01-05-2018, 17:06 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | DIG L01 Frp Remove problem >>>>Get android fastboot devices... Mobile Name: DIG-L01 Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:10fa495063dcd2b8 >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:10818aaf1b5b32e5 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:10910a2b0b5a2ae1 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... FAILED (remote: Command not allowed) finished. total time: 0.001s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.001s |
01-19-2018, 12:07 | #3 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 40
Member: 17405 Status: Offline Thanks Meter: 345 | same problem here, in Hisi type this error, in Qualcomm start button not working. >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: DIG-L21 Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:b3328134819a677e >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:b32e61d39d93f579 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:b32621919593797b >>>>try temp unlock bootloader function hisi 970... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:b351820de11c1325 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... FAILED (remote: Command not allowed) finished. total time: 0.000s >>>>Rebooting Mobile Phone rebooting... finished. total time: -0.000s |
01-19-2018, 14:21 | #4 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Try this tips 1. Open MRT 2. Click Hwtools 3. Set On Position , click emergency call 4.input * # * # 2846579 # * # * select Backgroud setting usb port setting manufactured mode ... Install Hisuite first on your PC let the driver is installing 5. next step click hw frp new tool 6. make sure port has set correctly click remove HW account 7. Done!!! MAKE MONEY SUCCESSFUL!!! |
01-19-2018, 14:43 | #5 (permalink) |
Member: 17405 Status: Offline Thanks Meter: 345 | in qualcomm type i cant press start button when REMOVE FRP LOCK selected, only read info also i cant lauch middle button Huawei FRP NEW, onlz first button in HW_Tools >>> Get Mobile Port: COM59 >>>>Device identification : DBAdapter Reserved Interface Try Qualcomm Unlock Frp function Connect Mobile success... Try Qualcomm Unlock Frp function Connect Mobile success... >>>>Connecting Unlock Service... Connect Service Success.... >>>>Sending Auth Data to Service... >>>>Sending 2ed time Auth Data to Server... verification data success.... boot Version: DIGC432B106_BOOT AMSS Info: MSM8940C432B106_AMSS Jun 6 201717:19:23 EFS Version: DIGC432B106_EFS HL1DIGM Sboot Version: DIGC432B106_APPSBOOT KERNEL Version: DIGC432B106_KERNEL System Version: DIGC432B106_SYSTEM Recovery Version: DIGC432B106_RECOVERY CPU Info: MSM8940 Software Modle Info: DIG-L21 Modle Info: ö~ PCB SN: 5H410C703107417 Mobile SN: GMY9X17419G09298 MEID: 00000000000015 IMEI: 863023030395006 IMEI2: Read IMEI1 Fail |
01-19-2018, 15:08 | #6 (permalink) |
Member: 17405 Status: Offline Thanks Meter: 345 | ok middle button huawei frp new open in win 7, BUT not help adb switch to fastboot failed, when unlocking frp when i manualy put phone in fastboot, window close, nothing happening after pull unlock data into dut... window close |
06-21-2018, 18:57 | #11 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 43
Member: 138234 Status: Offline Thanks Meter: 79 | Same problem with same phone DIG-L21 !! tested on last version 1.52, in fastboot soft say (DONE) but still frp on in normal mode (manufactured mode on) operations fail.. |
