Mi Y1 write firmware by AETool GM supporters, i hvae wrote firmware of Mi Y1 by AETool. Its Log is: >>>>Searching EMMC Devices.... MAE ToolSN 00A2 TS37 >>>>Testing EMMC disk read status.... Reading EMMC Capacity Info... Capacity Size:62537072640Byte/59640MB/58.64GB;(Hex:0x0E8F800000) >>>>Write Firmware modem.... File Size: 0x0005400000--->84MB Flash Add: 0x0004000000 Flash Block Size: 0x0005400000--->84MB EMMC Write Fail... Error Add:0x000000000000 >>>>Write Firmware sbl1.... File Size: 0x000005A2C4--->0MB Flash Add: 0x000C002400 Flash Block Size: 0x000005A2C4--->0MB >>>>Write Firmware sbl1bak.... File Size: 0x000005A2C4--->0MB Flash Add: 0x000C082400 Flash Block Size: 0x000005A2C4--->0MB >>>>Write Firmware rpm.... File Size: 0x000002D598--->0MB Flash Add: 0x000C102400 Flash Block Size: 0x000002D598--->0MB >>>>Write Firmware rpmbak.... File Size: 0x000002D598--->0MB Flash Add: 0x000C182400 Flash Block Size: 0x000002D598--->0MB >>>>Write Firmware tz.... File Size: 0x0000176D00--->1MB Flash Add: 0x000C202400 Flash Block Size: 0x0000176D00--->1MB >>>>Write Firmware tzbak.... File Size: 0x0000176D00--->1MB Flash Add: 0x000C402400 Flash Block Size: 0x0000176D00--->1MB >>>>Write Firmware devcfg.... File Size: 0x000000EDDC--->0MB Flash Add: 0x000C602400 Flash Block Size: 0x000000EDDC--->0MB >>>>Write Firmware devcfgbak.... File Size: 0x000000EDDC--->0MB Flash Add: 0x000C642400 Flash Block Size: 0x000000EDDC--->0MB >>>>Write Firmware dsp.... File Size: 0x0001000000--->16MB Flash Add: 0x000C682400 Flash Block Size: 0x0001000000--->16MB >>>>Write Firmware splash.... File Size: 0x0000057F4E--->0MB Flash Add: 0x0014000000 Flash Block Size: 0x0000057F4E--->0MB >>>>Write Firmware aboot.... File Size: 0x00000932DC--->0MB Flash Add: 0x0018000000 Flash Block Size: 0x00000932DC--->0MB >>>>Write Firmware abootbak.... File Size: 0x00000932DC--->0MB Flash Add: 0x0018100000 Flash Block Size: 0x00000932DC--->0MB >>>>Write Firmware boot.... File Size: 0x0001F7C54A--->31MB Flash Add: 0x0018200000 Flash Block Size: 0x0001F7C54A--->31MB >>>>Write Firmware recovery.... File Size: 0x00020CF54E--->32MB Flash Add: 0x001C200000 Flash Block Size: 0x00020CF54E--->32MB >>>>Write Firmware cache.... Write Ext4 Flash to EMMC.... Flash Add: 0x00E4000000 Flash Block Size: 0x000061A0E8--->6MB >>>>Write Firmware config.... File Size: 0x0000008000--->0MB Flash Add: 0x00F6180000 Flash Block Size: 0x0000008000--->0MB >>>>Write Firmware mdtp.... File Size: 0x0000D1C86A--->13MB Flash Add: 0x010C180000 Flash Block Size: 0x0000D1C86A--->13MB >>>>Write Firmware cmnlib.... File Size: 0x0000031240--->0MB Flash Add: 0x0110000000 Flash Block Size: 0x0000031240--->0MB >>>>Write Firmware cmnlibbak.... File Size: 0x0000031240--->0MB Flash Add: 0x0110040000 Flash Block Size: 0x0000031240--->0MB >>>>Write Firmware cmnlib64.... File Size: 0x000003E7C0--->0MB Flash Add: 0x0110080000 Flash Block Size: 0x000003E7C0--->0MB >>>>Write Firmware cmnlib64bak.... File Size: 0x000003E7C0--->0MB Flash Add: 0x01100C0000 Flash Block Size: 0x000003E7C0--->0MB >>>>Write Firmware keymaster.... File Size: 0x00000372D8--->0MB Flash Add: 0x0110100000 Flash Block Size: 0x00000372D8--->0MB >>>>Write Firmware keymasterbak.... File Size: 0x00000372D8--->0MB Flash Add: 0x0110140000 Flash Block Size: 0x00000372D8--->0MB >>>>Write Firmware cust.... Write Ext4 Flash to EMMC.... Flash Add: 0x011C000000 Flash Block Size: 0x00110AFAA0--->272MB >>>>Write Firmware userdata.... Write Ext4 Flash to EMMC.... Flash Add: 0x0150000000 Flash Block Size: 0x00166BF6E8--->358MB >>>>Write Firmware PrimaryGPT.... File Size: 0x0000004400--->0MB Flash Add: 0x0000000000 Flash Block Size: 0x0000004400--->0MB All is Done It shows error while writing modem partition and system not write. Plz explain what is the problem. thnx Sandeep Kumar |
Any screenshot can be posted? |
https://i.postimg.cc/62w3RqxP/Y1-I.jpg |
Note 3 Sir i receive mi note 3 in dead condition without detecting USB. Make ISP pinout and do write firmware operation. Same error as in redmi y1 comes. So i think emmc of both handset is faulty. |
