06-18-2017, 17:49 | #1 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | Meizu M1E (M3E) how to remove flyme account ? [ SOLVED] I have select model Meilan Max but not happy. Quote:
The Following User Says Thank You to love edition For This Useful Post: |
05-24-2018, 07:35 | #5 (permalink) |
Junior Member Join Date: Apr 2013 Location: Astana
Member: 1924155 Status: Offline Sonork: 028028 Thanks Meter: 4 | Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM101 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Fail After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! Can not do it. without factory mobile phone the phone is unlocked but always shows 1%. And if from factory mobile the option then writes a file. |
The Following User Says Thank You to TALISMAN_028 For This Useful Post: |
06-18-2018, 15:58 | #6 (permalink) |
Junior Member Join Date: Apr 2018 Location: Atyrau,Kazakhstan
Member: 2829405 Status: Offline Thanks Meter: 3 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: Устройство с последовательным интерфейсом USB >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM26 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Geting Mobile info data... ADD(HEX):0x002A800000 Size(HEX):0x0000700000 >>>>Writeing Mobile info data... This Phone Support CDMA SN has Change to : This Phone Support CDMA SN has Change to : SN has Change to :>>>>Formating Mobile USER Data... ADD(HEX):0x00EC000000 Size(HEX):0x065ABFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! Meilan E did not help help? |
The Following User Says Thank You to Nauryzbek For This Useful Post: |
