Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 04-21-2011, 06:00   #1 (permalink)
Member: 1104396
Sonork: 290480
Thanks Meter: 19
boot error...
Initializing...
DA_LIB_VER_3.2.0.5
It is sensing the pinout fast,please hold on the phone Power key
RXD=2 TXD=1
Connecting...Please hold on the POWER key until the red gauge is going...
Failed to read HardCode, REG=0x80000008
Error: Failed to read REG=0x80010008
Error: Failed to read REG=0x84010008
Error: Failed to read REG=0x80001008
what should i do, sir???
Old 04-21-2011, 06:04   #2 (permalink)
suwaree's Avatar
Member: 572409
Thanks Meter: 1,438
Check the cables
Call or put off shifting
Old 04-21-2011, 08:02   #3 (permalink)
Member: 1104396
Sonork: 290480
Thanks Meter: 19
still same problem, sir....
1. recheck the cable
2. try with another phone, is the same
3. how about request code and activation key????
i bought box yesterday when i register commzero...it says:
connecting server...
Error: Your box's serial number [00006817] has been registered.
Old 04-21-2011, 08:11   #4 (permalink)
Member: 1104396
Sonork: 290480
Thanks Meter: 19
Request code : 8B762693-E41A-4CD0-A551-AC276E45201C
Initializing...
DA_LIB_VER_3.2.0.5
RXD=2 TXD=1
when it says like that, the request code change : 2927A6AA-7B9C-4271-912B-653BEC14C928 and reconnect : 41E746B1-4666-4F57-99C2-B80E5327C2CE
is it normal????
the code always change when i try to connect
Old 04-21-2011, 09:03   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Initializing...
DA_LIB_VER_3.2.0.5
RXD=2 TXD=1
is it normal????
hi
first of all welcome to the board
Request code : 8B762693-E41A-4CD0-A551-AC276E45201C this code will change in every action this 4 security reason u have to don't worry
abt ur connecting problem
connect ur set in proper way than try remember to hold the power buttom
if still same than rehot cpu i think u have hard ware problem in the set
br,
vijay-gsm
Old 04-21-2011, 10:40   #6 (permalink)
Member: 1104396
Sonork: 290480
Thanks Meter: 19
it's not hardware sir...
i try another box......
(MTK) open com12 success!
press on/off key please..
Target's new hw_ver :0x8a02
Target's hw_code : 0x6235
Target's sw_code : 0x8A00
MTK AllInOne_DA_v3.1016.00.00
DA---->9 is selected
(DA) Check nor flash IC...
(DA) check NAND IC...Fail!
(DA) Bootloader running now, ok
(DA) Project ID:MAUI.09A.W09.52
(DA) Auto format info:
StartBaseAddr[0xF00000] size[0x100000]
(MTK) Close COM12 success
with COMMZERO V.5.001.....here is the log:
Initializing...
DA_LIB_VER_3.0.0.1
RXD=2 TXD=1
wHAT's wrong, sir....???
Old 04-21-2011, 16:48   #7 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Initializing...
DA_LIB_VER_3.0.0.1
RXD=2 TXD=1
contact me on yahoo- vijay2u2
i have to check
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 04-21-2011, 18:00   #8 (permalink)
Member: 1104396
Sonork: 290480
Thanks Meter: 19
thanks master...problem solved
when i extract the file especially commzero, i forgot disable antivir and make exclusion.
here is my steps :
1. remove driver and delete my commzero data
2. restart pc and i make exclusion commzero at my antivir(kaspersky)
3. install driver, upgrade box and run commzero
4. it's working now......
thank for your attention, if i have a problem somemore...i will contact you
B.R : Toto
tomorow i'll share the log....i'm happy. my super doctor runs normally
The Following User Says Thank You to maknyuss For This Useful Post:
Old 04-24-2011, 08:12   #9 (permalink)
Member: 462514
Sonork: 100.1596836
Thanks Meter: 602
this is not software prob this is hardware problem try and see.........
Old 06-09-2011, 14:11   #10 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
This is connectivity problem.....tested many time...
Old 07-13-2011, 21:42   #11 (permalink)
Guilherme Lima's Avatar
Member: 1508533
Thanks Meter: 45
Processor can also be the error, just trying to select correctly
Old 08-19-2011, 10:25   #12 (permalink)
Member: 550964
Thanks Meter: 5
bro ... i got the same problem ..
i try to uninstall n reinstall but still not working ...
can anyone help me ... thanks
Initializing...
DA_LIB_VER_3.4.1.2
RXD=1 TXD=2
Any errors please select another boot and try again.
Old 03-07-2012, 15:22   #13 (permalink)
Member: 1181277
Thanks Meter: 15
cant boot 6128 mtk cpu
i have chaina touch.its phone lok but cant boot with dragon mtk cpu 6128.
its show some erro
Initializing...
DA_LIB_VER_4.0.3.2
Tip: The phone must be able to power-on normally
RXD=2 TXD=5
Connection Failed.
plese help me sir
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
Avoid 3 times error code in Nokia 6185 X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-08-2000 20:24
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.23379 seconds with 9 queries
