Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 04-28-2009, 05:02   #1 (permalink)
Member: 845589
Thanks Meter: 23
Exclamation TTOne XLS SD card question
How can I make my TT One XLS to read everything from SD card? I know everything should be copied to the SD card, but I want to have the SD card at one navcore, map and voices and when I unplug the SD card to run from the internal memory without telling me that "yo have selected an nonexistent voice".
Thanks a lot.
Old 04-29-2009, 21:33   #2 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
Thanks a lot.
make a copy of the internal memory onto the sd card
then add / remove your voices or maps
Easy as 1-2-3
Thanks
B.u Mobiles
Old 04-29-2009, 21:44   #3 (permalink)
Member: 845589
Thanks Meter: 23
Internal memory is 1GB, running the low res map and VocaliserTTS, SDHC card is 4GB, running high res map and large Loquendo voices.
I need your help with my setconfig.txt for a XLS model.
As I have 64MB of RAM I want all my options ON. Like Bluetooth.
If I put in setcofig.txt model: x40, BT works but Loquendo doesn't.
with model: x40light or model: x40light2 Loquendo works but BT is disabled from the boot.
Thanks.
Old 04-29-2009, 21:50   #4 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
Thanks.
Use the version 8.0.10 SE and all will be fine
The Following User Says Thank You to BuMobiles For This Useful Post:
Old 04-29-2009, 21:53   #5 (permalink)
Member: 845589
Thanks Meter: 23
indeed, 8.0.10 was the lates version I got it using TTHome. But I don't think I can get IQ routes and ALG with that one.
Old 05-02-2009, 12:58   #6 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
Best thing to try is use the 8.0.10 on the internal memory with the low res maps.
Then use the new dsa 8.4.10 with your 4gb sd and the high res maps
Let me know
B.u Mobiles
Palm Centro.. Question about Viewing your sd card on your pc cesone PalmOS /HP and others 10 11-09-2008 08:04
Nokia N82 _ micro sd card memory card password remover amit_varietymob Nokia Base Band 5 ( BB-5 ) 12 10-25-2008 03:48
2gb sd card question treoist PalmOS /HP and others 0 03-03-2007 16:05
Where to find Bluetooth SD Card, SD TV Tuner Card in INDIA? sujithsidhardhan HTC & PDA WM( With Touchscreen) 0 10-29-2006 09:40
mini wifi sd card n mini sd dvb-h on spv Chopped HTC & PDA WM( With Touchscreen) 1 06-27-2006 13:51
Page generated in 0.19301 seconds with 9 queries
