03-15-2019, 16:10 | #394 (permalink) |
Major Poster Join Date: Jan 2017 Location: Uzbekistan
Member: 2678617 Status: Offline Thanks Meter: 5 | Hello. I recently bought mrt-dongle. Well, I never took a mi account because a new update on Xiaomi smartphone miui10. Please make an update so that I have at least one Mi account removed to justify a purchase. |
The Following User Says Thank You to dima0690 For This Useful Post: |
03-26-2019, 03:09 | #401 (permalink) |
Junior Member Join Date: Mar 2019 Location: india
Member: 2900323 Status: Offline Thanks Meter: 1 | Connect to Service Fail,Please re-run the software and try again... Fail i am getting this error while flashing Meizu M3 Note "L91/L681H" :- Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM5 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Connect to Service Fail,Please re-run the software and try again... Fail After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
03-26-2019, 05:18 | #402 (permalink) |
Freak Poster Join Date: Sep 2016 Location: BIHAR , INDIA Age: 33
Member: 2630154 Status: Offline Sonork: 1681209 Thanks Meter: 112 | HUAWEI LND - AL30 ( SW : LND - AL308.0.0.170 { C675 } ) ANDROID VERSION - 8.0.0 factory reset + FRP Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:7300a2e38cc2d8ed >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:7495dd972bcc1a84 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:7a3f4f9bea40a9dd Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Userdate Creating filesystem with parameters: Size: 57336115200 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Journal blocks: 32768 Label: Blocks: 13998075 Block groups: 428 ved block group size: 1024 Created filesystem with 11/3506176 inodes and 266140/13998075 blocks Creating filesystem with parameters: Size: 134217728 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Journal blocks: 1024 Label: Blocks: 32768 Block groups: 1 Reserved block group size: 7 Created filesystem with 11/8192 inodes and 1550/32768 blocks target reported max download size of 534773760 bytes erasing 'userdata'... KAY [ 2.959s] sending 'userdata' (140922 KB)... OKAY [ 3.072s] writing 'userdata'... OKAY [ 0.939s] erasing 'cache'... OKAY [ 0.062s] sending 'cache' (6200 KB)... OKAY [ 0.165s] writing 'cache'... OKAY [ 0.198s] 5s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.007s Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:7300a2e38cc2d8ed >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:7495dd972bcc1a84 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:74cf1f607349cad1 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) Erase success , the device will reboot and factory reset OKAY [ 0.026s] finished. total time: 0.026s >>>>Rebooting Mobile Phone |
03-28-2019, 18:22 | #405 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2832055 Status: Offline Thanks Meter: 0 | Xiaomi redmi note 5 , quitar cuenta MI, hace todo el proceso bien. Encimera el teléfono correcto pero desde que le pongo wiffi o tarjeta movil salta de nuevo el bloqueo. Alguien sabe el porque??? Uso el mrt dongle. Xiaomi redmi note 5, remove MI account, it does the whole process well. Countertop the correct phone but since I put wiffi or mobile card jumps back the lock. Does anyone know why? I use the mrt dongle. |
