Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 09-26-2016, 09:47   #1 (permalink)
Member: 1038939
Thanks Meter: 94
M3 Note L91 not support for operations. [ ANSWERED ]
Logs -
Read info -
    Searching Android Mobile...
    Reading Moblie SN Info...
    L91HVCNU22C9U    fastboot
    Restarting Mobile...
    rebooting...
    finished. total time: 0.003s
    How to Identify Modle in the SN--First 2 ~ 3 SN digit
    SN Is 71 Start Note1
    SN Is  75 Start MX4
    SN Is  76 Start MX4 Pro
    SN Is  79 Start M1
    SN Is  80 Start Pro6
    SN Is  81 Start Note2
    SN Is  85 Start MX5
    SN Is  86 Start MX5 PRO
    SN Is  88 Start M2
    SN Is  91 Start Note3
    SN Is  95 Start MX6
    SN Is  98 Start M3
    SN Is  Y15 Start 3S
    SN Is  A01 Start MeiLan E
    SN Is  A10 Start Metal
    After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Try unlock password -
    Disconnect Mobile...
    Re-Put the Mobile Bettery...
    Then Connect your Phone to Computer again....
    Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
    Get Mobile Port is:  COM4
>>> Device driver identification:
    MediaTek USB Port
>>> Mobile Has Connect...
    CPU_NAME: MT6755
>>> Reading Mobile Hardware Info...Success
    HW_Inf:  8A00    SW_Inf:  CB00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
>>>>Trying Connect to Service verification data...
Success
>>> Downloading Boot1 To Mobile Phone...Success
    Mobile phone status:SYNC...
    Mobile phone status swtich to :brom...Success
    Make sure Mobile status has in :brom...Success
and freeze program.
Try Reset Account -
    MediaTek USB Port
    CPU_NAME: MT6755
Success
Try erase userdata -
    MediaTek USB Port
    CPU_NAME: MT6755
Success
Old 09-26-2016, 10:22   #2 (permalink)
zhulianqi's Avatar
Member: 812359
Sonork: 100.1597111
Thanks Meter: 6,688
I think is this flash ic unsupport will be fix soon as soon
Old 09-27-2016, 05:08   #3 (permalink)
zhulianqi's Avatar
Member: 812359
Sonork: 100.1597111
Thanks Meter: 6,688
select M3 working aleady test
Old 09-27-2016, 15:04   #4 (permalink)
Member: 1038939
Thanks Meter: 94
Not work with m3 option. I sent last preloader to ARD. EMMC not support may be?
Freeze on 2boot sent -
Get Mobile Port is: COM6
MediaTek USB Port
CPU_NAME: MT6755
Success
Init Mobile BOOT2 ...
Sucess connect M3S -
    MediaTek USB Port
    CPU_NAME: MT6755
Success
    =====================Flash Type(eMMC)==============
    Flash   Size: 0x0000000747C00000 -> 29820M
    Flash     ID: 0x90014A4842473461
    Flash   Name: Hynix_Unknow
    Flash symbol: HBG4a2
>>> Swich Mobile to Hight Speed Re\Wr Port...
    Get Mobile Port is:  COM70
    MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
>>>>Formating Mobile USER Data...
    ADD(HEX):0x00EB000000    Size(HEX):0x065BBFBE00
    Corresponding operation completed!!!
Few days and i create FW and testing with logs and screen.
Old 09-28-2016, 21:50   #5 (permalink)
Member: 604267
Not work repair imei M3 Note L91... (
Old 10-06-2016, 02:13   #6 (permalink)
Member: 604267
M3 Note L91 not support ???
Screenshot by Lightshot
Old 10-06-2016, 03:33   #7 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
Size the ic 0mb maybe ic has damaged
Old 10-06-2016, 04:46   #8 (permalink)
Member: 604267
phone works, M3 Note L91 all functions do not work (tested MRT Ver 1.25 , ver1.19)
Old 10-06-2016, 05:05   #9 (permalink)
zhulianqi's Avatar
Member: 812359
Sonork: 100.1597111
Thanks Meter: 6,688
Select M3s will working
The Following User Says Thank You to zhulianqi For This Useful Post:
Old 10-06-2016, 10:39   #10 (permalink)
Member: 604267
select m3s not works..., waiting 4 phone...
Old 10-06-2016, 10:45   #11 (permalink)
zhulianqi's Avatar
Member: 812359
Sonork: 100.1597111
Thanks Meter: 6,688
M3 also can not????????????????????????????????
Old 10-06-2016, 11:06   #12 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
reboot your pc and connect again. seem your dongle not connect perfectly
follow this tuto also : http://forum.gsmhosting.com/vbb/f492...-tuto-2141219/
Old 10-06-2016, 12:12   #13 (permalink)
Member: 604267
phone M3 Note L91 (L681H), when choosing to mrt ''note3'' - not works, I chose mrt ''mx5''- unlock password done
imei repair - not works....
>>>>ЙиёРтБРєЕРЕПў: L910ZZ116V08
ОґЦЄІЩЧчіЙ№ы!!!
ЗлЧФРРЦШЖфКЦъєу!!!
КдИл*#06#ЧФРРИЁРґИлКЗсНкіЙ!!!
ОґЦЄІЩЧчіЙ№ы!!!
ЗлЧФРРЦШЖфКЦъєу!!!
Old 10-06-2016, 12:50   #14 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
ОґЦЄІЩЧчіЙ№ы!!!
ЗлЧФРРЦШЖфКЦъєу!!!
ОґЦЄІЩЧчіЙ№ы!!!
ЗлЧФРРЦШЖфКЦъєу!!!
so ...u solved the problem about unlock password with MRT dongle, right?
Old 10-06-2016, 15:29   #15 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
In meizu tab, when you select imei,it will give you steps !
There are have logs help. Follow that step!
Page generated in 0.88996 seconds with 7 queries
