10-10-2018, 11:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | honor lld-al10 frp mrt cant unlock (FRP REMOVE GUIDE :-POWER ON YOUR HONOR 9 LITE N TYPE THIS CODE *#*#2846579#*#* AFTER TYPING CODE U WILL SEE MENU == IN MENU JUST SELECT BACKGROUND SETTING=== AFTER SELECTING THIS==SELECT USB PORT SETTING===N FINALLY SELECT MANUFACTURER MODE.... AFTER ALL THIS PROCESS U WILL HAVE TO CONNECT UR MOBILE IN FASTBOOT MODE N GIVE THE FASTBOOT DRIVER .. THEN JUST SELECT REMOVE FRP N PRESS START>>>> NOW UR FRP WILL BE DONE ENJOY) >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: LLD-AL10 Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:68bf071eb090eaa7>>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:44ede6d9d5e4a080 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:b9618a8c4805d56b>>>>try temp unlock bootloader function hisi 970... Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:88e4848d71f07db4 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... FAILED (remote: Command not allowed!) finished. total time: 0.001s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.023s |
