04-21-2011, 06:00 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Indonesia-D.K.I Jaya
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | boot error... DA_LIB_VER_3.2.0.5 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 what should i do, sir??? |
04-21-2011, 08:02 | #3 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | still same problem, sir.... 1. recheck the cable 2. try with another phone, is the same 3. how about request code and activation key???? i bought box yesterday when i register commzero...it says: connecting server... Error: Your box's serial number [00006817] has been registered. |
04-21-2011, 08:11 | #4 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | Request code : 8B762693-E41A-4CD0-A551-AC276E45201C Initializing... DA_LIB_VER_3.2.0.5 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 when it says like that, the request code change : 2927A6AA-7B9C-4271-912B-653BEC14C928 and reconnect : 41E746B1-4666-4F57-99C2-B80E5327C2CE is it normal???? the code always change when i try to connect |
04-21-2011, 09:03 | #5 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
hi first of all welcome to the board Request code : 8B762693-E41A-4CD0-A551-AC276E45201C this code will change in every action this 4 security reason u have to don't worry abt ur connecting problem connect ur set in proper way than try remember to hold the power buttom if still same than rehot cpu i think u have hard ware problem in the set br, vijay-gsm | |
04-21-2011, 10:40 | #6 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | it's not hardware sir... i try another box...... (MTK) open com12 success! press on/off key please.. Target's new hw_ver :0x8a02 Target's hw_code : 0x6235 Target's sw_code : 0x8A00 MTK AllInOne_DA_v3.1016.00.00 DA---->9 is selected ......... ......... (DA) Check nor flash IC... (DA) check NAND IC...Fail! (DA) Bootloader running now, ok (DA) Project ID:MAUI.09A.W09.52 (DA) Auto format info: StartBaseAddr[0xF00000] size[0x100000] (MTK) Close COM12 success with COMMZERO V.5.001.....here is the log: Initializing... DA_LIB_VER_3.0.0.1 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 wHAT's wrong, sir....??? |
04-21-2011, 16:48 | #7 (permalink) | |
contact me on yahoo- vijay2u2 i have to check | |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
04-21-2011, 18:00 | #8 (permalink) |
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | thanks master...problem solved when i extract the file especially commzero, i forgot disable antivir and make exclusion. here is my steps : 1. remove driver and delete my commzero data 2. restart pc and i make exclusion commzero at my antivir(kaspersky) 3. install driver, upgrade box and run commzero 4. it's working now...... thank for your attention, if i have a problem somemore...i will contact you B.R : Toto tomorow i'll share the log....i'm happy. my super doctor runs normally |
The Following User Says Thank You to maknyuss For This Useful Post: |
08-19-2011, 10:25 | #12 (permalink) |
Junior Member Join Date: Jul 2007
Member: 550964 Status: Offline Thanks Meter: 5 | bro ... i got the same problem .. i try to uninstall n reinstall but still not working ... can anyone help me ... thanks Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 |
03-07-2012, 15:22 | #13 (permalink) |
Freak Poster Join Date: Dec 2009 Location: andrapradesh.india
Member: 1181277 Status: Offline Thanks Meter: 15 | cant boot 6128 mtk cpu i have chaina touch.its phone lok but cant boot with dragon mtk cpu 6128. its show some erro Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Connection Failed. plese help me sir |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
