Account Problem Xiaomi Redmi 5A MRT HELP! Hello! I try to remove mi account from xiaomi redmi 5a (Riva) by mrt dongle. Firmwares, that i try: China 8.5.7.0 Global 9.1.6.0 9.5.6.0 9.5.10.0 9.6.5.0 I try it even on a "vietnam" V9.1.8.0.0 On a low versions i tryed a 4a way to remove account - same result. No matter how i do it: Flash , then skip activation with no wifi, and then remove, or connect wifi on a activation start - Account always get back. When i try to freeze\remove apk find device error appear, i cant use the phone anyway. MRT TEAM I NEED YOUR HELP! |
Same problem. Redmi 5a successfully unlock mi account with MRT, but when I connect with internet then again relock mi account I will downgrade MIUI 9 to 8 but same problem . Try China 8.5.7.0 firmware and it not helped. Who can help me with this? |
i have same problem with this model and more models same relocked after unlock. MRT supporters always sleep |
Download this firmwear after complete download, disable anti viruse extract firmwer exe flash this firmwear via edl mode 10000% solve ur problem. post result https://drive.google.com/uc?id=1bikR...xport=download |
Have you solved the problem? I have the same device tried on V9.1.4.0 and V8.5.7.0 the result is the same when you connect to the Internet is blocked again. |
MIUI 8.5 China Stable ROM V8.5.9.0. MRT unlock OK. Blocking does not occur. |
