files that accompany the maps so they can be used on my TomTom.
I'm now up against my final hurdle and i can't quite clear it. After further research after the maps wouldn't work on my 530T, i discovered that you need a cracked version of the 'ttsystem' file as you can no longer patch the navcore 8.010 version.
I've scoured every forum i can find, and all the links are too old and TomTom have faithfully requested them to be removed from all the large upload sites. As such i would kindly request if someone could post another new link to a cracked version of the navcore 8.010 ttsystem file.
Thanks
As an aid to others who may happen upon this thread, below is a brief list of instructions to allow you get other maps working on your new TomTom Go Sat nav, it's not great but hopefully it's succinct and makes sense.
  1. Search for and download the additional maps you want for your TomTom unit, for example visit the piratebay and search for TomTom Maps Europe.
  2. Many of these downloads will come with the necessary keygen/patcher required, if not do a search for a TomTom map patcher at the same sorts of sites.
  3. Using the 'easyusetools' you need to follow the instructions, with a little decoding. Essentially, you need to locate the *.Bif (eg ttgo.bif) file on the tomTom itself.
  4. You can open this file (copied to your computer for safety) in notepad etc and you will need to note down the '[DeviceUniqueID]'.
  5. Next copy the .meta file from your maps folder into the folder that says, 'insert_meta_from_map_here'. Relatively obvious.
  6. Run the 'runmeforDCT.cmd' program and follow the instructions, using your device ID (which can also be written into the 'DeviceID.txt' file in that folder).
  7. This will generate a DCT file associated with the map and ID of your TomTom. You need to copy that to the map folder which you will transfer to your TomTom (best to store it on an SD card as they're so cheap).
  8. You also need to download a cracked version of the ttsystem file, also stored in the root directory of your TomTom if it is version 8.010 or above.
  9. You can determine it's version by turning on your satnav, and in the driving screen, prod the bottom left corner, it will display it's version number.
  10. Finally, make sure you never delete anything on you TomTom, only backup and rename file you no longer need. Much safer! Also, always backup your TomTOm using the TomTOm Home software before doing anything of this nature. You don't want to be left with a paperweight.
Hope this has been useful, and someone please post a fresh link to a cracked navcore 8.010 ttsystem file.
Thanks
The Following 8 Users Say Thank You to tstanton1 For This Useful Post:
Old 10-26-2008, 22:07   #130 (permalink)
pictopicto's Avatar
Member: 607536
So nice to see a newbie give back as much if not more than taken.
Well done, great post.
Old 10-26-2008, 22:20   #131 (permalink)
BuMobiles's Avatar
Member: 503346
Very true
So good to see people trying and learning
Old 10-26-2008, 23:47   #132 (permalink)
Member: 881648
Thanks
Thanks
very useful! THANKS!
Old 10-27-2008, 10:13   #133 (permalink)
Member: 885702
Minor correction, in step 9, you should prod the bottom RIGHT not the left as i said. Sorry for any confusion.
Old 10-27-2008, 18:54   #134 (permalink)
Member: 886474
I have a TomTom Go 910
I downloaded the following components based on your suggestions:
TomTom Go 720 (FW 8.10)
TomTom_KeyGen_v2.3_(v6-7-8)
TomTomGO Map Western and Central Europe v720.1803 TTS incl working keygen
Removed everything from the hard drive, and upload everything from the TomTom Go 720 (FW 8.10) folder to the root.
After that the system started sometimes, but turned off automatically after few minutes.
From this morning this worts. I am not able to turn on my Go 910.
Even I RESET it at the back with a needle/pin.
Please help me what should I do.
It is a software issue or my hardware broken.
Cheers
Tom
Old 10-27-2008, 22:43   #135 (permalink)
pictopicto's Avatar
Member: 607536
Cheers
Tom
Please tell me you did a backup before removing from the hard drive?
I think it sounds like you havent put the right files in the right place.
Best think to do is take a snapshot of the root folder of your system and post here so we can see what you have put where.
[Archive] TomTom v9 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4520 06-15-2013 19:46
TomTom v7 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 3479 03-05-2013 21:55
how to install tomtom V6 software and maps on NAVMAN F20 sniper007 GPS devices , Navigators & Maps 4 11-06-2012 17:58
TomTom v6-7 and Route 66 v6 Firmware and Maps BuMobiles GPS devices , Navigators & Maps 4687 05-25-2012 15:52
Page generated in 0.75727 seconds with 12 queries
