Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MRT - Mobile repair tool
Old 06-07-2018, 10:52   #1 (permalink)
levsha's Avatar
Member: 10505
Sonork: 100.40828
Thanks Meter: 363
Unhappy Meizu M5S unlock password issue
Hello, Team.
Disconnect Mobile...
    Re-Put the Mobile Bettery...
    Then Connect your Phone to Computer again....
    Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
    Get Mobile Port is:  COM80
>>> Device driver identification:
    MediaTek USB Port
>>> Mobile Has Connect...
    CPU_NAME: MT6735
>>> Reading Mobile Hardware Info...Success
    HW_Inf:  8A00    SW_Inf:  CA00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
>>>>Trying Connect to Service verification data...
Success
>>> Downloading Boot1 To Mobile Phone...Success
    The Flash Hardware Info:JHAG4a
>>> Downloading Boot2 To Mobile Phone...
>>> Initializationing Mobile Hardware Parameter...    After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
How to solve this problem?
levsha
Old 06-07-2018, 11:48   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,697
Have selected meilan 5s and hold vol -
Old 06-07-2018, 12:32   #3 (permalink)
levsha's Avatar
Member: 10505
Sonork: 100.40828
Thanks Meter: 363
Yes, I did. I tried off phone, hold - and insert cable. Tried power on, hold - and power untill off. All the same. Program stopped on string >>> Initializationing Mobile Hardware Parameter...
Old 06-08-2018, 09:08   #4 (permalink)
levsha's Avatar
Member: 10505
Sonork: 100.40828
Thanks Meter: 363
Any idea?
levsha
Old 06-08-2018, 10:10   #5 (permalink)
clinicmobile's Avatar
Member: 1024020
Thanks Meter: 125
How about vol - and + press together.
Old 06-10-2018, 15:38   #6 (permalink)
Member: 527144
Thanks Meter: 13
Same problem
    Get Mobile Port is:  COM65
    MediaTek USB Port
    CPU_NAME: MT6735
Success
    The Flash Hardware Info:GE6BMB
Old 06-10-2018, 16:04   #7 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,697
Select meilan A5
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 06-10-2018, 17:25   #8 (permalink)
Member: 527144
Thanks Meter: 13
    MediaTek USB Port
    CPU_NAME: MT6735
Success
Old 06-10-2018, 17:28   #9 (permalink)
Member: 527144
Thanks Meter: 13
The Following User Says Thank You to sc-flasher For This Useful Post:
Old 06-10-2018, 17:30   #10 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,697
Try again meilan 5s and try and try maybe server connection not stable
Old 06-10-2018, 19:59   #11 (permalink)
Member: 527144
Thanks Meter: 13
Another PC, without antivirus. another internet provider. The same error (((
Old 06-10-2018, 20:55   #12 (permalink)
Member: 527144
Thanks Meter: 13
Raised vpn, the problem remained. The problem in the software, because as a note 3, connected without problems.
Old 06-12-2018, 13:37   #13 (permalink)
Member: 527144
Thanks Meter: 13
It turned out to be done like A5. Just inserted the cable, without holding any buttons.
The Following 2 Users Say Thank You to sc-flasher For This Useful Post:
Old 06-13-2018, 21:08   #14 (permalink)
levsha's Avatar
Member: 10505
Sonork: 100.40828
Thanks Meter: 363
After setting model meilan A5:
>>> Searching Mobile Port...    Get Mobile Port is:  COM80
    MediaTek PreLoader USB VCOM (Android)
    CPU_NAME: MT6735
>>> Initialization Mobile ...Success
>>> Downloading Boot2 To Mobile Phone...Success
    =====================Flash Type(eMMC)==============
    Flash   Size: 0x00000003AB400000 -> 15028M
    Flash     ID: 0x90014A4841473461
    Flash   Name: Hynix_Unknow
    Flash symbol: JHAG4a
>>> Software Auto Switch Hight Speed Has Enable...
>>> Swich Mobile to Hight Speed Re\Wr Port...
    Get Mobile Port is:  COM105
    MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Success
>>> Extracting valid data from partition data...
>>>>Formating Mobile USER Data...
    ADD(HEX):0x00B6000000    Size(HEX):0x02F4380000
    Corresponding operation completed!!!
The issue is solved. Thanks!
levsha
The Following 3 Users Say Thank You to levsha For This Useful Post:
Old 06-08-2019, 19:30   #15 (permalink)
Member: 1305017
Meizo m5s
PeLace I am in the same problem did you find the solution and thank you
Page generated in 0.16029 seconds with 7 queries
