Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 10-13-2016, 15:55   #1 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 221
Micloud MI5 Completed Remove ★ MRT Leading The Pack ★
successfully remove xiaomi MI5 by one click
device must be mode EDL
Use deep Flash Cable to mode EDL
print screen windows xp
The Following 7 Users Say Thank You to wutangclan33 For This Useful Post:
Old 10-13-2016, 18:15   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
Yes ... You are correct!!! Boot cable is already had available in market
XIAOMI depth flash cable : bypass BootLoad locks, enter into the depth of 9008 flash mode ,then flash the phone
Press the phone ON/OFF button, When closing the phone , pls immediately press the switch of the cables about 8 seconds, , and see the computer in the device manager to recognize to port 9008, indicates success into the depth of the flash mode.
Use this , your MRT DONGLE MORE POWERFUL!!!
Have a nice day!
File Type: jpeg DA73A8C8-5E3E-42CF-B69A-545AE0006E20.jpeg (23.3 KB, 243 views)
The Following 4 Users Say Thank You to .::ARD::. For This Useful Post:
Old 10-14-2016, 18:11   #3 (permalink)
Member: 1753366
where can i buy depth flash cable
Old 10-18-2016, 10:04   #4 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,781
can connect with me
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 10-23-2016, 18:40   #5 (permalink)
Member: 2627974
Thanks Meter: 9
Remove account I can fully Xiaomi MI5 ?
Old 11-01-2016, 16:19   #6 (permalink)
Member: 138575
Thanks Meter: 53
MI 5 password done
Keep Hold the Power key and VOL+ key
Waiting Mobile MI logo come,then release the power key
When Mobile into recovery,release your vol+ key,
Searching Android Mobile...
Get the Android Deivers
Device identifier:
sideload::ro.product.name=gemini;ro.product.model= MI 5;ro.product.device=gemini;
>>>>Reading Mobile Version Info...
Miui Version:V8.0.2.0.MAAMIDG
Android Version:6.0.1
Device Info:gemini
branch Info:F
language Info:en
region Info:GB
SN Info:0xf7750b1e
>>>>Erasing Userdata...
Formating Info:Format_data_success.
Corresponding operation completed!!!
That too in Secs. SPERB TEAM!
jackle123
Old 11-10-2016, 18:21   #7 (permalink)
Member: 1511287
Hello its possible send me pm for buy this cable ? because i try sen pm for .::ARD::. and not replay.
Thanks
The Following User Says Thank You to cbur For This Useful Post:
Old 11-11-2016, 06:41   #8 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 191
I want this cable too
Old 11-14-2016, 15:23   #9 (permalink)
Member: 1511287
I made the cable and it worked without problems
Thanks
Old 11-23-2016, 20:23   #10 (permalink)
Member: 2430597
Thanks Meter: 68
Only by means of this cable, you can delete your account?
Old 11-23-2016, 21:52   #11 (permalink)
Member: 2430597
Thanks Meter: 68
not deleted account
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM2
>>> Device driver identification:
Qualcomm HS-USB QDLoader 9008
Connect Timeout
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
The Following User Says Thank You to volk12 For This Useful Post:
Old 11-24-2016, 00:01   #12 (permalink)
Member: 2430597
Thanks Meter: 68
Your software does not work
Old 11-29-2016, 18:32   #13 (permalink)
Member: 2430597
Thanks Meter: 68
Already works were server problems ....
Old 05-08-2017, 12:32   #14 (permalink)
Member: 2376030
Thanks Meter: 14
Originally Posted by volk12 View Post
not deleted account
disconnect mobile...
Re-put the mobile bettery...
Then connect your phone to computer again....
Please make sure mobile better has power...
>>> searching mobile port...
Get mobile port is: Com2
>>> device driver identification:
Qualcomm hs-usb qdloader 9008
connect timeout
after finish;disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
the same problem here its server problem
Old 05-09-2017, 00:59   #15 (permalink)
Member: 1128422
Thanks Meter: 63
not deleted account
Connect Timeout
follow manual given by sw
 Clear mobile account info help:
    now you has select : XiaoMi 5
    this set have bootload lock;
    unlock it need into 9008 and use miflash flash it
    you can download low version form gsm forum:
    http://forum.gsmhosting.com/vbb/f492/meizu-all-flash-file-download-line-2143317/
    after flash then power on the set and enable usb debug
    click remover apk
Page generated in 0.56015 seconds with 8 queries
