09-20-2017, 10:51 | #18 (permalink) |
Crazy Poster Join Date: Nov 2010 Location: Ukraine
Member: 1452910 Status: Offline Thanks Meter: 11 | I can not upload a screenshot, but the log writes that everything is done but as a result the phone shows that it is blocked and asks to enter a login and password |
09-20-2017, 10:52 | #19 (permalink) |
Member: 1452910 Status: Offline Thanks Meter: 11 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM8 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware InfoF4016 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x4501004446343031 Flash Name: Sandisk_Unknow Flash symbol: DF4016 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM5 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>> Analysis of mobile phone data... >>>>Reading Mobile Org Info.... Success >>>>Moving Mobile Info... This Phone Support CDMA SN has Change to :BQS2:B8W SN has Change to :BQS2:B8W >>>>Formating Mobile USER Data... ADD(HEX):0x00E6800000 Size(HEX):0x02C3B80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
11-03-2017, 23:09 | #21 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2363091 Status: Offline Thanks Meter: 0 | Hello, Help remove the flyme account. I tried to remove the flyme account with MRT dongle(V2.08) select the model note1+Meilan 5+Meilan 5s pressed the loudness up and flipped the phone. Everything goes well in MRT but the password is not removed from the phone Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM4 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:JHAG4a >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x90014A4841473461 Flash Name: Hynix_Unknow Flash symbol: JHAG4a >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>> Analysis of mobile phone data... >>>>Reading Mobile Org Info.... Success >>>>Moving Mobile Info... This Phone Support CDMA SN has Change to :BQQ28QAY SN has Change to :BQQ28QAY >>>>Formating Mobile USER Data... ADD(HEX):0x00E6800000 Size(HEX):0x02C3B80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
11-20-2017, 16:03 | #26 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Russia, Ivanovo city
Member: 2006990 Status: Offline Thanks Meter: 540 | Plese hellp me to flash Meizu M5c Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM4 >>> Device driver identification: PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware InfoF4016 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x4501004446343031 Flash Name: Sandisk_Unknow Flash symbol: DF4016 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM5 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success Initialization Write Flash Parameter Fail After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
11-20-2017, 20:34 | #27 (permalink) |
Freak Poster Join Date: May 2009
Member: 1024020 Status: Offline Thanks Meter: 128 | Read all page 1 -until end use google translate if not understand http://forum.gsmhosting.com/vbb/f492...-boot-2277616/ |
11-21-2017, 13:51 | #28 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
and no need MD1_DB fie for this phone?? | |
